MDF vs. Plywood for jigs, table tops etc.
Forum topic by roer posted 07-07-2011 05:58 PM 10280 views 0 times favorited 20 replies Add to Favorites Watch
View roer's profile
roer
66 posts in 3147 days
07-07-2011 05:58 PM
Hi
All of us want the table top for our router table to be dead flat and our jigs and fences to be 100% straight. For that we need stable wood that remains as stable as possible under different humidity. The preferred material seems to by birch plywood, but why is MDF (or laminated MDF) so seldom the preferred choise ? As I know MDF is should be even more stable than birch plywood, or ???
20 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3066 days
#1 posted 07-07-2011 06:12 PM
Actually, MDF is probably preferred by more people for such things than plywood just because of cost. High quality birch plywood is great if you can afford it, but MDF works very well too. Unless your workshop is underwater, the MDF should be plenty stable.
I think some people avoid MDF because of the nasty dust it generates when you cut it…not because of stability issues.
-- jay, www.allaboutastro.com
View Bertha's profile
Bertha
13508 posts in 2601 days
#2 posted 07-07-2011 06:15 PM
I use MDF sandwiches because the edges are friable. Nothing wrong with MDF in my book!
View Lee Barker's profile
Lee Barker
2170 posts in 2758 days
#3 posted 07-07-2011 06:15 PM
And the dust issue is blown way out of proportion. Yes, the dust is bad, but simple precautions are all that’s required. It’s a great product, widely available, reasonably priced, easy to work, and usually delightfully flat. Put on the mask and cut, that’s my thinking.
Kindly,
View woodklutz's profile
woodklutz
221 posts in 2676 days
#4 posted 07-07-2011 06:23 PM
The problem I find is attaching it. What method do you guys use to joint. I use dry wall screws and they tear out.
-- honing my craft one mistake at a time.
View DrDirt's profile
DrDirt
4421 posts in 3650 days
#5 posted 07-07-2011 06:38 PM
I like the stability of the MDF – perhaps weight factors in as well – but jigs and templates stay nice and flat. I have a tablesaw sled made from birch ply and it warped a bit – - just enough that there is a “bump” or ridge between the left and right sides of the kerf.
Next one will be MDF – but it always seems that more attention is spent to make the NEW stuff than going back and remaking the old.
View jonasramus's profile
jonasramus
24 posts in 2883 days
#6 posted 07-07-2011 06:38 PM
Both plywood and MDF have there pro’s and con’s. Generally the best idea is to pick the one appropriate for the application.
MDF Pro’s: very stable, very flat, less expensive than high quality plywood
MDF Con’s: it is not as strong as plywood of the same thickness, it does not hold screws well, it swells terribly if it gets wet, the edges get easily damaged, it’s damn heavy.
Plywood Pro’s: is usually stable but can cup or warp, it can be purchased in a wide variety of veneers to match you project, it hold screws very well
Plywood Con’s: it’s very expensive if you buy the good stuff, it needs it’s edges covered if the pc is for show
-- Jeff, Deltona Florida
Bertha
#7 posted 07-07-2011 06:45 PM
Clutz, I usually glue and pneumatically pin it for jigs. If I need screws, I usually use fine Kregs. I have a tendency to use Kreg screws for a lot of non-pocket applications.
View GregD's profile
GregD
788 posts in 3044 days
#8 posted 07-07-2011 06:48 PM
I have problems keeping the moisture off MDF jigs. It gets hot in my garage (Houston) and sweat becomes an issue. Things I care about get a coat or two of poly or I start with melamine and edge band any exposed edges.
IMHO MDF is more flexible than flat, so I usually plan for some structure to give it good support.
woodklutz – I use Kreg’s pocket hole screws mostly and drill a pilot hole at least part way. I also do the final tightening slowly by hand – they go from tight to blown out real fast. I don’t expect MDF to conform nicely to a flathead screw, so I would drill a countersink and use a conventional flathead wood screw before trying drywall screws.
-- Greg D.
Lee Barker
#9 posted 07-08-2011 07:04 AM
MDF glues easily. I would not recommend screws into the edge. Perhaps a staple as a clamp. Biscuits work splendidly. Or you can cut a kerf and make 1/8” spline stock out of plywood.
As soon as you try a mechanical fastener in the edge, you’re running a strong risk of changing that dimension.
Performax screws are the right ones if you insist, but then you gotta buy the $25 bit.
Kindly,
Lee Barker
#10 posted 07-08-2011 04:39 PM
Confirmat, not Performax!
Bertha
#11 posted 07-08-2011 04:40 PM
Lee’s got drumsanders on the brain;)
Lee Barker
#12 posted 07-08-2011 11:54 PM
It’s the constant drumming, not the sanding, that makes me weird, Al.
View NBeener's profile
NBeener
4816 posts in 3081 days
#13 posted 07-09-2011 12:18 AM
With MDF, I’ve had great luck using Spax screws.
-- -- Neil
View azor's profile
azor
62 posts in 3351 days
#14 posted 02-25-2016 06:58 PM
Does anyone make a confirmat or spax screw in a 1 1/4” length, #8, 7, 6
-- It isn't as easy as the demos make it seem.
View Bill White's profile
Bill White
4861 posts in 3868 days
#15 posted 02-25-2016 07:35 PM
I have used Extera (exterior grade) MDF with great success. More expensive than the regular stuff, but is almost bullet proof. I even used it on porch columns of a home. Won’t work UNDER water, but it sure does not vary with humidity.
Check it out.
Bill
-- bill@magraphics.us
