Wonder Dogs / Pups
Forum topic by WayneC posted 07-07-2011 03:14 AM 4761 views 0 times favorited 18 replies Add to Favorites Watch
View WayneC's profile
WayneC
13754 posts in 4091 days
07-07-2011 03:14 AM
Topic tags/keywords: jig carving tool carving traditional wonder pup wonder dog
Anyone have a recommendation for hole spacing to effectively using these. I’m making a carving jig and I am trying to decide if I will use a 3” or a 4” grid. I will be using a pair of wonder pups and a fence system similar to a bench hook.
http://www.leevalley.com/US/wood/page.aspx?p=31129&cat=1,41637,41645&ap=1
Top view and side view. Yellow circles are the dog holes. Dark blue if the fence.
I looked in the instructions and did not see any recommendations. Though there are a number of interesting ideas for using them in the instructions that I had not thought of…
18 replies so far
View RGtools's profile
RGtools
3372 posts in 2648 days
#1 posted 07-07-2011 05:19 AM
The closer the better. trust me on this. Less time turning screws more time carving.
-- Make furniture that lasts as long as the tree - Ryan
WayneC
#2 posted 07-07-2011 05:48 AM
RG, do you think closer than 3”?
View Tony's profile
Tony
986 posts in 4024 days
#3 posted 07-07-2011 08:35 AM
A lot depends upon the work pieces that are going to be held. If they are regular shapes, square or rectangular, then you can use a larger spacing, if you are going to have irregular shapes, then a smaller spacing is useful. I would have thought that 2 1/2” spacing, although more work (holes), would give you the maximum flexibility.
You are only going to make one of these – it should last you a very, very long time.
As for adjusting the wonder dogs quickly, just spin then like a “Football Rattle” – I do not think it will work on the “Pups” though, not enough mass.
View racerglen's profile
racerglen
3112 posts in 2774 days
#4 posted 07-07-2011 02:32 PM
Yup, the Pups spin just fine.. Wayne I’m not doing carving, but one thing with the dogs n’ pups and such on my bench is to use spacers. My dog holes are about 8 inches apart mostly, the ones running on the short side of the bench are closer. When I’m clamping smaller items, it’s a quick reach to the bottom shelf on my bench for a spacer or wedge
to fill the gap.
-- Glen, B.C. Canada
RGtools
#5 posted 07-07-2011 03:20 PM
3” grid would do just fine.
View bdjohns1's profile
bdjohns1
43 posts in 2686 days
#6 posted 07-14-2011 04:14 PM
There’s a pretty clever bench hook design in one of the recent PWW issues (June, IIRC). I just bought the materials to make one, and it’s designed around 2.5” spacing for the Pups.
-- Ben - resident cheese whiz.
WayneC
#7 posted 07-14-2011 04:39 PM
I will have to check out the PWW issue. I went ahead and layed it out with 3” spacing. I think it will be fine. I’m trying to decide if I want to drill it by hand or use the drill press. Currently access to the drill press is difficult.
View IrishWoodworker's profile
IrishWoodworker
159 posts in 4072 days
#8 posted 07-14-2011 04:49 PM
You can make a base with wider holes and then make a smaller base that fits on the first one with smaller holes. Kind of like a bench on a bench theory. I have thought of making one like this I just need to get around to it.
-- Dont just dream it, get up and live it!
WayneC
#9 posted 07-14-2011 04:54 PM
The pups are pretty versatile. I can see the ability to do a lot with them. The ability to screw stuff to them is interesting as well. I will probably post a review when I get finished with my carving fixture.
View Bertha's profile
Bertha
13525 posts in 2687 days
#10 posted 07-14-2011 04:56 PM
I like newplane’s idea. I’ve made a few of these jigs to drop into my limited dogholes. I resorted to sticking the dogs in the holes, laying the jig on top, and blasting away with a brad nailer, generally aiming for the dog.
View MedicKen's profile
MedicKen
1615 posts in 3456 days
#11 posted 07-29-2011 03:52 PM
Why not try a couple of different spacings on some scrap first? Go with 3, 4 or even 5” and see what works. You might find 2 1/2 to be optimum
WayneC
#12 posted 07-29-2011 03:55 PM
I went with 3” after looking around some think it is going to work fine. I have drill a few pocket holes and do some sanding…
View Mike R.'s profile
Mike R.
209 posts in 2639 days
#13 posted 08-07-2011 07:49 PM
wayne c , let me know how it turns out i plan on making one for using on my ship while im deployed.
WayneC
#14 posted 08-07-2011 07:58 PM
It worked out pretty well at 3”
View DamnYankee's profile
DamnYankee
3301 posts in 2556 days
#15 posted 09-11-2011 07:51 AM
I have them and I made my holes 3” (about half the total travel distance on the dogs/pups). You want the holes less than the travel distance or you risk having to use spacers on some projects. I also found anything less than the 3” ran into being too close sometimes.
-- Shameless - Winner of two Stumpy Nubs Awards
