HARDWARES - Really hard to find - Fabricate it.
Forum topic by BertFlores58 posted 07-07-2011 05:26 AM 1102 views 1 time favorited 6 replies Add to Favorites Watch
View BertFlores58's profile
BertFlores58
1698 posts in 3038 days
07-07-2011 05:26 AM
Topic tags/keywords: question hinges
These two options below are really bothering me in all my projects. Could you give some tips as to what is the best way so I could decide immediately? I have 40 boxes on the way but still I cannot decide what hinges should be used.
1. Where are you getting your hardwares… hinges, latches, handles? Would it be cheaper?
2. Why not make it yourself? Another difficult adventure than buying it? But would it be stronger? How will I do it. I know some of the LJ made a successful attemps on this … but again… can I do it?
-- Bert
View shipwright's profile
shipwright
8062 posts in 2914 days
#1 posted 07-07-2011 05:31 AM
Hi Bert,
Did you see this blog? http://lumberjocks.com/shipwright/blog/23989
View lew's profile
lew
12262 posts in 3871 days
#2 posted 07-07-2011 07:02 AM
You can’t go wrong with these folks-
http://www.cshardware.com/
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3223 days
#3 posted 07-07-2011 07:53 AM
Bert with your talent and innovative mind, you have this beat before you begin. What is the access in Manila for some 1/8” brass rod?
View David Grimes's profile
David Grimes
2078 posts in 2756 days
#4 posted 07-07-2011 08:14 AM
Good link, lew. Thanks
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
BertFlores58
#5 posted 07-07-2011 09:42 AM
Paul, I review back your blog and so with Martyn. I am dealing with 1/4 inch and less thickness of wood. If I use 1/8”, have only 1/16 (2mm) on each side to hold the 1/8 pin… Somewhat weak. Probably ebony can hold. I will try doing it on 3/8 thickness then slowly plane it to the thickness of 1/4… think it will help.
Rand, 1/8” brass rod is available here but you have to buy it as WELDING ROD for oxy-acetylene welding. It is much easier to buy stainless rod than brass.
To give further idea on how I will fit the hinges and latches… here is the photo of 6” x 6” x 2”depth box where I just fitted ordinary hinges. Maybe you can suggest how I will get along with this.
This is the photo of the box without the lid…
-- Bert
lilredweldingrod
#6 posted 07-07-2011 06:20 PM
Bert. Our suppliers of welding supplies carry stainless rod for TIG welding that is just at or less than 1/16”. Maybe this would work in place of the brass rod which is usually much thicker. Then this brings up the accessibility of the small drills needed. These need to be as long as you can find. I’ll look over here and see if there are any around 3 to 6 inches long.
