Paint can rim clean up
Forum topic by paulmon posted 07-20-2018 02:24 AM 1139 views 0 times favorited 23 replies Add to Favorites Watch
View paulmon's profile
paulmon
52 posts in 369 days
07-20-2018 02:24 AM
Topic tags/keywords: paint paint can cleanup paint can rim
I’ve been focused on a long project (that should be done soon) and haven’t had much time for anything else. Today though, I suddenly thought of an easy solution for cleaning the paint can rims. No matter how hard I try I always seem to be chasing that last little bit of paint around and around the rim.
Now I KNOW this has to have been done before, but I suddenly thought of a solution, and of course, I had to make a video of it. Because that’s what I do :)
https://youtu.be/xhneTEtw-0Q
23 replies so far
View bandit571's profile
bandit571
21973 posts in 2918 days
#1 posted 07-20-2018 02:29 AM
I usually just drive a nail down through the rim a few places…to act as “drains”....rim then empties itself.
Rick Dennington
6343 posts in 3429 days
#2 posted 07-20-2018 02:32 AM
That’s a pretty slick solution, but an easy solution also is simple: just take a 10-12 penny nail, and a hammer and punch several holes all the way around the rim so the paint, stains, contact cement, etc. can drip back down into the can…..problem solved… It’s worked for me for years, and still does….!!
-- " At my age, happy hour is a crap and a nap".....!!
paulmon
#3 posted 07-20-2018 02:32 AM
I’ve done that one before too. It works. In this case I was using contact cement so the tape was better.
Paul M
- bandit571
View GR8HUNTER's profile
GR8HUNTER
5365 posts in 947 days
#4 posted 07-20-2018 02:33 AM
I also poke holes with old small screwdriver :<))
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#5 posted 07-20-2018 04:10 AM
Ditto. The holes work.
View mel52's profile
mel52
625 posts in 499 days
#6 posted 07-20-2018 04:32 AM
I’m with everyone else, I just punch holes around the rim.
-- MEL, Kansas
View John Smith's profile
John Smith
1538 posts in 397 days
#7 posted 07-20-2018 11:37 AM
nicely done Paul !!
I have several of the plastic rings that snap onto the paint can lid
but the contact cement cans have always been a challenge for me.
the tape is an excellent idea for contact cement !!
I used to poke holes in paint and varnish can rims but, in my opinion,
that method “could” also let air into the can to promote skinover.
and contact cement will never drain out of a small hole in the rim.
nicely done and thanks for sharing !!
The viewers should take note this idea is directed mainly to CONTACT CEMENT cans.
-- I started out with nothing in life ~ and still have most of it left.
paulmon
#8 posted 07-20-2018 12:15 PM
Yea, I’ve had cans skin over from the hole punch method. I went to trying to punch inwards with my holes but I like this method pretty good (so far) as it leaves the rim absolutely clean.
Paul M
nicely done Paul !!
- John Smith
View bondogaposis's profile
bondogaposis
5148 posts in 2586 days
#9 posted 07-20-2018 12:35 PM
The hole punch method works fairly well for most things, but not on contact cement. The tape method looks like a great solution for that.
-- Bondo Gaposis
View MrRon's profile
MrRon
5261 posts in 3478 days
#10 posted 07-20-2018 04:30 PM
Why does contact cement get into the rim of the can? I use contact cement all the time and never have that problem. I don’t wipe the brush against the rim, but just let it drip until the amount of cement is right; then I twirl the brush until the drip stops.
bondogaposis
#11 posted 07-20-2018 06:44 PM
When I use contact cement, I most often roll it. If you roll it, you have to pour in a tray and if you pour it, it will be all over the rim.
-- Bondo Gaposis
View Desert_Woodworker's profile
Desert_Woodworker
1673 posts in 1449 days
#12 posted 07-20-2018 07:04 PM
I love your idea, sounds good to me.
as for the nail method, sometimes the punched hole get rusted…
Also from Lowes $1.28
-- Desert_Woodworker
John Smith
#13 posted 07-20-2018 08:35 PM
Contact Cement:
If you roll it, you have to pour it in a tray or on the surface.
Bondo
X2
DWW ~ I’m gonna get me one of those Dozers tomorrow and try it out.
View Kazooman's profile
Kazooman
1265 posts in 2187 days
#14 posted 07-20-2018 10:27 PM
Geez…. I have used my own homemade “Paint Dozer” for years and years. A folded sheet of paper towel does exactly the same thing and you don’t have to clean it. A bit of a point down in the groove, the bulk folded to push the residue back into the can, and round and round we go. Sparkling clean rims, the excess goes back in the can, and you toss the dirty towel. Works for paint, contact cement, stain, shellac, and probably marinara sauce if it comes in a paint can style container.
MrRon
#15 posted 07-20-2018 10:31 PM
- bondogaposis
I guess because I don’t roll it, I wouldn’t have the problem. It’s a good tip anyway.
