Am I set up for lacquer
Forum topic by Coleby posted 07-08-2011 01:14 AM 1334 views 0 times favorited 9 replies Add to Favorites Watch
View Coleby's profile
Coleby
29 posts in 3028 days
07-08-2011 01:14 AM
Topic tags/keywords: question finishing
I have a binks siphon gun and compressor. I have no booth but I can spray outside. I am finishing a newly built gun cabinet. Am I good to spray and what products will likely suit me best??? Thanks
-- Dean, http://www.woodworkerColeby.com
9 replies so far
View Steven H's profile
Steven H
1117 posts in 3298 days
#1 posted 07-08-2011 03:11 AM
Spray 40 sample pieces first than the cabinet.
View Earlextech's profile
Earlextech
1162 posts in 2928 days
#2 posted 07-08-2011 11:15 PM
Look into General Finishes, they all have good results. Find them at Woodcraft.
View TheOldTimer's profile
TheOldTimer
226 posts in 3324 days
#3 posted 07-09-2011 12:00 AM
I totally agree with Steven, practice,practice and more practice on scraps or cardboard. I only spray water base lacquor and my favorate is Target Coatings.
-- TheOldTimer,Chandler Arizona
Coleby
#4 posted 07-09-2011 01:05 AM
Is it a good idea to use a linseed oil on my cabinet and then lacquer or poly it?? Or are they not compatable
View Luke's profile
Luke
290 posts in 2925 days
#5 posted 07-09-2011 01:26 AM
I’m sure you’ll hear it a million times. But Jeff Jewitt has a book called Spray Finishing made simple. It helped me alot.
Fine Woodworking also had a book called “Taunton’s Complete Illustrated Guide to Finishing” That book is also helpful in determining what is compatible and different techniques. But if you plan to spray, Jeff Jewitt’s book helped me alot.
And practice, or you may end up doing what I did the first time I sprayed… sanded it all off, and practiced on something else, and then sprayed again. :)
View bigike's profile
bigike
4055 posts in 3526 days
#6 posted 07-09-2011 03:50 AM
what binks gun do u have a model 7 or a 2001?
View bobdurnell's profile
bobdurnell
317 posts in 4135 days
#7 posted 07-09-2011 04:15 AM
The Jocks have asked good questions so I’ll just tell what works for me. I have a Binks 37 gun, had it for about 30 years still works great. I now use Deft clear wood finish that is thinned with lacquer thinner. I shoot the stuff thinned a little at about 40 psi and I adjust my fan pattern regularly. Practice also helps. Good luck—-bob
-- bobdurnell, Santa Ana California.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3524 days
#8 posted 07-09-2011 06:57 PM
Assuming your compressor is big enough, you should be fine. I use Binks #7 and 2001 on my siphon guns and 2001 on my pressure pots.
I use Gemini Coatings, but there are lots of good brands. M L Campbell is good. If you have a local professional paint supplier, start there . That’s much easier than having lacquer shipped.
Be sure it’s not raining—LOL
-- http://shepherdtoolandsupply.com/
TheOldTimer
#9 posted 07-11-2011 07:21 PM
Just a quick recommendation, if you are going to use BLO to pop the grain, I would use a 1lb. cut of shellac as a sealer prior to spraying your lacquor. Shellac is a finish that is compatable with all finishes.
