Router Bits - why three sizes
Forum topic by hjt posted 07-17-2018 12:31 AM 508 views 0 times favorited 13 replies Add to Favorites Watch
View hjt's profile
hjt
896 posts in 3221 days
07-17-2018 12:31 AM
Topic tags/keywords: router bits trim bits
I’m sure there is a reason, and I have my suspicion, but that may not be correct – like the days I married this woman and thought it would be marital bliss!!! That turned out wrong too. But I digress.
All three of these router bits seem to be trim bits, but why three sizes – why would I choose one over the other?
Also, riddle me this – I used the middle sized bit to trim off the little over hang I had when gluing on a piece of what I’ll call “white board” on the face of a shelf. Darn of the bit did not take off a little of the shelve surface too. I guess my hand held trim router was not exactly 90 degrees to the surface. Would you concur?
-- Harold
13 replies so far
View shipwright's profile
shipwright
8031 posts in 2881 days
#1 posted 07-17-2018 01:28 AM
Larger bit, higher cutter speed, smoother cut.
Smaller bit, fits sharper corners.
Good bits are very accurate ….. not so good bits ….. not so much.
Any tool is only as good as the hands that hold it.
View wuddoc's profile
wuddoc
297 posts in 3801 days
#2 posted 07-17-2018 01:31 AM
hjt
There are most likely several reasons regarding the different diameters if you talk with a tooling rep.
I am aware of two.
Pro: The smaller diameter allows you to get closer in an internal corner cut.
Con: Small diameter cutter and shaft have increased deflection and vibration.
-- Wuddoc
View Desert_Woodworker's profile
Desert_Woodworker
1534 posts in 1297 days
#3 posted 07-17-2018 01:32 AM
- shipwright
+1
-- Desert_Woodworker
View alittleoff's profile
alittleoff
541 posts in 1359 days
#4 posted 07-17-2018 01:46 AM
Yep.
A.L.Off
View Rich's profile
Rich
3341 posts in 672 days
#5 posted 07-17-2018 01:49 AM
As mentioned, the smaller bit is good for tighter radiuses. On larger bits, the larger radius reduces the angle at which the blade engages the wood, thereby reducing tear out. That’s why shapers cut so smoothly compared to router bits in general.
View hjt's profile
hjt
#6 posted 07-17-2018 02:07 AM
Thanks fellas
-- Harold
Desert_Woodworker
#7 posted 07-17-2018 02:55 AM
As mentioned, the smaller bit is good for tighter radiuses. On larger bits, the larger radius reduces the angle at which the blade engages the wood, thereby reducing tear out. That s why shapers cut so smoothly compared to router bits in general.
- Rich
+1 I love the closing “why shapers cut so smoothly compared to router bits ” Smooth exit my friend. :)
View BurlyBob's profile
BurlyBob
5827 posts in 2348 days
#8 posted 07-17-2018 03:09 AM
shipwright +3. Also I’ve found that Whiteside router bits are the best value out there.
View BroncoBrian's profile
BroncoBrian
702 posts in 2041 days
#9 posted 07-17-2018 03:20 AM
shipwright +3. Also I ve found that Whiteside router bits are the best value out there.
- BurlyBob
Yep – they make a bit for everything. Great value. Whiteside is all I buy.
-- My fake plants died because I did not pretend to water them.
View hjt's profile
hjt
#10 posted 07-17-2018 03:38 AM
Bronco, having never heard of Whiteside, I went to google, and as I began to type it in the search, up came router bits. https://www.whitesiderouterbits.com/ Neat company! The video of how they produce the bits was impressive – https://player.vimeo.com/video/42220700.
So should I assume your are a Denver Bronco fan??
-- Harold
View Rick S.'s profile
Rick S.
10135 posts in 3115 days
#11 posted 07-17-2018 08:41 AM
- shipwright
BINGO! On The Money Shipwright!
Rick
-- If it wasn't for Electricity, We'd all be Watching Television by Candlelight!
View Woodwrecker's profile
Woodwrecker
4166 posts in 3658 days
#12 posted 07-17-2018 03:45 PM
Whiteside bits are the best to use in my book.
But any bit you have is the best bit to have Harold…lol
View hjt's profile
hjt
#13 posted 07-17-2018 04:16 PM
Roger that, WoodWrecker!!
-- Harold
