Paring Chisels in need of some TLC
« back to Hand Tools forum
Forum topic by Coddiwomple posted 07-06-2018 04:55 AM 998 views 0 times favorited 13 replies Add to Favorites Watch
View Coddiwomple's profile
Coddiwomple
3 posts in 734 days
07-06-2018 04:55 AM
Topic tags/keywords: question chisel refurbishing
My first post to Lumberjocks!
I recently acquired a set of paring chisels that belonged to my grandfather which were probably made in the 1930s or 1940s. The appear to be good quality chisels but there are no makers marks on any of them and I have no idea what kind of steel they are made from. All in all, they are in pretty decent shape though they need to be cleaned up, reground, sharpened, and honed. I can handle all that.
Upon closer inspection, I noticed that all of these chisels are bent to varying degrees, some as much as 1/8” out of flat! It’s almost as if they were used to pry something.
These somewhat delicate paring chisels should, I believe, be dead flat. Does anyone have any suggestions about how to flatten them or have them flattened in a way that won’t damage them further? Any and all comments/suggestions would be most appreciated.
Thanks.
-- Bill in Asheville, NC
13 replies so far
View Andre's profile
Andre
2364 posts in 2044 days
#1 posted 07-06-2018 05:32 AM
You probably only need to get 3 or 4 inches flat for most work, but with a paring chisel it is nice to flatten the entire blade. Took me many hours on a set of Stanley 720’s, don’t think I have ever used them? Almost always use crank neck for any Paring.
View John Smith's profile
John Smith
1552 posts in 401 days
#2 posted 07-06-2018 11:10 AM
what are your plans for them ?
are you going to put them into your tool bin and actually use them?
I think they would look nice if left “as is” and you build a nice display case
with a glass front, like a shadow box and display them proudly in your home.
very nice set of vintage tools
-- I started out with nothing in life ~ and still have most of it left.
Coddiwomple
3 posts in 734 days
#3 posted 07-06-2018 12:23 PM
I plan to use them though I had thought of displaying them. Would trying to bend them flat and following that up with grinding work?
View BlasterStumps's profile
BlasterStumps
1071 posts in 678 days
#4 posted 07-06-2018 01:59 PM
I would smith them using a rubber faced mallet and some strips of wood strategically placed under the blade. Checking your work often using a flat surface to reference to. It might take some trial and error. I have straightened chisels and even made a crank neck chisel this way. easy does it.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View HokieKen's profile
HokieKen
7567 posts in 1377 days
#5 posted 07-06-2018 03:10 PM
You can try to bend them like BlasterStumps suggests. I’d use a propane or MAPP torch to heat localized areas to aid in bending but keep the heat well away from the cutting edge. If you really like the chisels and want to put them into service, you may consider taking them to a machine shop and having them surface ground flat.
-- Kenny, SW VA, Go Hokies!!!
Smitty_Cabinetshop
15816 posts in 2857 days
#6 posted 07-06-2018 04:06 PM
I suggest not risk the damage you may cause and use them as they are. Plenty of surface to register the work against, you’ll get used to (and excel at) using them just as your granddad did.
Coddiwomple
3 posts in 734 days
#7 posted 07-30-2018 11:59 AM
Okay, Smitty I have decided to take your advice and do a minimal intervention. Clean them up, flatten the first few inches past the tip, grind a new edge, sharpen, hone, and use.
Thanks for all your suggestions.
View bilyo's profile
bilyo
474 posts in 1341 days
#8 posted 07-30-2018 02:50 PM
I think you have made a wise decision. Trying to straighten them risks breaking them. If they were estate sale finds then I would suggest giving it a try. But these belonged to your grandfather. If they are not usable then put them on display. Otherwise, sharpen them up and put them to use. That small bend will likely have very little adverse effect; if any.
View Bill Berklich's profile
Bill Berklich
503 posts in 627 days
#9 posted 07-30-2018 03:05 PM
Curious to know what did your Grandfather did for a living? Mine was a Pattern Maker and Tool and Die Master and he modified (and made) many of his tools to suite his needs including the needs of the moment. Quite a few of he’s chisels are bent (not cranked) specifically so he could pare surfaces/places that would not be accessible to a off the shelf flat chisel.
-- Bill - Rochester MI
Smitty_Cabinetshop
#10 posted 07-30-2018 05:34 PM
You go, Bill! Get ‘em working, enjoy!
View KYtoolsmith's profile
KYtoolsmith
46 posts in 98 days
#11 posted 10-13-2018 11:39 PM
Hello all! Read the above an had to join… From my long time collecting old wood working tools, I have found that nearly all early firmer and paring socket chisels have a very subtle curve. The “modern” convention is for all chisels to be dead flat. But this was not always the case. I recommend that you do nothing to alter what look to be a fine set of chisels. In my own use, I find the curve is an advantage when truing a dado or rebate.
-- "Good enough" is just an excuse. Good workmanship needs no excuses.
View TheFridge's profile
TheFridge
10816 posts in 1724 days
#12 posted 10-13-2018 11:47 PM
Yep. The whole surface doesn’t need to be flat. Would be nice but it’s not necessary.
View Derek Cohen's profile
Derek Cohen
418 posts in 4207 days
#13 posted 10-14-2018 12:35 AM
- Coddiwomple
Yep, that’s what I would do.
The Japanese slicks (paring chisels) I use have a slightky canted blade, which makes it possible to use the blades flat to the surface. I suspect that yours (are they Witherby) are for the same purpose.
Regards from Perth
Derek
-- Buildiing furniture, and reviewing and building tools at http://www.inthewoodshop.com
