Got retro-fit kit for RAS but now confused
Forum topic by Yupa4242 posted 07-03-2011 06:17 AM 916 views 0 times favorited 1 reply Add to Favorites Watch
View Yupa4242's profile
Yupa4242
116 posts in 2775 days
07-03-2011 06:17 AM
On the Instructions It says to lower RAS arm and tilt arbor pointing down and set the miter to 50 degrees. I do this to use the arbor as a guide for the fence rail supports so that each side is the same height. Once i got one side tight and level i moved the arm to the other side only to find arbor is over a 1/2 inch higher on the right side and the rail will not reach to match. Since i bolted down the base is it possible that I I kiltered the sqareness a bit. I’m thinking that the saw may be hard bent or damaged.
-- "If the Universe is Infinite, Then all dreams are real."
1 reply so far
View gawthrrw's profile
gawthrrw
207 posts in 2621 days
#1 posted 09-15-2011 12:25 AM
Its quite possible the base is bent. My first RAS was a craftsman and i had nothing but problems with it. Ive been told that once the base is out of true that it is nearly impossible to fix. Your best bet is either find a new base(which is probably more than the saw is worth.) Or just go find you an old dewalt RAS. I’d go for the latter. Can’t get better than the Dewalt. I own three.
-- Rob, Dallas TX
