Anybody a framing capenter?
Forum topic by JPB posted 07-03-2011 04:27 PM 2385 views 0 times favorited 27 replies Add to Favorites Watch
View JPB's profile
JPB
31 posts in 2586 days
07-03-2011 04:27 PM
I didn’t know where to post this, or even if its appropriate for this site, but the members here seem much less likely to flame me for posting a DIY question in a ‘pro’ forum, which is all I can seem to find. Mods delete away if I’m way off topic.
I have this cat – it had a small medical problem (corrected) that led to his relieving himself in my living room – way up against the wall. As a result it soaked thru the carpet, missed the padding and into the OSB subfloor and sill plate for an outside wall. We already had some hardwoods ordered to go down in there, so I was just going to patch the subfloor and spay the sill plate with some cat pee chemical from the pet shop.
So my question is, how do I patch the subfloor that is right up against the sill plate? Is there going to be anyway to get a cut flush up against the sill plate? Jig saw maybe?
Any insight would be much appreciated. Thanks
Joe
27 replies so far
View lew's profile
lew
12154 posts in 3812 days
#1 posted 07-03-2011 04:46 PM
Every project requires a new tool! How about this-
http://www.portercable.com/Products/ProductDetail.aspx?ProductID=24970
View specialj's profile
specialj
8 posts in 2593 days
#2 posted 07-03-2011 04:57 PM
sawzall with blade in backwords works just be carefull not to cut into i joist or framing members below.For bathroom remodels we have to do this just about on everyjob to get at the plumbing,etc…
View Mark's profile
Mark
1807 posts in 3331 days
#3 posted 07-03-2011 05:24 PM
sawsall out a square patch and make sure you cut it on center joist to joist. do not cut the joist (or any wiring at that). it may be a bit easier to use a circular saw at 5/8” or 3/4” depth depending on how thick your floor is just along the joist until you cant cut any further with it. but anyways once its cut out, get a piece of plywood the same thickness and size that you cut, and screw it into your joists. If you really want to perfect it, use some subfloor caulking on the floor joist before you screw it in. And to top it off, if you can get to it from underneath just grab a small piece of plywood and screw it in where the board butts with the existing subfloor (just to prevent warping or a weak spot in the floor (it will be strong enough without it but just to give it that little extra beef if you want it). Anyways thats that.
-- M.K.
View Mark's profile
Mark
#4 posted 07-03-2011 05:26 PM
o….and when cutting the ply along the joist, watch out for screws or nails. remove them first.
-- M.K.
View Bluepine38's profile
Bluepine38
3379 posts in 3142 days
#5 posted 07-03-2011 06:27 PM
I have had to do a couple of these, a sawzall will usually get you close enough, after you use a circular saw to
take out an opening so you can see what is underneath, if you can not get at it from underneath. I always
attach at least a 2X4 between joists to fasten the new piece to on both ends and glue it to eliminate any
possibility of a squeaky floor. Nothing can ruin a job worse than having the carpet down and hearing that
damn squeak as you walk in to pick up the check.
View JPB's profile
JPB
#6 posted 07-03-2011 09:59 PM
Thanks for the tips. I can’t possibly get all the wood out – I can’t cut out the sill plate, can I? I was thinking of using the sawzall andcutting out a square between the joists, rather than trying to pull out all the nails so I can cut down the center with a circular saw. I was then going to attach some 2×4’s to the joists to screw the sub floor to. Kind of like the ask the builder guy here
http://www.youtube.com/watch?v=o1zvWVL5_9w
I DO have access to the floor from the bottom.
Anybody have any idea what a carpenter would charge me to do do this? Maybe I’ll hire it out and pass on the opportunity to buy a new tool.
View Mark's profile
Mark
#7 posted 07-03-2011 11:20 PM
lol…..a carpenter will charge you too much for something so little…..he’d prob charge you 50-100$....you can cut out the sill as long as theres no stud on it and you must put a block in to replace it when you’re done putting the subfloor in
-- M.K.
View Mark's profile
Mark
#8 posted 07-03-2011 11:22 PM
you can cut out a small square between the joists like you said and but 2×4 blocks under the new piece to support it just dont put too much weight on it afterwards
-- M.K.
View fussy's profile
fussy
980 posts in 3107 days
#9 posted 07-04-2011 04:46 AM
Same thing happened to us except the damn cat was lazy, not sick (we still have him. I’m married). We cut up the sub floor with a circ saw with depth set for the thickness of the sub floor. Used a toe-kick saw from HF, #94626. Amazing tool, worked great. Worth every penny even if I never use it again. Got right up to the wall. Used 2 coats of Kilz, finished up, and the floor’s been down a year (red oak), and nary a sign of cat pee. He walks by the corner with a puzzled look.
Steve
View Grandpa's profile
Grandpa
3260 posts in 2732 days
#10 posted 07-04-2011 05:26 AM
Buy a product called “Acticate Plus” at a janitorial supply store. It works well.
View jerkylips's profile
jerkylips
419 posts in 2627 days
#11 posted 07-05-2011 03:35 PM
at our old house we had a similar problem – cat had a medical problem & did the same thing. I got a gallon jug of that “nature’s miracle” enzyme cleaner. I scrubbed it up with water first, then REALLY soaked it with that stuff. I had to let it dry for a weel pr so, but it seemed to do the trick. We had 3 cats at the time. None of the cats went back to that spot. If you have the time to do it, it would probably be less drastic before cutting up your floor (especially since you need to treat the sill plate anyway.
One thing our vet recommended was getting a black light to make sure you can see every spot that the cat “hit” & treat them all. We saw lots of stuff under the light that we’d never know was there otherwise.
View JPB's profile
JPB
#12 posted 07-05-2011 06:08 PM
I did the Natures Miracle thing. In fact, since there is new floor going down anyway I cut a big piece of the carpet out and treated the sub floor and sill plate directly. The problem I am now facing is the floor has to go down, and the surface is WET – like 16 to 18% according to my meter and besides that, it still stinks, and I mean BAD. I am thinking about that toe kick saw, but I have heard some pretty scary stories about them. Would that multi tool be able to take out take out that OSB under the sill plate?
jerkylips
#13 posted 07-05-2011 08:37 PM
yours must be worse than ours was, then. If it were me, I’d start with a circular saw set to a depth of your subfloor thickness & get as close to the sill plate as possible – you should be able to get within 1-2”. From there, you may need to use a chisel to chop out the rest. Definitely glue & screw the new piece to prevent squeaks later.
I realize this probably goes without saying, but make sure that when you cut out the old piece you give yourself something to nail to on the edges. that may mean cutting the hole bigger than you need to get rid of the pee spots..
View childress's profile
childress
841 posts in 3598 days
#14 posted 07-05-2011 09:32 PM
I used to work for a general and we had a realtor client that had us do fixes to get places ready to rent. One condo had cat piss and it wreaked…. Basically put a couple thick coats of kilz2 and it completely sealed and blocked the odor. No cutting and replacing sub floor whatsoever. I’m pretty sure it worked fine because this realtor was a stickler and always called us back for the most mundane things, but this particular problem, never a call back. Hope I’m not too late and you haven’t already done a bunch of work… You can get this at any hardware store pretty much.
-- Childress Woodworks
View JPB's profile
JPB
#15 posted 07-06-2011 12:15 AM
I haven’t done anything yet. I thought about Kilz – I was worried about the moisture content of the OSB sub floor after the Natures Miracle treatment. I have to put 3/4” sold maple floor on top of this.
