1" x 8 tpi spindle tap question
Forum topic by Chris posted 718 days ago 2213 views 0 times favorited 6 replies Add to Favorites Watch
View Chris's profile
Chris
148 posts in 2281 days
718 days ago
Topic tags/keywords: 1 spindle tap 1x8 tpi spindle tap tap for wooden spindles
I am looking to purchase a 1”x8 tpi spindle tap that is designed to be used for wood and is made or marketed by Beall. I was wondering if the tap was by chance designed to work with a 1” forstner bit for if this tap is designed like all other taps of course an undersized drill size would be used.
Therein lies the dilemma, this tap is designed for woodworkers. i am not presently familiar with any drill bit on the market outside of high speed drill bits that come in such variations of sizes which one may need to use with this tap.
Curious to know if anyone is familiar with this system?
Chris
-- Chris Harrell - custom callmaker "Quacky Calls" Eastern NC. http://www.quackycalls.com
View crank49's profile
crank49
2370 posts in 1166 days
#1 posted 718 days ago
1” x 8 tpi is a standard bolt thread for metal. I doubt, if a specialty wood thread existed, that it would use the same identical description as a metal thread. Bellow are standard metal tap and drill sizes.
INCH SIZES -
NATIONAL COARSE
TAP SIZE———DRILL SIZE
1/4-20———————#7
5/16-18——————-F
3/8-16———————5/16
1/2-13———————27/64
5/8-11———————17/32
3/4-10———————21/32
7/8-9————————49/64
1-8————————7/8
1-1/8-7——————-63/64
1-1/4-7——————-1-7/64
1-1/2-6——————-1-11/32
You are in luck. As you can see, the drill size for a 1”- 8 thread is 7/8”. That is a standard Forstner or Brad point drill size.
I saw on Woodcraft’s site they are suggesting tapping a hole in wood to match the standard thread of a lathe spindle, so YES!, this is in fact a standard metal thread size. It is so you can remove the chuck and just screw the wood workpiece onto the lathe in place of the chuck.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View sarahss's profile
sarahss
233 posts in 845 days
#2 posted 718 days ago
I recently checked into it for my Jet Mini lathe with a 1×8 TPI headstock. After talking with Jet and McMaster Carr, they recommended this, but I haven’t ordered it yet and don’t know if the “pitch” of the threads would be correct or not.
http://www.mcmaster.com/#2521a581/=cz5j9e
don’t know if you want to spend that much either, but we got the tap & dye set (1×8TPI)—from Grizzly, I think—anyway, the threads the tap cut were not compatible with my lathe headstock.
View David Kirtley's profile
David Kirtley
1250 posts in 1193 days
#3 posted 718 days ago
It is a metal tap to match the metal threads. I have one but have not used it yet. I believe the instructions do say 7/8 bit but I would have to go look when I get home.
Chris
#4 posted 717 days ago
Thanks guys, i actually called Craft Supplies USA today and spoke with a rep and to reiterate what you guys are saying, the rep said the particular 1×8 spindle tap in question does utilize a 7/8” pilot hole.
So there i go!
Thanks again, Chris
View bubinga's profile
bubinga
860 posts in 863 days
#5 posted 717 days ago
The 1×8 tap does use a 7/8” bit, a brad point is much better choice, and you can buy it,( and odd sizes) from Beall Tool
The tap you are looking to purchase, has a removable guide on the end,that guides the tap straight
I have made, and tapped wood nuts for 1/2”, 5/8”,3/4”, 1”, 1 1/4” and 1 1/2”, wood bolts.
IMPORTANT: When tapping in wood, clamp in vise to avoid splitting
-- E J ------- Always Keep a Firm Grip on Your Tool
Chris
#6 posted 716 days ago
“IMPORTANT: When tapping in wood, clamp in vise to avoid splitting
—E J”
THanks EJ, with this tidbit i will not have to go through the school of hard knocks in this area. Chris
