| Forum topic by Estley | posted 604 days ago | 3831 views | 0 times favorited | 18 replies | ![]() |
604 days ago |
Hey guys, I have two Dewalt 14.4 batteries that need to either be replaced or re-built. Does anyone here have experience with re-built batteries? are they worth it, or should I just send them to the recycle center and get fresh ones?... By the way, for those of you who do re-build where’s a good place to send them? |
604 days ago |
Never done it. |
604 days ago |
To be honest I have never heard of anyone rebuilding them. Tool suppliers such as Lowe’s and Home Depot maintain recycling centers for returning these batteries. New ones cost $74 at Lowe’s (I bought one last month). It would be difficult to get one rebuilt for this price. But here is a link that I found http://www.primecell.com/ Hope it helps. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
604 days ago |
You might check with an Interstate Battery Shop, not people that just sell batteries. The local shop in Bloomington, IL rebuilt some for me for $25 a pop. -- Only the Shadow knows.................... |
604 days ago |
There is a guy on Ebay that swears you will send you the plans on how to re-build almost ANY battery but I havent never heard of anybody ever doing it. |
604 days ago |
They should just be normail off the shelf batteries inside. -- Gary, East TX -- The longest journey begins with a single step. |
604 days ago |
I went looking myself and found the labourand materials was not feasible.
I had 4 dead Sears 15.6 batteries; I went on E-bay and bought 4 identical volt batteries made by -- AllWood |
604 days ago |
Check out these guys. They have really good prices. http://batterybank.net/digital/powertools/ I bought the -- Tim -- http://tmuli.com |
604 days ago |
I had two Milwaukee 18V batteries rebuilt by MTO Battery rebuilders. http://www.mtobattery.com/store/ On a side note, just after I had my two of my batteries rebuilt, Milwaukee had a recall on batteries and I got two new ones to replace my other two batteries. So, now I have four new batteries. -- Jim |
603 days ago |
I don’t have any experience with any of the re-builders but I looked into doing it myself a couple of years ago and decided that it wasn’t cost effective. Believe it or not if you price 15 (for 18V) good quality cells it is only slightly cheaper than getting a new battery. Figure in shipping, cost of my time and lack of warranty and it was a non-starter. If your going to stray from OEM batteries please do your homework. Some batteries are designed to preform like a Formula 1 engine. Some batteries are more like a small economy 4 cylinder engine. The high performance battery will generate more power but won’t last as long. The economy battery may last for ever but good luck drilling hard maple with a 2” bit. One other thing. NIMH batteries are not inherently better than NICAD. NIMH is a little lighter for the same capacity, which is why the auto industry is interested in them, but an 18V 2.4AH battery pack will deliver the same power (voltage) for the same amount of time (Amp-Hour) regardless of the chemistry. -- Che. |
603 days ago |
Estley, I’ve done exactly what you a contemplating doing. Rebuilding a DeWalt 14.4 volt battery pack. Before I lay out the facts I’ll give you the final answer so you can quit reading and move on: It’s not worth it. Here are the facts for DeWalt 14.4 v drill battery packs: - the battery packs are based on nicad battery technology.
- nicad sub-c cells are around $2.50 – $5.00 USD Sanyo Nicads - you need 12 of them per battery pack so you are looking at $30 – $60 in raw nicad batteries per pack You probably dont have a resistance welder that will work to spot weld the tabs of one battery to the post of the other battery. Too bad, that means you are going to have to solder the tabs together and possibly have to use some jumper wire. This is bad because the connections are not as good and the soldered connections take up more physical space. You have a poorer solution that you have a hard time fitting back in the case. But if you decide to keep going make sure you buy the batteries with tabs, you’ll need the tabs, top and bottom, to solder together. If you are determined you can make it work. It is possible to get the batteries soldered together in way that is reasonably sound and will eventually fit, with a little filing and pounding. Hopefully you made sure the batteries bought are suitable to use with your factory dewalt charger with similar charging characteristics. That way you can just drop you newly rebuilt pack onto the factory charger, otherwise you’ll need to find or build a new charger. Oh, and don’t forget, when you cracked the case you might have split the plastic, but even if you didn’t you’ll have to find a way to epoxy it all back together and not leave any bumps or changes in shape so it will still fit and lock into the tools handle. And finally nicad batteries require controlled disposal, dont just throw the old ones in the garbage. So, if you went through all that fun you can actually rebuild a tool battery pack. And it will work, and it will have performance similar to a factory pack. But unless you’ve got a secret stash of sub-c cells, the right tools, patience and general handy skills, you wont save much, or any, money, and you’ll likely end up with a sub par result. So I’ll say again: It’s not worth it. |
602 days ago |
guy on craigslist.org that rebuilds tool batteries … link... -- work from your heart and your spirit will live forever |
516 days ago |
I just use Batteries Plus…. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
515 days ago |
I’m a little Sheepish about it – but I buy Ryobi drills because they I owned a nice Bosch drill that was nicer in terms of ergonomics On rebuilding batteries: I’ve read about it and apparently its commonly the case that only You can sometimes bring a dead battery back by putting it in -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
515 days ago |
I gave up on portable drills the first time I went and saw how much the batteries cost LOL. I don’t do much work in the woods and my corded drill is always powered up and ready 2 go. Anyone want a Dewalt 14.4V drill without batteries? -- Scott - Chico California http://chicowoodnut.home.comcast.net |
513 days ago |
I haven’t tried this yet, buy planning on it. I too have a dewalt 14.4 with one bad battery. -- Joey, Magee, Ms http://woodnwaresms.com |
11 days ago |
I’ve rebuilt quite a few batteries with just a soldering iron. The cells that are inside are sub-c or SC cells. Here is a really basic article outlining what is inside a power tool battery. http://toolbatt.com/anatomy.html if your thinking of rebuilding one. You need to be really careful not to heat up the cells to long as this can damage them. I like to hot glue all the cells together first also, this makes it much easier to work on. I don’t rebuild them anymore though it is just as cheap to buy a good quality aftermarket one from someone like http://toolbatt.com |
11 days ago |
I tried it quite a while ago on two early B&D cordless drills that did not use battery packs. I got the batteries from Batteries Plus. After all the work and cost they didn’t last long at all so I won’t be attempting that again. From my experience with RC cars and their NiCad battery packs to get the best performance you want to have matched cells, the characteristics of each individual cell being the same. Buying 12 cells out of a bin does not get you matched cells even when they’re the same make an model. I have to think that the manufactures do this matching to some extent to get a decent product. I too use DeWalt 14.4’s, DeWalt sells a two-pack, usually in the $109-$119 range, I pick a couple up packs when they’re on sale for $99. That brings them down to $50 a pop, right around what you spend on batteries alone to rebuild them. -- -Curt, Milwaukee, WI |
11 days ago |
i think i can add a little to the discussion. i love to tinker. in fact i do more “fixit” than straight woodwork. that little booklet on ebay for 7 bucks is not a rip-off. i bought it last yr. its not very good for fixing dead batteries but it had some good over view info. on how to care for you batteries. and explains difference in fair detail nicad and nimh lith, and one or two others. i forget now but one is real sensitive to cold and the other sensitive to draining past 90%. as fare as fixing dead ones its a hasle, you need 2 or 3 strong fully car batteries. in sequence. ie you have to take the battery out of 2-3 vehicles unless you have several sitting around the shop. but for the guy with more bucks go with the rigid b/c free life time batteries. and although i love ryobi but and try not to drop off the ladder ive lost a few this way. as i do alot of roof and gutter work. |
| Forum | Topics |
Woodworking Skill Share
2908 |
3933 |
256 |
946 |
223 |
Woodworking Trade & Swap
617 |
Coffee Lounge
2377 |
LumberJocks.com Site Feedback
522 |
