Wood advise
Forum topic by TN777 posted 07-08-2018 09:12 PM 400 views 0 times favorited 3 replies Add to Favorites Watch
View TN777's profile
TN777
2 posts in 37 days
07-08-2018 09:12 PM
Topic tags/keywords: birch table top table top advise recommendations
Hey everyone,
I’m a woodworking hobbyist with a few years of self-learning. I’m currently attempting to build a table top for a rise to stand table.
My project so far:
1. piece of birch 60” Long X 27” Wide X 1.5” thick – I need a piece that’s 31.5 wide X 65” long
2. would like to add mesquite to the birch (60” Long X 27” Wide X 1.5” thick) to meet the dimensions 31.5 wide X 65” long
Questions
1. would joining the birch and mesquite be a good or start from scratch
2. concerned with shrinking and expansion
thank you in advance
3 replies so far
View Kazooman's profile
Kazooman
1085 posts in 2032 days
#1 posted 07-08-2018 09:50 PM
Birch and mesquite are going to expand at different rates with changes in humidity. However, that should not be a major problem for making the piece wider. Ripping the birch and adding a center piece of mesquite or adding two mesquite pieces along the edges should be OK. The problem comes in adding the 5” to the length. If you were to add a mesquite breadboard on both ends you have a cross grain situation. The center panel would expand and contract with changes in humidity much more than the breadboard ends. You will have to use the common breadboard joinery methods to allow for the expansion.
TN777
2 posts in 37 days
#2 posted 07-16-2018 01:16 AM
Kazooman,
Thank you for the advice. I have not started the project as of yet but will definitely into the breadboard ends.
View John Smith's profile
John Smith
1229 posts in 242 days
#3 posted 07-16-2018 01:06 PM
that sounds like the standard 27 or 28” Lauan Door to me.
with hardwood ends and edgebanding of contrasting color.
-- Graduated Valedictorian from the University of HardKnocks --
