How safe to have a ceiling fan in shop?
Forum topic by notdan posted 07-19-2018 01:27 AM 1157 views 0 times favorited 20 replies Add to Favorites Watch
View notdan's profile
notdan
27 posts in 1467 days
07-19-2018 01:27 AM
I’d like to put a ceiling fan in my shop, which is the third bay of a 3 car garage. Should I be worried about sawdust or any other reason this would be a bad idea? Any type of ceiling fan a better choice? I mostly do hand tool woodworking with occasional mitre/jig/circular saw.
20 replies so far
View Sawdust4Blood's profile
Sawdust4Blood
406 posts in 3106 days
#1 posted 07-19-2018 01:35 AM
Maybe not appropriate if you mostly use hand tools but food for thought… my Jet air filtration unit moves about the same amount of air in the shop as a ceiling fan (and cleans the air as bonus).
-- Greg, Severn MD
View bondogaposis's profile
bondogaposis
4897 posts in 2435 days
#2 posted 07-19-2018 01:39 AM
Same here, my ambient air filter moves air just like a fan and cleans the air.
-- Bondo Gaposis
woodbutcherbynight
5488 posts in 2493 days
#3 posted 07-19-2018 01:52 AM
One of my Dad’s friends did it. This was his issue after a year of use. To many times he had it on and came in with a large piece of wood and got it tangled with the blades. So he took it out and got a pedestal fan.
View WoodES's profile
WoodES
107 posts in 1775 days
#4 posted 07-19-2018 05:10 AM
I have two in my shop. Fans only, no lights. I have learned to work around them and it makes the hot California central valley summers tolerable…
Some day I’ll need to replace the blades but I don’t have an issue with that….
View becikeja's profile
becikeja
909 posts in 2897 days
#5 posted 07-19-2018 10:21 AM
https://images-na.ssl-images-amazon.com/images/I/81hlxWMMEcL._SL1500_.jpg
I use one of these high velocity fans. Have had it for years. Typically have the shop bay door open, put this at the back and blow towards the bay door at about a 60 degree angle toward the ceiling. Keeps good air circulation throughout the shop and doesn’t stir the dust too much. Also can be moved around the shop as needed.
My opinion is that ceiling fans hang too low, and would get in the way. Also could not be moved if I needed to work in that area and did not want the air to be stirred up. Just seems like too many limitations for me.
5035 posts in 2577 days
#6 posted 07-19-2018 10:31 AM
I think in your circumstances you’re good to go, though you will have to be mindful of swinging the longer boards around.
View Redoak49's profile
Redoak49
3400 posts in 2073 days
#7 posted 07-19-2018 10:56 AM
I have a cheap one in my garage and works well.
View dhazelton's profile
dhazelton
2786 posts in 2381 days
#8 posted 07-19-2018 11:49 AM
To the first couple of posters I think his concern is that it is not an explosion proof fan. I don’t see an issue, and it’s probably more comfortable than a box fan.
View Bill White's profile
Bill White
5009 posts in 4044 days
#9 posted 07-19-2018 12:02 PM
Have 2 52” on 6” downrods. Rheostat on the wall switch to change speeds. Use ‘em summer and winter. 9’ ceilings so I don’t mash ‘em up.
-- bill@magraphics.us
View Gene Howe's profile
Gene Howe
10718 posts in 3513 days
#10 posted 07-19-2018 12:10 PM
I use one of these high velocity fans. Have had it for years. Typically have the shop bay door open, put this at the back and blow towards the bay door at about a 60 degree angle toward the ceiling. Keeps good air circulation throughout the shop and doesn t stir the dust too much. Also can be moved around the shop as needed.
- becikeja
Ditto.
View Fresch's profile (online now)
Fresch
279 posts in 2005 days
#11 posted 07-19-2018 12:56 PM
12xx16 shop have one running 24/7 I believe it cuts down on rusting.
View Tony1212's profile
Tony1212
211 posts in 1819 days
#12 posted 07-19-2018 01:11 PM
My grandfather had one in his shop as long as I can remember. But he also had a self-installed wood stove and threw away the splitter on his tablesaw. I had to duck to get under the fan.
A ceiling fan was never a consideration in my personal shop. I found a $20 window A/C unit at a garage sale. It has kept my 3 car garage at 67 degrees during Chicago’s latest run of 90+ degree days.
-- Tony, SW Chicago Suburbs
View fivecodys's profile
fivecodys
1068 posts in 1720 days
#13 posted 07-19-2018 03:53 PM
Some day I ll need to replace the blades but I don t have an issue with that….
- WoodES
Same here. I have two that were originally in the kids rooms. I removed the light kit and hung them up.
It hasn’t been a problem at all.
Yes, it does get hot in the Valley. (Madera)
I use them in conjunction with my WEN air filtration unit.
I do turn them off when applying a finishes so I don’t get dust in my finish but other than that they run all the time.
No problems to date
-- There' are two theories to arguin' with a woman. Neither one works.
WoodES
#14 posted 07-20-2018 05:53 AM
- WoodES
I’ll wave twice as I pass through Madera on Saturday, maybe create enough of a breeze to cool you off some… ;-)
It hasn t been a problem at all.
I do turn them off when applying a finishes so I don t get dust in my finish but other than that they run all the time.
No problems to date
- fivecodys
View JCamp's profile
JCamp
785 posts in 635 days
#15 posted 07-20-2018 12:34 PM
I would say they ain’t a problem but I smacked mine pretty good last night with a board. It does help keep it cool tho so I don’t think I’ll b taking it down anytime soon. A window AC sounds good but I’m to tight to pay for the electric
-- Whatsoever thy hand findeth to do, do it with all thy might
