Wood magazine chamfer plane
« back to Hand Tools forum
Forum topic by Simons44 posted 686 days ago 1299 views 0 times favorited 5 replies Add to Favorites Watch
View Simons44's profile
Simons44
85 posts in 1592 days
686 days ago
I would like to build the chamfer plane featured in woo magazine #162 from April/May 2005. The article points to a source that no longer sells the plane blade. Does anyone have recommendations on where to purchase the blade? The blade size is: 1/16 thick, 1×1 7/8”
I googled it but haven’t had any luck finding one.
thanks,
Jeremy
5 replies so far
View KayBee's profile
KayBee
896 posts in 1415 days
#1 posted 686 days ago
Here’s one for you to consider. Look at the replacement blade, pretty reasonable cost too.
www.leevalley.com/US/wood/page.aspx?p=41197&cat=1,41182
-- Karen - a little bit of stupid goes a long way
View WayneC's profile
WayneC
9596 posts in 2266 days
#2 posted 685 days ago
The one Karen suggested looks good. Is the 1” dimension width?
Perhaps one of the clearance blades from woodcraft. I did not see any measurements on the woodcraft site.
http://www.woodcraft.com/Product/2080170/26542/Pinnacle--Replacement-Plane-Blades-for-Veritas-Chair-Makers-Scraper-Straight-Blade-HCS.aspx
Simons44
#3 posted 684 days ago
Thank you Kay and Wayne
View SCOTSMAN's profile
SCOTSMAN
4309 posts in 1754 days
#4 posted 684 days ago
You could mille one from hss steel high speed steel or an old chisel or another plane blade could be perhaps milled if you had a milling machine. Alistair
View Loren's profile
4880 posts in 1816 days
#5 posted 684 days ago
Or you could just modify the plane to fit whatever iron you can
get easily. That’s what I’d do. I’ve made several specialty planes
just sizing the designs to Stanley block plane irons and grinding
the iron to the profile, if necessary.
