| Forum topic by grego | posted 712 days ago | 1275 views | 0 times favorited | 10 replies | ![]() |
712 days ago |
Topic tags/keywords: box marquetry I’d appreciate any and all tips for incorporating marquetry in small box lids. In particular, how do you hide and protect the veneer edges? I see many lovely examples on this site. |
10 replies so far
#1 posted 712 days ago |
This is a pretty simple box http://lumberjocks.com/projects/50187. All I did here was leave a recess in the top frame and drop the top panel in with some hide glue. The panel is 1/4” MDF. Everything was finished first and the excess hide glue was “rubbed” off when it gelled. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#2 posted 712 days ago |
Paul, that’s exactly what I was looking for – thanks! |
#3 posted 712 days ago |
Cr1 – thanks! Actually I’ve already got the used woodwork book bug, and have a pile from Thrift Books. Unfortunately none I have so far (and I have a couple of marquetry books) address this specific question. |
#4 posted 712 days ago |
You can also miter the corners and match the grain if you want to get fancy. These are veneer over MDF as well. Yes, that’s what I love about MDF. Also it’s absolutely flat. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#5 posted 709 days ago |
Greg, there are a number of techniques that are practical for incorporating marquetry work into box construction. Yes, floating panels in grooves is one way of doing it, this has the advantage of allowing you to work on a flat piece and easily press the work. You can also do work on both sides in this way. Another way would be to have a solid piece and press the marquetry directly to the outside of the box. You can glue up the marquetry on a flat substrate first, and then cut out your box parts after your panel is dry. Hope that helps! -- You either think you can, or think you can't. Either way you are right. Henry Ford |
#6 posted 707 days ago |
Thanks Matthew. It seems to me that an advantage of the floating panel approach is that the edges of the veneer are hidden from view, and also protected from being damaged. Is this valid? Or is the veneer so thin and tightly bonded that these aren’t a concern for your second approach? |
#7 posted 707 days ago |
By the way, I’m having trouble finding 1/4” MDF – is this a rarity? Perhaps 1/4” BB plywood would be a reasonable alternative… |
#8 posted 705 days ago |
Hi Greg, 1/4” MDF is easy to find here in BC but my supplier calls it “Rangerboard”. Trade name I guess. I find it at my regular building supply (RONA) and they are not known for their wide range of products. To answer another of your questions, yes your veneer / substrate joint should be good enough that it is as strong and damage resistant as any other piece. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#9 posted 705 days ago |
Grego, if you are looking to learn more about marquetry and parquetry here is a good site with a lot of information. Hope it helps. Richard www.marquetrysociety.ca |
#10 posted 704 days ago |
Richard and Paul – thank you both. Lots of food for thought! |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
