Why I love BLO
Forum topic by CharlieM1958 posted 07-04-2011 06:31 PM 4538 views 0 times favorited 25 replies Add to Favorites Watch
16274 posts in 4216 days
07-04-2011 06:31 PM
The other day I posted this box in the projects section.
Although I was happy with it overall, I kept thinking that the colors were just not exactly what I had originally envisioned. After some self-debate, I spent about three minutes sanding off a polyurethane mirror finish I had several hours invested in, and wiped the whole thing down with boiled linseed oil. After it cured, I buffed on my 3-wheel Beall system.
The whole new finish took less than 15 minutes (not counting curing time), and I think it looks much better than the original, much more time-consuming finish.
See the before and after below. Sometimes you just have to not over-think things. :-)
25 replies so far
TopamaxSurvivor
18269 posts in 3673 days
#1 posted 07-04-2011 06:39 PM
WOW!! Thanks for the hot tip Charlie!! :-)) I love it to but for different reasons. I fixes the handles of tools with too much time in the weather. It makes muzzleloading ramrods very resilient. Now I think I will use and love it even more. I have been thinking about just using it as a primary finish, You have made up my mind ;-))
View BobTheFish's profile
BobTheFish
361 posts in 2549 days
#2 posted 07-04-2011 06:40 PM
often times, it’s more of a matter of which finish is best for the project. Designing and constructing something is only about 2/3’s of the project. Properly sealing and bringing out the true character of the materials is the other third.
It takes time and plenty of experimentation, but learning to use a variety of different techniques and products will give you the means to truly “finish” your projects.
View Bertha's profile
Bertha
13528 posts in 2690 days
#3 posted 07-04-2011 06:41 PM
Charlie, I love BLO for both yours and Topa’s reasons. Did you buy your Beall system as a kit or did you cobble it together? I’m in the process of putting a system together to operate on a treadle.
TopamaxSurvivor
#4 posted 07-04-2011 06:42 PM
BTW, I think you should re post it as a refinishing project with more pics of teh box before and after ;-))
#5 posted 07-04-2011 06:50 PM
Al, I bought the kit with the lathe spindle. It’s fantastic for small projects. The only drawback is that because the wheels are fairly close together you can’t buff anything very large.
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3156 days
#6 posted 07-04-2011 06:50 PM
I don’t like that it turns lighter woods yellow – some call it “warmth,” but I call it yellow. However, in the right application it’s stunning. Definitely a good thing there, Charlie!
-- jay, www.allaboutastro.com
#7 posted 07-04-2011 06:53 PM
Jay, yes, the yellowing is definitely a consideration. There is a noticeable difference on the light corner inlays, but I think the trade-off is worth it for the effect on the walnut in this case.
View RogerBean's profile
RogerBean
1605 posts in 2951 days
#8 posted 07-04-2011 07:20 PM
Charlie,
I think your decision to tone down the color a bit was a great success. Walnut seems to be a wood that generally benefits from a little subtle color manipulation (and is perhaps my favorite wood). But then, I definitely tend toward darker woods and low contrast combinations. However, many roads lead to Rome. :-) Nice job.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
View SPalm's profile
SPalm
5320 posts in 3879 days
#9 posted 07-04-2011 07:37 PM
HA!
Amazing what photoshop can do.
Good discovery, thanks,
Steve
-- -- I'm no rocket surgeon
Bertha
#10 posted 07-04-2011 07:44 PM
I also agree that BLO yellows. Not as bad as amber shellac, which should probably be classified as orange shellac (at least the cheap ones I use). BLO’s hit or miss on different woods but I think clearly a hit on Charlie’s. I just like the feel of slathering it on, leaving the piece out in the sun a bit, then rubbing on it some more. Creepy, sure; but I like it.
View Tedstor's profile
Tedstor
1643 posts in 2630 days
#11 posted 07-04-2011 08:03 PM
Nothing wrong with the original finish.
But the new finish is nothing short of amazing.
I LOVE when the quick/easy way works out so well.
View degoose's profile
degoose
7233 posts in 3352 days
#12 posted 07-04-2011 11:19 PM
Go for the simpler things in life… often the best.
View sedcokid's profile
sedcokid
2732 posts in 3596 days
#13 posted 07-05-2011 04:30 AM
Charlie,
I never drempt that BLO was a finish that looks this great! It is Beautiful!!!
Thanks for Sharing!
-- Chuck Emery, Michigan,
View Steven H's profile
Steven H
1117 posts in 3057 days
#14 posted 07-05-2011 07:15 AM
BLO is also great for making wood old.
View Roz's profile
Roz
1699 posts in 3784 days
#15 posted 07-27-2011 01:23 AM
I have never heard of BLO but it has given this box a much richer finish.
-- Terry Roswell, L.A. (Lower Alabama) "Life is what happens to you when you are making other plans."
