| Forum topic by bigike | posted 711 days ago | 989 views | 0 times favorited | 22 replies | ![]() |
711 days ago |
Topic tags/keywords: hand plane paint rehab As you know I did a couple plane rehabs and now the paint is cured but it feels kinda rough to the touch. How can I get the paint to feel smoother like the way it looks? Also when I touch it there is a scuff mark left even if I just rub it a little with my finger. I know my hands are rough but this is ridiculous. It’s a very light scuff mark you would have to be holding the plane in your hand to see it or I would have to magnify it. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
22 replies so far
#1 posted 711 days ago |
Paint? -- 温故知新 |
#2 posted 711 days ago |
What kind of paint did you use, Ike. I’ve used a gloss black heavy duty spray from HD, and it looks and feels like the original japanning. -- Charlie M. "Woodworking - patience = firewood" |
#3 posted 711 days ago |
Ike, it almost sounds like the paint isn’t fully cured or dried ? -- Glen, Vernon B.C. Canada |
#4 posted 711 days ago |
Original Planes have japanning instead of paint. There are processes for doing this. I belive it involves baking the finish. I have seen recommendations for automotive paints for this purpose. Personally, I leave my planes original and do not repaint. I use schellac on the body of the plane where the plane is japanned to protect it from rust. -- We must guard our enthusiasm as we would our life - James Krenov |
#5 posted 711 days ago |
I used some kind of paint I got from the hardware store it’s enamel paint for metal and plastic I for get the name and I threw out the can. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#6 posted 711 days ago |
I baked the paint on for about 20mins it has been curing for about three weeks now and it has 8 coats of paint. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#7 posted 711 days ago |
Maybe the baking process had a negative effect on the paint because it was not the heat-resistant type. I have read of guys using engine paint and then baking it on, but maybe that’s not a good idea for regular paint. I’ve done 5 or 6 planes so far following the same procedure… applying several light coats about 30 minutes apart… and the paint was smooth and hard as a rock by the next day. -- Charlie M. "Woodworking - patience = firewood" |
#8 posted 711 days ago |
The paint came out very hard it’s just like a scuff as if you had a piece of acrylic and rubed it with a hard papertowel, mabe I’m just being pickey about it I’ll try the rubbing compound and see what happens! -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#9 posted 711 days ago |
This question might be moot, but what did the paint’s instructions say about applying the product? -- 温故知新 |
#10 posted 711 days ago |
make shure thearea to be painted is clean and free of greese and dirt. Also that the temp is about 60 deg. same as any other spray paint. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#11 posted 711 days ago |
I doubt its the paint. Even a cheap can of spray paint should leave a decent enough surface after it drys. I think the issue may be with the plane and or prep work. What kind of plane is it? I ask because I have had some planes that were not made by Stanley that had a really rough metal casting almost like it was bumpy. Also did you strip all the old finish off? Was it sanded before you painted? Did you use any primer? -- Dan - "Collector of Hand Planes" |
#12 posted 711 days ago |
What did the instructions say about baking the finish? -- 温故知新 |
#13 posted 711 days ago |
Nothing about bakeing the finish but what I did was heat the oven and turn it off then put the plane in there after it had about 1 day to dry. As for the prep of the plane the only thing I didn’t do was use primer, I did take all the paint off and sanded as much as I can. They are record planes I don’t see what that would have to do with the paint though. -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
#14 posted 711 days ago |
Is this what you used?
-- shdesign3.com |
#15 posted 711 days ago |
This is the stuff I used, -- Ike, Big Daddies Woodshop, http://www.icombadaniels@yahoo.com |
| Forum | Topics |
Woodworking Skill Share
8845 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
