Shelf life of jeweler's rouge
Forum topic by TopamaxSurvivor posted 07-03-2011 09:12 PM 5257 views 0 times favorited 16 replies Add to Favorites Watch
TopamaxSurvivor
18267 posts in 3671 days
07-03-2011 09:12 PM
Topic tags/keywords: jewelers rouge shelf life
Does anyone know if jeweler’s rouge has a shelf life or any deterioration after a decade or 2?
16 replies so far
View Loren's profile
10377 posts in 3643 days
#1 posted 07-03-2011 09:21 PM
I’ve had some around for over a decade and it seems pretty much
the same. It can get dry and crumbly and may not stick to buffing
wheel fibers quite as well, but it seems to cut the same.
View David Grimes's profile
David Grimes
2078 posts in 2635 days
#2 posted 07-03-2011 09:31 PM
Ditto what Loren said. The mineral(s) are good but the carrier/binder is what dries or degrades.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
TopamaxSurvivor
#3 posted 07-03-2011 09:41 PM
Can you dissolve it in anything to rejuvenate the binder?
David Grimes
#4 posted 07-03-2011 09:50 PM
Maybe. If you can identify what it is and find the MSDS to see what the binder is, you may be in business. I bet it varies by mineral used.
I did exactly that with some automotive glass rouge. The lid cracked and it dried up. It got a tiny bit of light mineral oil and mortar/pestle treatment. I put it in a cold cream jar the wife had almost emptied. I still have it and THAT was late ‘90’s.
View Bill White's profile
Bill White
4928 posts in 3955 days
#5 posted 07-04-2011 12:54 AM
Use it and quit worryin’.
Bill
-- bill@magraphics.us
35120 posts in 4395 days
#6 posted 07-04-2011 02:28 AM
I go with using it.
View horologist's profile
horologist
104 posts in 3734 days
#7 posted 07-04-2011 03:40 AM
I use mostly green and red rouge, some of which is probably 20 to 30 years old and have observed no ill effects.
Is there some reason for your concern?
-- Troy in Melrose, Florida
TopamaxSurvivor
#8 posted 07-04-2011 06:34 AM
It doesn’t want to rub on the leather strop very well and it makes a gob when it does. Seems to have lost its easy flowing consistency. Just like to get it smoothed out like it used to do.
View philip marcou's profile
philip marcou
264 posts in 2592 days
#9 posted 07-04-2011 06:53 AM
It can be dissolved or softened in mineral spirits (turpentine). I think the carrier base is wax so you can also soften it for easier application by heating it a bit.
So if your shop is an oven it will have a short shelf life and simply melt away (;).
Other than that its shelf life is infinite, but I did have a dog who got hold of a bar and chewed it …..
TopamaxSurvivor
#10 posted 07-04-2011 08:20 AM
I thought it was probably a binder/carrier issue, not a problem with the polishing materials. If it is wax, I will try heating it a little. The shop has never really been an oven or a freezer. The only difference in the seasons here in Water World, aka Western WA, is about 15 degrees in the mist ;-)
Maybe I will try melting a gob of it with a little mineral oil to soften it up like I do with bees wax to make bullet lube. Thanks for the tip!! ;-))
Seems like the last time I made a strop, about 20 + years ago ;-) it wiped on fairly evenly.
horologist
#11 posted 07-04-2011 04:19 PM
It does sound like the binder (usually wax or grease) has broken down. You may be able to revive it but in a pinch the stuff is cheap.
:o)
Funny how dogs are attracted to the strangest things. We took care of my mother in law’s dog once, the second day here he dug into the box where I keep my polishing compounds and ate most of the green rouge. Only the green rouge. No ill effects but he made quite a mess.
View woodsmithshop's profile
woodsmithshop
1318 posts in 3540 days
#12 posted 07-05-2011 02:19 AM
I have had a stick of it since 1962, when I went into the Army, still works ok.
-- Smitty!!!
TopamaxSurvivor
#13 posted 07-05-2011 10:52 AM
Yeah, it is cheap, but I hate to throw anything that is basically still good away. Guess that comes form being raised without a penny in my pocket until I was old enough to earn it myself ;-)
View Sanderguy777's profile
Sanderguy777
174 posts in 1197 days
#14 posted 02-13-2015 01:05 AM
I have the same problem with the white rouge. If I heated it with old motor oil would it hurt the metal or anything?
I know, it’s a dumb question but, I am just curious. What about if I ground it up and dawn in it. I bought a strop from woodcraft that came with a jar of paste; the sales man said all it was was Flexcut gold and some Dawn soap.
View waho6o9's profile
waho6o9
8187 posts in 2572 days
#15 posted 02-13-2015 01:28 AM
” If I heated it with old motor oil would it hurt the metal or anything?”
Be careful as motor oil is flammable.
