Rikon resaw bar
Forum topic by Tom Canales posted 07-03-2011 08:27 PM 7727 views 1 time favorited 5 replies Add to Favorites Watch
View Tom Canales's profile
Tom Canales
34 posts in 2616 days
07-03-2011 08:27 PM
Topic tags/keywords: bandsaw resaw rikon
OK so i just bought a Rikon 14” bandsaw, got it put together and adjusted. I’m new to bandsaws and I’m confused about how to use the supplied resaw bar. I would have figured to resaw you simply run a piece of wood along the fence. What is the point of the resaw bar? How is that thing suppose to help? it just seems to be in the way.
-- I used to be indecisive, now I’m not so sure
5 replies so far
View Loren's profile
10476 posts in 3672 days
#1 posted 07-03-2011 08:56 PM
It lets you make subtle corrections while resawing. It’s pretty
tricky to set up a bandsaw for perfection in resawing with
a straight fence.
View coloradoclimber's profile
coloradoclimber
548 posts in 4092 days
#2 posted 07-03-2011 08:59 PM
Tom, look up bandsaw drift angle. If you have not set your fence to account for drift the saw will not cut a straight line. If you use the resaw bar to guide by hand along a mark you can get consistent cuts regardless of drift. Using the resaw bar allows you account for drift on the fly. It can be faster if you do onesy-twosy resawing. If you are doing a bunch of resawing it’s probably worth the time to fuss with zeroing out the drift.
View pintodeluxe's profile
pintodeluxe
5703 posts in 2838 days
#3 posted 07-03-2011 09:00 PM
It is like a single-point pivot fence. Some people like to resaw that way. I prefer to set my fence at a slight angle to correct for blade drift.
View bubinga's profile
bubinga
861 posts in 2692 days
#4 posted 07-03-2011 09:25 PM
That is to adjust for blade drift. Here’s some videos, differant fence, but are basically the same thing
Resawing On A Band saw Part 1 Presented by Woodcraft
Resawing On A Band saw Part 2 Presented by Woodcraft
-- E J ------- Always Keep a Firm Grip on Your Tool
Tom Canales
#5 posted 07-04-2011 02:08 AM
Thanks for all the helpful replies guys!
