How thick bench top?? 2"? 3"? 4"?
Forum topic by TwoThumbBruce posted 07-05-2018 03:51 PM 1315 views 1 time favorited 28 replies Add to Favorites Watch
View TwoThumbBruce's profile
TwoThumbBruce
36 posts in 3252 days
07-05-2018 03:51 PM
I’m building My Last Workshop, and one of my first projects will be a workbench. Most of the workbenches i see on YouTube use 2×4 or 4×4’s for the tabletop. Is 4” really necessary? It’s not the cost, and just a bit of the extra work, , but wouldn’t 2” or 3” (nominal) be enough? I’ll have wood vises and dog holes.
Someplace I read that working mostly with power tools, as I’ll be doing, doesn’t have the same needs as old school woodworking, I don’t want a table that’ll bounce, but is 4” think tops necessary?
-- Bruce, Florida
28 replies so far
View jmartel's profile
jmartel
8278 posts in 2386 days
#1 posted 07-05-2018 04:04 PM
Not necessary. But more mass is always better. I’d go with 3” over 2” for sure. 2” is a little thin for holdfasts. Can be used, but 3” is better.
View jmos's profile
jmos
905 posts in 2606 days
#2 posted 07-05-2018 04:18 PM
Depending on how you’ll use the bench, the weight of a thicker top is really useful. Mine is 4” thick and 7’ long, and it never thinks about moving when I’m hand planing. The thicker top can also be nice when you’re chopping with a chisel, as a thinner bench top may flex a bit. I’d also say a minimum of 3” if you’re doing hand work.
As you say, if you’re mostly doing power tool work, 2” is probably sufficient. According to a blog on Tools for Working Wood, 2” thick works fine for holdfasts.
If you confident you’re not going to take the trip down the hand tool rabbit hole, you should be fine with 2”.
-- John
View jdh122's profile
jdh122
1058 posts in 3054 days
#3 posted 07-05-2018 04:22 PM
I made mine out of 2×4s and it’s very solid. But you might want to check out Mike Siemsen’s version of the Nicholson bench, all built out of construction lumber at less than 2 inches thick, with a bit of reinforcement at strategic places. And he’s an all hand-tool guy too.
-- Jeremy, in the Acadian forests
View MrRon's profile
MrRon
5261 posts in 3480 days
#4 posted 07-05-2018 04:22 PM
Weight is your friend so a thick top is most desirable, especially since cost is not a factor.
View HokieKen's profile (online now)
HokieKen
7549 posts in 1375 days
#5 posted 07-05-2018 04:31 PM
I’m a hybrid guy myself but most of the work done on the bench is hand tool. My bench also doubles as my assembly table for larger projects. My top is about 3-1/4” thick White Oak. My goals for the top were mass and rigidity as others pointed out. I’m happy with my bench as-is but I wouldn’t want it any thinner for the purpose of weight. Even with the 3+” top, 4×6 legs and 4×4 stretchers, the dang thing will shift occasionally on my slick, concrete shop floor when I’m scrub planing.
Honestly, even for power-tool work, I’d go as thick as you can practically. If you have some good, stable 8/4 stock you want to use, then go for it. But if you’re going the 2X construction lumber route, I’d buy a few extra pieces and go for 3” instead. I’ve heard guys say they wish their bench was thicker/heavier. Never heard anyone complain it’s too thick though. Err on the side of caution when practical…
-- Kenny, SW VA, Go Hokies!!!
View gargey's profile
gargey
1013 posts in 1012 days
#6 posted 07-05-2018 04:33 PM
You said “My Last Workshop.”
If that’s the plan, don’t undershoot and wish you’d done better.
It’s not much extra work (or money, if using construction lumber as you suggest).
View bondogaposis's profile
bondogaposis
5150 posts in 2587 days
#7 posted 07-05-2018 04:40 PM
I think depends on the style of bench you intend to build. For a Roubo, I wouln’t go less than 3”. The weight and mass is your friend on that style of bench. The other types of benches I’n not familiar with so I’ll let others comment on that. Do you have a style in mind?
-- Bondo Gaposis
View PPK's profile
PPK
1246 posts in 1046 days
#8 posted 07-05-2018 04:49 PM
Not necessary. But more mass is always better. I d go with 3” over 2” for sure. 2” is a little thin for holdfasts. Can be used, but 3” is better.
- jmartel
+1
-- Pete
View Bill_Steele's profile
Bill_Steele
459 posts in 1968 days
#9 posted 07-05-2018 05:47 PM
I agree with the other posts—you want a heavy solid workbench. If you’re not dead set on a wood tabletop—you might consider MDF. It’s heavy, flat, and does not change much (if at all) dimensionally. Four layers of 3/4” MDF will get you a heavy and solid work surface.
View builtinbkyn's profile
builtinbkyn
2680 posts in 1177 days
#10 posted 07-05-2018 05:53 PM
Depending on how you ll use the bench, the weight of a thicker top is really useful. Mine is 4” thick and 7 long, and it never thinks about moving when I m hand planing. The thicker top can also be nice when you re chopping with a chisel, as a thinner bench top may flex a bit. I d also say a minimum of 3” if you re doing hand work.
As you say, if you re mostly doing power tool work, 2” is probably sufficient. According to a blog on Tools for Working Wood, 2” thick works fine for holdfasts.
If you confident you re not going to take the trip down the hand tool rabbit hole, you should be fine with 2”.
- jmos
The 2” they cite does work, but it also depends upon the thickness of the stock being held. I’ve cleaned up my top twice now and it’s approaching the 2” thickness. I find thinner stock isn’t holding as well. Sometimes I need to give the holdfast another whack or two.
-- Bill, Yo!......in Brooklyn & Steel City :)
View BurlyBob's profile
BurlyBob
6030 posts in 2502 days
#11 posted 07-06-2018 05:37 AM
Bigger is always better and it suck to build a light duty bench and wish you’d built it bigger. Mines going to be a 5”-5 1/2” top.
TwoThumbBruce
#12 posted 07-06-2018 06:08 AM
Well, THAT was impressive! You guys chimed in cast my doubts away! Quick! Of course, in retrospective, the answer is obvious with the minimal downside being overwhelmed by the much more substantial benefits or potential benefits.
I have my new Laguna Fusion F2 arriving this afternoon and if the Florida heat eases up a bit I’m going to start on my workshop and I’ll try to make a few LJ projects. I hope I don’t embarrass myself too much!
Thanks guys!
-- Bruce, Florida
View bigJohninvegas's profile
bigJohninvegas
544 posts in 1698 days
#13 posted 07-06-2018 06:11 AM
Like others say, It depends on what kind of work you are doing. I love the idea of a 4” thick bench. But that just does not fit my needs. As it turns out, I too for the most part am a power tool woodworker. And with my small shop size, My bench needed to be an outfeed/assembly table as well as a workbench.
In the end I loosely copied the benches from a local school. The top of my bench is two sheets of 5’X5’- 3/4” baltic birch ply wood. And 4/4 poplar, and 1” ply for the legs and base. Flat, and solid as a rock. And when the top gets worn out. Just a new sheet of plywood.
Photo was when bench was brand new, had not added the dog holes yet.
-- John
View jonah's profile
jonah
1972 posts in 3535 days
#14 posted 07-07-2018 02:12 PM
My workbench top is about 3.5” thick, and I like it. Personally, I wouldn’t go less than 3” for a classic hand tool or hybrid bench, but honestly, with the right bracing, stability, and a heavy base, you can get by with a 2” top.
View CaptainKlutz's profile
CaptainKlutz
693 posts in 1730 days
#15 posted 07-10-2018 07:16 PM
Agree with other posts >> If you want hand tool bench:
2” thick is marginal for using hold fasts. Bench dog holes will also wear faster than thicker top.
3” thick works with hold fast, and allows for 3-4 major top re-surfacing as top gets more experience.
4” thick will allow your kids to use the bench after you die, unless are type who abuses his bench top and needs to resurface it every couple years; then best plan for 6 inch thick.
IMHO – For a classic hand tool use, would not start with less 3.5 inch lumber thickness for a new bench.
Do not forget that you have to flatten the top after glue up. It is easy to make glue mistakes or get some warp after glue up that will require 1/4+ inch removal to get long table top flat initially. Before you know it, 3.5 inch top becomes 3 inches. So best to start at least 1 inch thicker lumber than final thickness you want to end up using initially.
Best Luck.
showing 1 through 15 of 28 replies
