Big Green Egg
Forum topic by richgreer posted 06-29-2011 07:53 PM 22080 views 3 times favorited 22 replies Add to Favorites Watch
View richgreer's profile
richgreer
4541 posts in 3039 days
06-29-2011 07:53 PM
Has anyone built their own support stand for the Big Green Egg (BGE)?
If so, do you support the BGE with a ring that is slightly smaller than the diameter of the BGE near the top or do you support it with a shelf at the bottom and a larger ring?
What wood did you use? Any problem with the wood getting too hot?
Do you have any general advice to offer?
22 replies so far
16274 posts in 4183 days
#1 posted 06-29-2011 07:58 PM
I’m eager to hear the response, Rich. I’ve been thinking of building my own cart for a Weber kettle grill, but I can’t decide how to support it so that the hot metal won’t be directly touching the wood. Then again, I’m not sure if that is even an issue.
View Chris 's profile
Chris
1879 posts in 3956 days
#2 posted 06-29-2011 08:12 PM
Rich,
I don’t think wood is an issue. I just found a page on their site with free plans for tables that will hold the eggs. So, it should be straight forward.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
richgreer
#3 posted 06-29-2011 08:26 PM
Never thought to look on their website. Yes, the plans look very simple.
All of my other outdoor furniture is made of ipé. I think I will get some more ipé and go to work. With ipé, I’ll probably have a table the weighs as much as the BGE.
View Bertha's profile
Bertha
13521 posts in 2658 days
#4 posted 06-29-2011 08:44 PM
I thought I saw one here, because I think I recall replying about the big green egg (which I’m a freak over) and not really mentioning his project. I could, of course, have dreamt all of this.
View crank49's profile
crank49
4030 posts in 2936 days
#5 posted 06-29-2011 08:46 PM
A friend of mine has a BGE on a cart that a local furniture has made locally. It’s made of Cypress and the egg sits on a lower shelf on a 2” tall fixture that looks a little like those concrete bases you put under a deck. I assume the grooves in that fixture serve to let air flow through. The top shelf of the cart has about a 1/4” gap from the egg. The whole thing is on 4” casters.
View Richard's profile
Richard
297 posts in 2502 days
#6 posted 06-29-2011 09:47 PM
You DO realize that this reads like something I would post, right?!
I have never heard of a ‘BGE’ and, honestly, thought this was some sort of joke… hell, had me laughing!
Checked out the plans and realized what was going on.
Even if it was unintentional, you got me.
Thanks, guys…
This is just another example of why I joined this group.
-- 'I sand, therefore, I am'. Richard. PNW.
View mattshack's profile
mattshack
45 posts in 3061 days
#7 posted 06-29-2011 10:04 PM
Rich, I dont have a BGE but I do have a Primo (a ceramic cooker similar to a BGE). I built a table for it out of cedar. I have not had any issues with heat but the grill does sit on ceramic feet which I placed on a large ceramic tile. Also if you want some design ideas you can check out this forum, http://primogrillforum.com and look under the “Show Off Your Tables, Stands and Outdoor Kitchens” section. I hope this helps.
View Dave Pearce's profile
Dave Pearce
108 posts in 3637 days
#8 posted 06-29-2011 10:18 PM
Sounds like more than a couple Jocks have built their own BGE table. If I ever get the wherewithall, I’d certainly love to have an “egg” to call my own.
http://lumberjocks.com/search_results?cx=016283335483199634424%3A4na88symhay&cof=FORID%3A9&safe=high&q=big+green+egg#1226
-- http://www.pearcewoodworking.com
View jerkylips's profile
jerkylips
394 posts in 2535 days
#9 posted 06-29-2011 11:14 PM
I’m making an assumption, but I’m guessing that the BGE doesn’t get nearly as hot on the exterior as the weber, because of the ceramic construction.
For those who have them, are they as good as I’ve heard? I’ve never heard anything bad spoken of them, but they are EXPENSIVE!
View DPN's profile
DPN
2 posts in 2487 days
#10 posted 06-30-2011 01:23 PM
Here’s mine. Used the egg table plans for the overall dimensions. It’s made of MDO for the casework carcass with teak stiies rails and T&G in typical frame and panel construction design. The teak oil created a reddish cast, but that has since mellowed and allowed the natural teak color to show through.
DPN
Chris
#11 posted 06-30-2011 02:18 PM
Very nice result with that DPN.
#12 posted 06-30-2011 04:12 PM
DPN: Very nice!!!!!
Jerkylips: I think you are correct about the outside temp of the BGE being considerably lower than a Weber. That’s why I was really hoping to hear from someone who had done what I was looking to do.
View DPN's profile
DPN
#13 posted 07-01-2011 02:02 AM
Rich, I cut through the teak and the plywood sub top giving only 1/8” airspace without any heat damage to the perimeter. I inset a piece of slate on the bottom shelf to catch the ash when i clean the bottom.
The best advice I can offer is to build the table for the largest egg made. I own the large, but built a table that would accommodate the x-large. I’ll upgrade someday and won’t have to steal from my daughters college savings account to buy more teak.
Charlie, While the wood does get warm,I think a Weber in this application would be to hot. I can touch the side of the egg and not get instantly burned. If I would have done that on the Weber I had before my egg, I know I would have left some skin behind.
DPN
View Dabilene's profile
Dabilene
23 posts in 2656 days
#14 posted 07-01-2011 03:18 AM
I built one similar to the pic above. Mine is on wheels & made of cedar. I set the BGE on an 18” x 18” concrete stepping stone that is about 2” thick. Stepping stone it sitting on the bottom cedar shelf.
View treeman's profile
treeman
208 posts in 3414 days
#15 posted 07-01-2011 11:49 AM
I built two of these; one for my son and one for myself. Made of cypress with a granite work surface. The drawer holds most of my “Eggcessories”.
