Table Saw Blade Speed?
Forum topic by MontanaSoftware posted 07-14-2018 02:36 PM 417 views 0 times favorited 9 replies Add to Favorites Watch
View MontanaSoftware's profile
MontanaSoftware
1 post in 36 days
07-14-2018 02:36 PM
Topic tags/keywords: question tablesaw
Hi Folks:
I’m restoring an old Craftsman 113 table saw (yes … I know I can’t turn a pig into a racehorse … but I can make a fast pig!!)
I’m replacing the 1.5HP motor with a 3HP motor, and adding machined steel pulleys and a link belt. I’ve also made PALS-style adjuster brackets for the trunions, and am making an adjustment tool with a dial indicator.
My question is … what speed should I run the blade? The motor is 240 volts, 15 amps, and spins at 3450 RPM. I have several options for pulley sizes, and can pretty much spin the blade at any speed I choose.
What speed do you recommend?
Thanks!
PS: This is my first post on this forum … is there a way to “subscribe” to this topic and receive an email notification every time it gets a response?
9 replies so far
View Don Broussard's profile
Don Broussard
3627 posts in 2336 days
#1 posted 07-14-2018 02:43 PM
Montana—I had a similar saw that ran at 3450 rpm from the factory, so I think that’s the right speed. As for the subscription, since it’s your topic, you will have the title of your post in the Pulse in bold every time a new post is added. You’ll have to edit your e-mail notifications from your profile page to be alerted via e-mail.
-- People say I hammer like lightning. It's not that I'm fast -- it's that I never hit the same place twice!
View jbay's profile (online now)
jbay
2492 posts in 983 days
#2 posted 07-14-2018 02:49 PM
View knotscott's profile
knotscott
8102 posts in 3460 days
#3 posted 07-14-2018 03:43 PM
I agree with Don….factory speed of around 3450 is best.
View jonah's profile
jonah
1820 posts in 3383 days
#4 posted 07-14-2018 06:56 PM
The manual will probably have the rotational speed of the blade. I suspect it’ll be somewhere around 6000rpm.
View ArtMann's profile
ArtMann
1009 posts in 900 days
#5 posted 07-15-2018 07:51 PM
Don’t get carried away with feed speed. The motor may be able to handle it but not the trunion. It was designed for a weaker motor and the bearings or even the cast iron may fail if used like a cabinet saw.
View johnstoneb's profile (online now)
johnstoneb
2994 posts in 2257 days
#6 posted 07-15-2018 10:08 PM
Pulleys on the 113 are 1:1 so its about 3450.
-- Bruce, Boise, ID
woodbutcherbynight
5488 posts in 2493 days
#7 posted 07-16-2018 01:52 AM
A word of advice, stick to whatever the manufacture recommended for blade speed. Bad things happen when you tinker. Just saying….
LOL
View uptoolateman's profile
uptoolateman
36 posts in 155 days
#8 posted 07-16-2018 02:12 AM
If you install the machined pulley’s from inline industries it bumps the blade speed up to 3833 rpm using a 3450 rpm motor. The motor pulley in the kit is 2 1/2” and the blade pulley is 2 1/4”. I guess you could install them the other way around and get 3105 rpm, but I don’t know why you would want to slow the blade down.
View dschlic1's profile
dschlic1
440 posts in 2054 days
#9 posted 07-16-2018 05:27 PM
I have a 113 table saw with (I believe) original pulleys. The pulley on the arbor is slightly smaller than the pulley on the motor. Because of this the blade spins at a slightly higher speed than the motor.
