Truck Bed Finish 1949 Ford
Forum topic by milbert posted 07-05-2011 06:40 AM 6504 views 0 times favorited 9 replies Add to Favorites Watch
View milbert's profile
milbert
21 posts in 3165 days
07-05-2011 06:40 AM
Topic tags/keywords: question oak finishing
I am nearly finished restoring a 1949 Ford F-1 truck with my Dad. We are doing the “traditional” wood plank finish with white oak and stainless steal separating strips.
My question is what kind of finish to use on the Oak? The truck will spend most of its off time in a garage and therefore not exposed to extremely harsh weather, but there should be some type of weather protection.
9 replies so far
View Steven H's profile
Steven H
1117 posts in 3301 days
#1 posted 07-05-2011 07:04 AM
Do you want a clear coat that is clear, or don’t care if its amber color?
View cloakie1's profile
cloakie1
204 posts in 2795 days
#2 posted 07-05-2011 09:40 AM
i think most of the resto guys just use polyurethene….and lots of it
-- just get stuck in and have a go!!!
View BarneyTomB's profile
BarneyTomB
28 posts in 2758 days
#3 posted 07-05-2011 11:04 AM
Can’t go wrong with Spar Varnish. That many boat owners can’t be wrong.
-- Profanity; The last refuge of the limited intellect.
View tenontim's profile
tenontim
2131 posts in 3985 days
#4 posted 07-05-2011 01:03 PM
I would put about 4 coats of pure tung oil (not tung oil finish) on the boards, with about 2 days between coats, then top coat that with spar varnish.
View lwllms's profile
lwllms
555 posts in 3522 days
#5 posted 07-05-2011 02:41 PM
I’m not sure what finish was traditionally used but I’d sure like to see photos of your truck.
milbert
#6 posted 07-06-2011 05:59 AM
Steven: I wouldn’t mind a nice amber color, and I have been thinking either a gloss or semi gloss finish.
Barney: I was looking into Spar Varnish a little before I posted this. I don’t know too much about but like you said if its good enough for marine applications I’m sure it would be alright for this use. It seems like penetrating the wood first with oil would probably be best to get the pores full.
Here are a couple pictures of the truck (green machine).
This one is minus a lot of trim/bumpers/running boards that have since been added
Here is a picture of the wood after it was milled to size. The bed actually sits on top of the wood bed, this is just the wood laying in the bed with the stainless steel strips to get an idea of the look.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2771 days
#7 posted 07-06-2011 07:40 AM
Milbert,
Check out this article, and the followup articles it links to. Their test regimen was much more severe than what you’d expose your truck to, but you can probably draw some conclusions as to what the best approach might be in your situation.
Apart from the differences in coating performance, I found the conclusion that using BLO under a spar urethane to be beneficial was enlightening.
-- Mark Kornell, Kornell Wood Design
cloakie1
#8 posted 07-06-2011 11:07 AM
love the truck…
Steven H
#9 posted 07-06-2011 04:02 PM
