Looking for a way to Preserve/ Treat wood myself from Rot and Decay.
Forum topic by ringosmills posted 689 days ago 1011 views 0 times favorited 6 replies Add to Favorites Watch
View ringosmills's profile
ringosmills
21 posts in 1136 days
689 days ago
Topic tags/keywords: ash question milling rustic tip
Hi all. I recently bought a sawmill. And have started milling alot of Ash. With all the Ash dying here in Ohio it is very plentiful. I have milled some beams and wanted to know if anyone knew of a way to preserve the wood from decay and rot from ground contact? I am looking to sink some of the beams in the ground for an arbor for my wife. what would be the best way to seal them up? Thanks, Nate
-- Nate- Bryan, Ohio
4884 posts in 1817 days
#1 posted 688 days ago
The pole barn builders know about these issues.
View Nomad62's profile
Nomad62
567 posts in 1127 days
#2 posted 687 days ago
There are plenty of wood preservatives out there, but the one I would recommend is a green colored paint-on (or spray, but I don’t like that) type; I don’t know the brand name off the top of my head (I have a can at home) but I’m sure your local building supply will have it or a version thereof. You can also use any borate solution and spray it on, but I prefer the green stuff. Bugs just love ash wood, so make sure and get it all covered well, especially the end grain. I would recommend putting in concrete piers that stand proud of the ground by at least 6” to put the wood beams on top of (you can put recesses in it to accept the beam), but if you put it in a hole then don’t fill it with concrete, fill it with gravel after having put in about 3-4” of gravel in the hole first. Filling the hole with concrete almost guarantees the beam to rot at ground level; the gravel will let the water go away. Congrats on the mill, I have one as well and it’s a blast slicing logs. Best of luck!
View auggy53's profile
auggy53
160 posts in 849 days
#3 posted 686 days ago
i think the green stuff that nomad mentioned is called penta , i used it along time ago and it worked well for what i needed.
-- rick
View ajosephg's profile
ajosephg
1719 posts in 1730 days
#4 posted 686 days ago
Can’t be penta – it was outlawed years ago.
-- Joe
Nomad62
#5 posted 686 days ago
Forgot to look last night, called my wife to get the name…good to have her around every now and then, lol. Anyway, it’s made by Jasco, and called Termin-8. I paint it on and let it soak in for a few minutes, it stinks and is messy but a really good product. Got a 5 gallon can a few years ago, haven’t checked it’s current availability.
View HerbC's profile
HerbC
778 posts in 1028 days
#6 posted 685 days ago
I believe you’ll find that ash does not hold up well in ground contact applications. ERC (eastern red cedar), or black locust would be good choices if you do not want to use commercially available treated posts.
Good luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
