Maple Tearout
Forum topic by Kevin posted 07-07-2011 02:29 AM 3053 views 0 times favorited 12 replies Add to Favorites Watch
View Kevin's profile
Kevin
462 posts in 3168 days
07-07-2011 02:29 AM
Topic tags/keywords: maple wood joint plane
Hi,
Just wondering if my knives on my jointer and planer need sharpened or not. I am getting some slight grain tearout looks like when jointing the maple. First time i’ve used rough cut maple. I bought somewhere between 40-45 BF of maple over the weekend. I got to pick out what I wanted, 6 boards for $20 bucks so they were all 5/4×8” wide and 9-11 feet long.
Even going at a slower feed I still get some very little knicks in it. The tearout isn’t huge or anything, but it’s the size of a beebee or similar. It’s just annoying to know it’s not smooth :)
Thanks,
Kevin
-- Williamsburg, KY
12 replies so far
10246 posts in 3611 days
#1 posted 07-07-2011 02:43 AM
Maple does that. You can try dampening the surfaces with water
immediately before running through the planer – sometimes that
helps control tearout as it makes the surface fibers more flexible
or something.
The really committed solution is to put a 5 degree back-bevel on your
planer knives. It’s called double-bevel sharpening.
Kevin
#2 posted 07-07-2011 02:52 AM
Thanks Loren,
Like I said it’s not really that big of tearouts, but being so darn picky like I am it’s annoying to say the least. I will try the dampening you suggested first as I mainly mill walnut and cherry right now. Not getting that silky smooth effect after jointing or planing was a little depressing, lol.
Kevin
-- Williamsburg, KY
View MedicKen's profile
MedicKen
1612 posts in 3425 days
#3 posted 07-07-2011 03:53 AM
Loren is right…..Maple is notorious for tearing. Another trick, very light cuts and be sure of the grain direction. Also, you might try running the board at a slight angle through the planer, it is kinda like canting a hand plane to make it cut easier
Kevin
#4 posted 07-07-2011 04:02 AM
I think i’ve got my jointer at 1/32” right now, but my planer takes off more though, probably 1/16 on each pass. I’ve looked at the grain direction, but from what I can see it’s pretty much going down the middle, at least on the boards i’ve done so far. There isn’t any sloping from one end to the other.
Thanks,
Kevin
-- Williamsburg, KY
View closetguy's profile
closetguy
744 posts in 3855 days
#5 posted 07-07-2011 05:13 AM
Try turning the board around. You may be running the wrong grain direction.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View fussy's profile
fussy
980 posts in 3014 days
#6 posted 07-09-2011 05:43 AM
As Loren says, wet the boards and take LIGHT cuts. Also, is your planer hooked up to a dc? I found that sometimes chips not evacuated could cause slight tearout or divots. Mostly went away when I turned on the dc. Maple is a wooley-booger, but it’s worth it.
Steve
Kevin
#7 posted 07-09-2011 08:12 PM
Update:
I tried turning the board around, but didn’t really make a difference. The planer isn’t hooked up to a DC, but after cleaning the planer and jointer free from chips and wetting the boards slightly the problems are gone.
Thanks to everyone !
Kevin
PS: Just noticed Steve you are only about 60 north of me.
-- Williamsburg, KY
View NBeener's profile
NBeener
4816 posts in 3137 days
#8 posted 07-09-2011 08:24 PM
Yup. Loren’s right.
Aside from being SURE your blades are sharp … that’s one reason people change out the knives for helical cutter heads
-- -- Neil
Kevin
#9 posted 07-10-2011 11:14 PM
Yep Neil,
If I had the funds I would opt for those. Right now i’m making 30k less than I did a couple of years ago so the money is a little tighter these days :(
Next on my list is a DC, man I gotta get one of those soon :) Gonna have to find a good one that will be good for a Jointer, planer and TS. I will prob have blast gates and only use one machine with the DC at a time since it’s just me in my shop.
Peace,
Kevin
-- Williamsburg, KY
View blackcherry's profile
blackcherry
3337 posts in 3786 days
#10 posted 07-11-2011 01:09 AM
Loren recommended water the surface slightly, I use denature alcohol it work wonder on tiger maple and birdseye maple as well…hope this helps…Blkcherry
View rwachtell's profile
rwachtell
6 posts in 2444 days
#11 posted 08-13-2011 05:49 AM
I have planed a lot of curly maple both hard and soft. Curl rips easily especially the hard. The water trick works well for me and I use it often. However this summer I planed some wood on a very very humid day without wetting the wood and I had very little rip out in that batch. Now I’m curious about whether wood will plane with less rip out in humid weather. If anyone has any thoughts or experience with this situation please tell me about it.
Robert Wachtell
Weston CT
Kevin
#12 posted 08-14-2011 04:23 AM
I used some more of my maple yesterday and used the water technique. Came out extremely smooth. It’s been really hot the past two months here in KY that it’s pretty much unbearable to try and do anything outside.
On another side note I found at the local flea market today a guy selling A LOT of different sizes raised panel doors that are solid maple for 4-8 bucks per door. They are unfinished, but hey I can’t even build them for that. He gets them from a cabinet shop so my guess is they are seconds or something else, but they are nice to say the least.
Kevin
-- Williamsburg, KY
