Jet 6" Jointer Issue
Forum topic by BryanFaz posted 07-15-2018 06:45 PM 355 views 0 times favorited 6 replies Add to Favorites Watch
View BryanFaz's profile
BryanFaz
58 posts in 644 days
07-15-2018 06:45 PM
Topic tags/keywords: jointer infeed table
Has anyone ever had a problem raising the infeed table on a Jet Jointer (model JJ-6CSX)? I’m checking to see if infeed and outfeed tables are parallel. It needs less than an 1/8” to move…but it won’t budge.
Thanks!
BryanFaz
#1 posted 07-15-2018 07:20 PM
I should have provided a few details. The adjustment wheel will not turn. I have removed it and I’m’ using a wrench to turn the shaft but it is not moving easily. I have just greased the threads of the adjustment shaft. Hopefully that will help. It has almost moved up to the outfeed table height. I can’t figure out what is causing it to move like its in a bind. We’ll see how the grease does.
View Rich's profile
Rich
3650 posts in 733 days
#2 posted 07-15-2018 07:27 PM
Did you pull the knob in back that pops in when it gets dropped to more than 1/8” cut depth? At least my Jet JJ6 has one and it will block the infeed from coming back up.
BryanFaz
#3 posted 07-16-2018 02:29 AM
Hi Rich! I attempted to…but am not sure it came out. I read about it…it’s a depth stop i believe. I probably should have paid more attention to it. I bet that’s what was restricting it.
Thanks a bunch for commenting!!!
View Rich's profile
Rich
#4 posted 07-16-2018 03:10 AM
You’ll need to lower the infeed a bit. It sounds like you were cranking the handle pretty hard and that will pin it. Turn the handle to the right a bit and then pull the knob in back with the round head. Also, you’ll have to keep pulling on it while you crank the wheel left.
BryanFaz
#5 posted 07-16-2018 11:59 AM
Thanks again Rich. I’ll let you know how it goes.
BryanFaz
#6 posted 07-17-2018 11:57 AM
Rich you were spot on. I now understand what you meant by pinned. I couldn’t pull that knob/pin out initially so I ignored it not realizing what I was doing. i loosed those three screws on the back that the knob was attached to and it came loose. Now the wheel is moving freely.
Thank you so much for your diagnosis and cure!!!!!!
