Building Thickness sander - Drum Question
Forum topic by wildbill001 posted 07-07-2011 09:33 PM 14306 views 1 time favorited 16 replies Add to Favorites Watch
View wildbill001's profile
wildbill001
111 posts in 2511 days
07-07-2011 09:33 PM
Topic tags/keywords: thickness sander drum sander question homemade
Building a thickness sander based on designs I’ve seen here and on the ‘net’. One thing I rarely, if ever, see mentioned is attachment of the wooddisk to the shaft. Some folks have said that the epoxy/glue they used to glue-up the drum was sufficient to hold to the shaft. Others don’t mention anything about it.
I have a 5/8” shaft, with 5” MDF disks. The disks move easily along the shaft after drilling a 5/8” hole. I can’t help but wonder if I need to somehow “pin” the drum to the shaft to keep it from free-wheeling.
So for those who have gone down this road, How did you attach the disks to the shaft ?
TIA
Bill
-- "You can tell the pioneers by the arrows in their back" -- Unknown
16 replies so far
View Bertha's profile
Bertha
13494 posts in 2562 days
#1 posted 07-07-2011 09:41 PM
I considered making one of these. You could grind a flat into the shaft to engage a long machine screw inserted from the perimeter of the disk. You could also thread the axle and capture the disks with nuts. I was worried about exactly what you’re worrying about; I applaud you for going for it!
View crank49's profile
crank49
4028 posts in 2840 days
#2 posted 07-07-2011 10:25 PM
Caution! A 5/8” dia shaft is pretty small for the mass you are wanting to spin. across the length most drums need to be; I’m assuming over 20” or so. If it was a metal drum, no problem; the drum itself adds rigidity. Not so much so with wood or MDF. Then, to drill a 1/4” hole through this shaft in three places; I don’t think I want to be standing in the line of fire when this thing revs up.
From what I have read, most of these drums use 5/8” dia. shaft for a 16” to 18” drum. One builder said if he were doing it over, or going any longer, he would use 1”, but didn’t say why.
The link below here is another LJ who did this. His, and 3 or 4 other threads I read, indicate they only attach the drum disks to the shaft with epoxy.
http://www.rockslide.org/drum%20sander.html
Bertha
#3 posted 07-07-2011 10:32 PM
Good point, Cr1. How are the other guys around here doing it?
wildbill001
#4 posted 07-07-2011 11:31 PM
Let me clarify. I’m planning on a width of 12”, possibly shorter but certainly no longer.
Bill
crank49
#5 posted 07-08-2011 12:27 AM
Well, for a 12” drum width, based on other projects I have read, you should be okay.
As far as attaching the disks to the shaft, the epoxy will absolutely adhere to the ID of the disks.
You might want to rough up the surface of the shaft in the area to be glued. Also, you want to be absolutely sure and clean all traces of oil off the shaft before installing in the disks. I have had good results using lacquer thinner as a solvent for this purpose, then follow with acetone.
Good luck, and keep us posted.
View SASmith               's profile
SASmith
1850 posts in 2856 days
#6 posted 07-08-2011 12:44 AM
This is how it is done in Shopnotes #86 Vol. 15.
-- Scott Smith, Southern Illinois
Bertha
#7 posted 07-08-2011 01:04 AM
Thanks SASmith, I’m trying to imagine what that locking wedge does.
SASmith
#8 posted 07-08-2011 01:25 AM
It is to hold the end(s) of the sandpaper.
wildbill001
#9 posted 07-08-2011 02:12 AM
Thanks SASmith for the diagram. That’s actually pretty much how I envisioned it.
crank49
#10 posted 07-08-2011 04:19 AM
Ya’ll did notice that the ShopNotes version uses a 3/4” shaft? and 3/16” pins?
Bertha
#11 posted 07-08-2011 03:32 PM
Cr1, I was planning on 1” just because the pillowblocks are easy to come by. I tend to agree with Cr1 that I’m probably underestimating the forces generated at the moment arm. I imagine 12 inches of sandpaper meeting wood at relatively high speed could generate a lot of force. I can see the axle twisting off at the pin points. I’m no engineer but I do break a lot of stuff.
View George M's profile
George M
118 posts in 2633 days
#12 posted 07-08-2011 04:11 PM
I used a 1” shaft for mine. It also uses MDF disks, but has a 26” capacity, and use the pin system seen in the Shopnotes article. The wedges are to anchor the sandpaper. Instead I used the conversion kit sold by Jet that uses Hook and Loop.
It works well, but if I did it again, I would use an aluminum cylinder rather than MDF.
-- George, Parker Colorado
Bertha
#13 posted 07-08-2011 04:39 PM
Thanks to all for explaining the wedge to me. I’ll have to look into this JET conversion.
George M
#14 posted 07-09-2011 04:56 AM
cr1,
You would have to either turn some aluminum blanks into hubs, or have someone do it for you. The LJ who helped me (Johnz) could do it. He turned the aluminum hubs for my transport rollers. I also believe TomT used an aluminum cylinder for his drum.
View BritBoxmaker's profile
BritBoxmaker
4610 posts in 2905 days
#15 posted 07-24-2011 07:38 PM
I used PVA between the discs and Epoxy to glue them to the shaft. One year of constant use later its still intact.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
