Built in bookcase design
Forum topic by nubbin00 posted 07-12-2018 03:09 PM 423 views 0 times favorited 8 replies Add to Favorites Watch
View nubbin00's profile
nubbin00
26 posts in 2429 days
07-12-2018 03:09 PM
Topic tags/keywords: question tip
So I’m trying to finalize the design for a built in bookcase, specifically regarding what to do with baseboards. I plan on building a base for the unit from 2x material for the bookcase to sit on but my baseboards are approximately 8.5” tall. Should I remove the baseboards and use 2×4 for the base or should I build the base as tall as the baseboards?
-- Nothing is foolproof to a sufficiently talented fool.
8 replies so far
View pintodeluxe's profile
pintodeluxe
5783 posts in 2987 days
#1 posted 07-12-2018 04:00 PM
A sketch would help us understand the proportions. 8” baseboards sounds a little too tall.
With built-ins like bookcases or wainscoting, I try to build the baseboards separately so I can account for uneven floors etc. I usually make baseboards 4-6” high.
nubbin00
#2 posted 07-12-2018 04:39 PM
This is the wall where the units will be installed. 35.5” on the left, 38.5” on the right. There will be a connecting shelf over the window and a smaller shelf beneath the window which I might make into a window seat.
nubbin00
#3 posted 07-12-2018 04:41 PM
The baseboards are actually 7.5” tall
View RobHannon's profile
RobHannon
165 posts in 705 days
#4 posted 07-12-2018 05:05 PM
My house has 12” baseboards, done to cover where old baseboard water heater boarded each room, and I have done both cutting out the baseboard and cutting the cabinet around the baseboard. Cutting the baseboard to accept the cabinet or built-in looks considerably better in my opinion. A 8” tall base will look a little off I think, but you could design around it with a drawer. Cutting the baseboard would be less work.
pintodeluxe
#5 posted 07-12-2018 05:19 PM
Oh, I see, you’re matching existing baseboard height. I think that’s fine.
1+ on the window bench idea! That would be great, especially with a custom cushion.
View BFamous's profile
BFamous
174 posts in 295 days
#6 posted 07-13-2018 01:24 AM
I’d probably out to match the baseboard height on my built-in if there is exposed baseboard on the adjoining walls. If your unit is covering the entire length gth of the wall AND there isn’t a lot of exposed baseboard on the adjoining walls I think you could aesthetically get away with doing shorter.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View jbay's profile (online now)
jbay
2748 posts in 1073 days
#7 posted 07-13-2018 02:30 AM
If your new units will be from wall to wall,
I would cut back the existing base and butt it into the face of the new cabinets.
Then I would run a smaller base across the front of the new cabinets and have it butt into the existing base.
Like so:
-- “Hanging onto resentment, is letting someone you despise live rent-free in your head.” (Ann Landers)......
woodbutcherbynight
5597 posts in 2583 days
#8 posted 07-13-2018 03:47 AM
Like so:
- jbay
My Grandfather taught me that trick, a long time ago. Called it seaming. As best I remember anyway.
