Using 2” pvc pipe for dust collection
Forum topic by jody495 posted 07-11-2018 05:27 AM 258 views 0 times favorited 5 replies Add to Favorites Watch
View jody495's profile
jody495
39 posts in 2670 days
07-11-2018 05:27 AM
While revamping my dust collection system I needed to put a 2-1/2” blast gate in a 2” pvc fitting. What I came up with was to cut4 slots in the bell of the fitting then start to push the blast gate into the bell. I then heated the pvc fitting up with a heat gun. When the plastic was soft I finished pushing the blast gate in. I then ran a self tapping screw thru the pvc into the stub on the blast gate. I finished off by wrapping electric tape to seal the slots in the pvc. Sorry I don’t know how to post pictures
5 replies so far
View squazo's profile
squazo
78 posts in 1694 days
#1 posted 07-11-2018 11:59 AM
Why not just get adapters?
View DBDesigns's profile
DBDesigns
64 posts in 47 days
#2 posted 07-11-2018 12:38 PM
I just wrap “Duck Tape” around the female end until it is fat enough to fit tight with a slip joint. “The only tools you need are duct tape and WD40.” If it moves and it shouldn’t…duct tape. If it should move and it doesn’t…WD40!
-- I remember when Grateful wasn't Dead
jody495
#3 posted 07-11-2018 01:21 PM
A 2-1/2” blast gate wouldn’t fit into a 2” sch. 40 pipe fitting. A 4” blast gate will fit into the end of a 4” pvc pipe. It is a little loose, I put a bead of caulking around the gate before I install it then add self tapping screws to make it secure.
View woodbutcherbynight's profile (online now)
woodbutcherbynight
5206 posts in 2458 days
#4 posted 07-11-2018 04:02 PM
Lots of methods to accomplish the same results. If it works and doesn’t leak all is good. For anyone reading and wanting a NASA style fix you could spend some time and try this.
Mark with tape 1” down from the end of the pipe, sand turning the pipe against a sander until you get a loose fit. Then take pipe to TS and use your miter sled. Slightly raise blade and rotate pipe around creating a channel, move 1/4 inch and repeat. You now have two slots for O rings that can be found in stock at hardware store, Borgs, or HF sells a cheap kit. Lubricate with WD -40 to install and you have a slip joint that has no tape and can be taken apart fairly easily. Even looks seamless if you are careful with the sanding part.
Did I do mine like this? NO. But my son wanted to better understand how such a joint worked so as an experiment we did this. The few places I have ever had trouble in the shop I just use duct tape or an adapter.
LOL
jody495
#5 posted 07-11-2018 04:28 PM
Sounds good. I run a solid copper wire inside for grounding and one on the outside to prevent static electricity from causing a fire
