| Forum topic by breaknrn | posted 712 days ago | 2173 views | 0 times favorited | 16 replies | ![]() |
712 days ago |
Topic tags/keywords: tip trick drilling accurately placed holes Okay, here’s a challenge for all you readers out there. I just picked up some aluminum miter slot bars from Rockler and they are tapped for 1/4 20 holes . To attach the bars to the table saw cross cut sled I am building, I need to drill holes through the sled to align with the pre drilled holes in the bars. The screws need to be screwed in from the top because there is no counterbore for screw heads on the bars themselves. I could use a punch to locate the holes to be drilled in the sled, but it is not accurate enough because the punch has a diameter smaller than the hole I need to drill. Anyone have any ideas? Very much appreciated! -- breaknrn |
16 replies so far
#1 posted 712 days ago |
I have several ideas, use a drill bit the diameter of the hole in the miter bar (http://en.wikipedia.org/wiki/Unified_Thread_Standard), position the bar when you want it with double stick tape and turn the bit by hand until you get a dimple in the bottom of the sled. Remove the bar and drill the holes. Use a Insty-bit drill bit/countersink combo, turn the countersink around so that the cutting edge faces the drill, insert the shaft of the drill bit into miter bar and then into the drill chuck. Hold the bar in a vice so it doesn’t spin, start the drill slowly and when you pull it away from the miter bar the countersink will countersink the bar exactly in the center of the miter bar holes. You can find center punches at Sears or Ace Hardware and other places in multiple sizes for $3-$4 each, just buy one that fits the holes, while not elegant it might be the cheapest solution. -- Paul, Beaverton OR, www.TravelbyPaul.com |
#2 posted 712 days ago |
what paul has said…i was going to say a counter sink in reverse. it should locate the centre of the hole for you -- just get stuck in and have a go!!! |
#3 posted 711 days ago |
A self centering drill bit sometimes called a “vix” bit. you’ll have to get one the proper size. -- Darrell, making more sawdust than I know what to do with |
#4 posted 711 days ago |
A vix bit will not really help here except to create a pilot hole which would have to be enlarged. The hole size in the slid is actually bigger than the hole in the miter bar. -- Paul, Beaverton OR, www.TravelbyPaul.com |
#5 posted 711 days ago |
As devann said: A self centering drill bit sometimes called a “vix” bit,maybe a (5/64” Vix Bit for #3 & 4 Screws) , will mark hole locations,on the sled,through the holes in the miter bar, and will be centered,so you can drill and counter sink your 1/4” holes. Paul M Cohen: I don’t think he has drilled any holes in the sled yet These highly accurate bits are used for precise drilling of holes for cabinet and door hinges, door butts and all large and small hardware. Desired depth is achieved by loosening a setscrew, setting the high speed drill bit, then tightening the setscrew.
-- E J ------- Always Keep a Firm Grip on Your Tool |
#6 posted 710 days ago |
Paul, Thanks for the tip. it looks like a 7/32” bit fits pretty closely in to the hole size needed to fit inside the 1/4 20 pre tapped hole in the bar. Luckily, I have this size in a brad point bit. Okay, here’s the procedure I ended up using. 1. Clamp the bar to the base of the sled temporarily in their desired locations. Thanks Paul and everyone for their tips. Note: as Paul said, Sorry, a vix bit won’t work here since its tough to get a vix bit with the same outside diameter as the 1/4” hole size. Even if you want to use it to make a dimple in the wood below, you’d have a difficult time making sure it is plum and square to the wood while using the tip as a reference edge because the miter bar wasn’t countersinked. Thanks anyways! -- breaknrn |
#7 posted 710 days ago |
Another method would be to use a transfer punch, this is a machinist punch set made in sizes similar to a -- As ever, Gus-the 74 yr young apprentice carpenter |
#8 posted 710 days ago |
Page 21 of the Lee Valley Feb 2011 Suppliment (http://www.leevalley.com/US/wood/page.aspx?cat=1,43456&p=54892) has a center punch set for 14.95 for a Transfer Punch Set for accurate layout of holes. Not near the same price as center finding drill bits. I have been toying of getting this set but have not done so yet. Royal |
#9 posted 710 days ago |
I know I’m missing something obvious, but … if you punch the center of the right location, and use a brad-point (or equivalent) type of drill bit, of the appropriate size, why WON’T it be just where you want it to be ?? -- -- Neil |
#10 posted 710 days ago |
Actually drilling holes with a drill press is not an accurate way of making round holes for various reasons. -- excuse my typing as I have a form of parkinsons disease |
#11 posted 710 days ago |
The key is actually punching the exact center of the hole. If you just dot it with a pencil, or other marking device, then you are not on center. By using the predrilled holes as guides, and coloring in the hole, or marking the center of the hole, many of us can’t mark the exact center of the hole with a regular punch or hold a pencil exactly 90 degrees and mark the exact center of the hole. Being slightly off just drives some of us crazy! So, using something like this marking set that the punch is the exact same size as the pre-drilled hole, then it will give us a true center. (Then if we don’t use a drill press, then our holes are not drilled perfectly.) Royal |
#12 posted 710 days ago |
The way to drill a perfectly sized hole (not location) is to drill 1/64 undersize and then “drill ream” it with the finished size drill bit. -- Government does not solve problems; it subsidizes them. |
#13 posted 710 days ago |
I have used drill bits to mark a hole through, another hole hundreds of times -- E J ------- Always Keep a Firm Grip on Your Tool |
#14 posted 700 days ago |
I’ve used the Harbor Freight Transfer punch set (paid maybe $5 on sale) A LOT with no problems on both wood and metal. But hey, sounds like the problem was solved and all are happy now…. -- "You can tell the pioneers by the arrows in their back" -- Unknown |
#15 posted 660 days ago |
One more simple suggestion … Chuck up a 1/4”-20 long setscrew in your drill and grind/file the exposed end to a point. Clamp the miter bar in place … run the new setscrew into the hole, pointy end first … screw it in until it meets resistance … give it another turn or so, and tap it with a hammer. You should have a very accurate center mark which can be drilled to whatever size hole you wish. -- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ... |
| Forum | Topics |
Woodworking Skill Share
8847 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15982 |
Hand Tools
2098 |
Jigs & Fixtures
501 |
Wood & Lumber
2909 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
