Coat rack hooks and their long screws
Forum topic by Dchip posted 07-05-2011 05:07 PM 4571 views 0 times favorited 13 replies Add to Favorites Watch
View Dchip's profile
Dchip
271 posts in 3454 days
07-05-2011 05:07 PM
Topic tags/keywords: question
Every hook I’ve ever seen for a coat/hat rack comes with screws that are probably 1.5’’. This makes it difficult if you plan to fix these hooks into 3/4 material. I’m probably gonna double up the wood where the hooks are mounted even though this may give a heavier look than I originally wanted. I understand that the length of the screw is probably for reaching through drywall if you were to screw these directly to a stud, but does anyone have any clever solutions for this issue short of cutting every screw or buying new ones? Any input is appreciated.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
13 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 3052 days
#1 posted 07-08-2011 06:38 AM
Buy new. They’ll cost less than doubling the material (and harpooning your design).
Kindly,
View MrRon's profile
MrRon
5193 posts in 3445 days
#2 posted 07-08-2011 06:39 PM
This is a good example of good design vs traditional design. The original pattern was made for attaching to solid wood walls, maybe 200+ years ago. They have been made the same ever since; why? because that’s the way it has always been done. The screw holes are usually spaced 1-1/4” to 1-1/2” apart which means only one screw will line up with a wood stud. The way around it is to mount the hooks on a piece of wood which in turn can be mounted to the wall. I know you know this, but I thought I would explain why it is so. Apparently there is not much interest in re-inventing the wheel, but there are many items of “traditional design” that need to be brought up to date.
View Tomoose's profile
Tomoose
422 posts in 3575 days
#3 posted 07-08-2011 07:39 PM
In similar circumstances I have “pre-tapped” the long screws into the wood to about the desired depth. I then back them out, cut to length, and then re-insert and tighten. Once the hole is mostly formed the screw tip isn’t really needed anymore. Maybe there are some engineer guys who will tell me I shouldn’t do this for a reason I have not considered, but it has worked for me in the past.
Good luck and have fun
Tom
-- “I am always doing that which I cannot do, in order that I may learn how to do it.” Pablo Picasso
Dchip
#4 posted 07-08-2011 09:27 PM
Thanks for the input all. I’ll probably give a look for some similar looking screws, and if not, dig up the hacksaw.
MrRon
#5 posted 07-09-2011 05:35 PM
This is really a no brainer; get shorter screws.
View gfadvm's profile
gfadvm
14940 posts in 2892 days
#6 posted 07-10-2011 03:08 AM
Small bolt cutters are WAY faster than hacksawing!
View Stuey's profile
Stuey
43 posts in 3159 days
#7 posted 07-10-2011 06:10 AM
I usually swap in 3/4” screws. When using such a hook with shortened screws, I once had the hook pull out since I didn’t hit a stud. A bit of gorilla glue fixed everything.
I wouldn’t bust out the hacksaw, although bolt cutters are a bad idea. They’ll crush the screw a little, possibly deforming it, which could lead to an oversized hole. Oversized hole + short screws can only lead to headaches.
I would just get shorter screws. Besides, you could probably use them for another project down the road anyways, right?
-- http://toolguyd.com
Dchip
#8 posted 07-11-2011 02:31 PM
I agree that shorter screws would be the best solution, but matching the color and size will be difficult.
View justahobby's profile
justahobby
19 posts in 2779 days
#9 posted 07-14-2011 03:18 PM
I recently put together several coat hook racks from reclaimed and new hooks. Since all were based on 3/4” stock, I took a scrap and drilled a grid of counter-sunk pilot holes, drove in the screws and put the board upside down in a vise. An angle grinder made short work of 24 screws.
Lee Barker
#10 posted 07-14-2011 05:50 PM
What’s the color? Sharpie, fingernail polish, paint…
Kindly,
View ClayandNancy's profile
ClayandNancy
520 posts in 3217 days
#11 posted 07-14-2011 05:55 PM
It’s a little work but if your attaching hooks to a board that will be mounted on the wall, you could use t-nuts and a machine screw. Of course the screw would have to match or like Lee Barker said.
Dchip
#12 posted 07-19-2011 02:23 PM
Thanks everyone. Looks like a good excuse to start checking out some angle grinders…
Stuey
#13 posted 07-19-2011 02:30 PM
I may be missing something here, but if you cut/grind the screws down to size, how will they pierce the stud and cut a thread into it? Large pilot hole?
Ordering color-matched screws of the right size will be far cheaper and easier than buying an angle grinder and cutting what you have down to size.
If you’re having too much difficult color-matching, maybe try going for a contrasting look.
