Help please - Painting six board chest question
Forum topic by simoncpj posted 07-12-2018 03:00 PM 323 views 0 times favorited 6 replies Add to Favorites Watch
View simoncpj's profile
simoncpj
23 posts in 629 days
07-12-2018 03:00 PM
I am making a mini six board chest and plan to use traditional cut nails and no glue to hold it together. I would like to paint the exterior with milk paint.
How would you suggest I do this without leaving paint on the cut nail heads?
Pre-finish prior to nailing together
Try to paint around the nail heads
Paint over and try to wipe while wet
Thanks for the benefit of your collective experience
View Lazyman's profile
Lazyman
2386 posts in 1504 days
#1 posted 07-12-2018 03:05 PM
If you can put some wax on the nail heads without getting it on the surrounding wood, it would be easier to get the paint off afterwards (wet or dry). Or better yet, especially since you are not going to glue it together, paint it before assembly.
View John Smith's profile
John Smith
1309 posts in 280 days
#2 posted 07-12-2018 03:27 PM
do you have any concerns about the cut nails rusting ?
or would that just add character to the project.
if there was no glue involved, I think I would assemble the whole box
with the nails left out maybe a 1/4” or so, paint the box as desired,
then come back after you are satisfied with the paint job and set the nails.
you could grind down a bolt to the profile of the nail head to set the nails
without leaving hammer marks. or – if you wanted the heads dead flush with
the wood, use a large flat bench chisel on the nail head and gently tap it in.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View bondogaposis's profile
bondogaposis
4926 posts in 2468 days
#3 posted 07-12-2018 04:56 PM
Paint the boards first then assemble.
-- Bondo Gaposis
View LittleShaver's profile
LittleShaver
361 posts in 736 days
#4 posted 07-12-2018 05:54 PM
I like John’s suggestion. Since your nails sound like a feature, you might want to do a careful layout to get consistency and symmetry.
-- Sawdust Maker
View ColonelTravis's profile
ColonelTravis
1876 posts in 2011 days
#5 posted 07-12-2018 06:09 PM
I learned this technique for smaller brad nails on molding, it may or may not be feasible in your case, but get a tiny gouge, dig into the wood a little, lift up a flap (don’t tear it off), put a nail in the depression that you gouged, hammer it in, put glue on the flap, rest it back down to cover the nail head, then put some masking tape to keep the flap down while the glue dries. You’ll never know a nail was there. I’m doing that with 1 1/2” cut nails on one board on a desk build I’m about finished with. I don’t want to use pocket screws and I don’t want nail heads to show on this board. Also doing it with brad nails on the trim molding.
simoncpj
#6 posted 07-12-2018 07:59 PM
Thanks Gents, I appreciate the wisdom. Likely will see what I can pre-finish then try leaving the nail heads proud for the touch up.
