How to adjust LARGE cabinet doors
Forum topic by marlis321 posted 07-14-2018 06:41 PM 474 views 0 times favorited 6 replies Add to Favorites Watch
View marlis321's profile
marlis321
6 posts in 3594 days
07-14-2018 06:41 PM
Topic tags/keywords: question
Recently purchased a large Armoire type freestanding cabinet at an estate sale. Solid oak, great deal. BUT, the doors are crooked to the case/frame. Any suggestions on how to adjust these doors? Or square the frame? I can’t see any adjusting mechanisms on the hinges.
View LesB's profile
LesB
1913 posts in 3677 days
#1 posted 07-14-2018 08:05 PM
If I’m understanding the adjustments you are wanting to make I would suggest you try adding shims under the hinges. Thin strips of wood or cardboard material.
-- Les B, Oregon
View 000's profile
000
2859 posts in 1134 days
#2 posted 07-14-2018 08:16 PM
I don’t think the doors need to be adjusted.
I think the cabinet is twisted/racked.
Grab the cabinet at the top and twist it to the right and then to the left while watching the gap at the top of the doors. If it gets better, which ever way you twist it, that is the problem.
You could probably put some shims under the correct corner of the cabinet to rack the cabinet back into square.
View Aj2's profile
Aj2
1943 posts in 2032 days
#3 posted 07-14-2018 08:19 PM
Before you mess with the hinges lift up on the corner.
The side that has a sagging door the piece looks twisted
Uneven floor?
-- Aj
View CharlesNeil's profile
CharlesNeil
2468 posts in 4105 days
#4 posted 07-14-2018 08:28 PM
jbay nailed it , as well as Aj2
shim the feet on the cabinet , it will come in
make a wedge , and tap it under the foot until its fitting , this will then tell you the thickness of the spacer you need
View JCamp's profile
JCamp
891 posts in 785 days
#5 posted 07-14-2018 08:34 PM
To me it looks like the seam between the doors is even. If that is the case either the doors are fine or twisted in the same way. To me it looks like the door on the right needs raised up a bit cause it’s lower than the left door. In that case losses the screw in the hidges on the cabinet itself and try to raise the door and retighten the screws
-- Whatsoever thy hand findeth to do, do it with all thy might
woodbutcherbynight
5824 posts in 2643 days
#6 posted 07-15-2018 01:20 AM
My grandmother had a cabinet that sat on a uneven floor for 40 years. Same thing, twisted cabinet.
