Major Tearout - Ash wood
Forum topic by knottyknip posted 07-11-2018 08:24 PM 1410 views 0 times favorited 53 replies Add to Favorites Watch
View knottyknip's profile
knottyknip
25 posts in 130 days
07-11-2018 08:24 PM
Topic tags/keywords: tearout ash oil based stain oops
Hello! Long time lurker, first time posting.
Thank you for all of your contributions and consideration to make this site a very valuable resource.
I am making a table from ash wood. I started removing hardened glue with my hand plane and landed against the grain. The end result is some pretty massive tearout.
I’d like to use an oil based stain (gray) and topped with Arm-R-Seal (matte).
What is the best method to make this blunder as discrete as possible?
I will try to attach pictures :)
53 replies so far
View chrisstef's profile
chrisstef
17717 posts in 3181 days
#1 posted 07-11-2018 08:27 PM
Ouch. Beautiful table. Those look pretty deep. I might be inclined to try the wet towel and iron trick to raise those up and swell the wood. Then id use a card scraper and try not to dish it out too much. If that dont work, maybe some colored epoxy in there but that may stand out too much for your taste.
View Breeze73's profile
Breeze73
98 posts in 856 days
#2 posted 07-11-2018 08:34 PM
I would also recommend some epoxy, but I wouldn’t color/tint it. I would try to put the stain on first in the areas that need to be filled. After the stain is dry, then fill them with clear epoxy. After that dries, then level the epoxy and get it up to a pretty high grit (320-400) before staining the whole piece. The stain won’t stick to the epoxy, but the sealed in stain color underneath should allow it to fit in with the color of your top. Honestly, no-one other than you will notice the ever so slight defect.
-- Breeze
View CaptainKlutz's profile
CaptainKlutz
530 posts in 1669 days
#3 posted 07-11-2018 10:41 PM
+1 Attempt to raise with wet towel and hot iron technique
If still need to fill, I would try Crystalac grain filler. It is clear shellac based grain filler. Does not absorb much stain color from oil based stain, much less than it does with water based versions (but never messed with gray colors).
Using an entirely oil based finishing schedule on top of it, it will be compatible, and should be almost invisible.
If you find the Crystalac filler absorbs some stain color, can hide the damage with some artistic work.
Use some fine line artist brushes with custom mixed dark brown/grey stain colors (to match the color after staining) and re-create some faux grain lines on to filled area to match grain around the area. Will take some patience, but should be able to make the fill disappear to most everyone, except maybe a woodworking finishing guru looking for it.
Best Luck.
knottyknip
#4 posted 07-11-2018 11:23 PM
Chrisstef- thank you for the kind words! I saw an article/video from Marc (WW). Didn’t know if I could do it since I ripped the wood fibers (pictures don’t do it justice, haha). It is definitely worth a shot though!
Breeze73- thank you for the advice! This method is what I was considering due to the depth of the gouging I inflicted. I also thought the satin arm-r-seal would reduce the depth a bit? Any recommendations on epoxy? I would only need a small tube.
CaptainKlutz – wow! I appreciate you sharing that filler. I thought about using some Timbermate and some colored pencils. I like the staining aspect though, and the fact it has a reduced chance of being too dark after applied. Thank you!
There is soo much knowledge here, and I have soo much to learn!!
View Rich's profile
Rich
3758 posts in 764 days
#5 posted 07-11-2018 11:25 PM
The steam trick only works on dents where the cells have been crushed. The steam will swell them to a certain extent and lessen the depth of the dent. Where there is tear out, it won’t work because there are no cells there to swell.
You have a number of options. I wrote a blog post about using epoxy putty to fill defects that will work in your case. Your tear out is already rough enough around the edges to ignore the part about obscuring the defect. Also, since you plan to stain it, you will want to do that before any blending of color. Use an epoxy lighter than the wood is raw and stain it, then do the blending and seal it.
Another possibility is a hard fill. There are a couple of different kinds and without a lot of time practicing, a regular hard fill will be your best choice. You can melt it with a soldering iron to drip it into the defects, and use a leveler to scrape it flat. It comes in dozens of colors and is used after staining and your first seal coat is applied. After you complete the fill, then you apply your remaining layers of top coat.
For the hard fill, check out Mohawk Finishing Products videos on youtube. They have a ton of useful how-to videos on doing hard fill.
The final fill is a shellac-type of stick. It’ll give the best results, but I don’t recommend it for a beginner since the repair is leveled with a burn-in knife and you need a lot of practice to get it right.
One last thing — avoid clear fillers. They sound like they are the perfect fix, but they show up the most due to the way they bend the light that goes through them.
View pintodeluxe's profile
pintodeluxe
5783 posts in 2988 days
#6 posted 07-11-2018 11:50 PM
I have battled tearout on tabletops in the past. It can be frustrating.
I switched to a helical cutterhead on my planer, which seemed to cure the problem. I glue up pairs of boards into planks, and plane the planks to finished dimensions. Then I glue the planks together. This way I only have to clean up 2 or 3 glue lines for a wide table.
I sand the tabletop, rather than hand planing it. This way there’s no risk of tearout. A card scraper is another option, but it’s a dreadfully slow process.
I know it doesn’t help on this table, but that’s how I’ve avoided the problem lately.
View Aj2's profile
Aj2
1796 posts in 1973 days
#7 posted 07-11-2018 11:59 PM
Card scraper for sure you don’t need to scrap the whole table. Just lower the wood in the tear out area and blend outwards.
You must of forgot about that card scraper right.
-- Aj
View waho6o9's profile (online now)
waho6o9
8483 posts in 2752 days
#8 posted 07-12-2018 12:32 AM
Maybe use the other side?
knottyknip
#9 posted 07-12-2018 02:58 AM
Rich – awesome! Thanks for taking the time and consideration in your response. The thread you created/linked was very informative and helpful with the pictures! I cannot express my gratitude enough!!
Pintodeluxe- I like your approach! Once I convince my wife I’m pretty decent at this, the allowance for tools may increase.
knottyknip
#10 posted 07-12-2018 03:06 AM
Aj2- I don’t have a card scraper. Seems like a valuable tool that would come in handy often! Any recommendations on a budget friendly one?
knottyknip
#11 posted 07-12-2018 03:06 AM
waho9o6- your response is brilliant. I have a tendency to over complicate things. I liked this side for selfish reasons (grain/figure), but my brother wants it stained gray anyways!! The other side is perfect. Haha – too funny. Thank you for helping me keep it simple!
knottyknip
#12 posted 07-12-2018 03:16 AM
- waho6o9
I’m gonna try a variation of a method listed above, and if it doesn’t work… I will use the other side.
waho6o9
#13 posted 07-12-2018 03:23 AM
Looking forward to seeing your fine table in the projects thread knottyknip!
“I’d like to use an oil based stain (gray) and topped with Arm-R-Seal (matte).”
Practice on some scrap pieces before doing the whole table to make sure you like the finish.
You’re welcome knottyknip and keep doing the good work!
View Desert_Woodworker's profile
Desert_Woodworker
1623 posts in 1389 days
#14 posted 07-12-2018 03:29 AM
The steam trick only works on dents where the cells have been crushed. The steam will swell them to a certain extent and lessen the depth of the dent. Where there is tear out, it won t work because there are no cells there to swell.
The final fill is a shellac-type of stick. It ll give the best results, but I don t recommend it for a beginner since the repair is leveled with a burn-in knife and you need a lot of practice to get it right.
- Rich
+1 wet towel for dents and whatever else he said, seriously. Nice job…
-- Desert_Woodworker
woodbutcherbynight
5597 posts in 2584 days
#15 posted 07-12-2018 03:34 AM
I started with these card scrapers, still have them.
https://www.amazon.com/Crown-Hand-Tools-Rectangular-375/dp/B012M9H8UG/ref=sr_1_6?ie=UTF8&qid=1531366401&sr=8-6&keywords=card+scrapers
showing 1 through 15 of 53 replies
