3/4 hp Router Too Weak?
Forum topic by Nemuri posted 07-04-2018 06:12 PM 282 views 0 times favorited 7 replies Add to Favorites Watch
View Nemuri's profile
Nemuri
1 post in 99 days
07-04-2018 06:12 PM
Hi all,
Sorry for the n00b-level question here, but…
Somebody has a free router for me, but it’s only ¾ hp. I can’t even find any new ones online with less than 1hp.
Is this thing gonna be too weak to even bother using, or can I go ahead and use it with some caveats/limitations?
7 replies so far
View MrUnix's profile
MrUnix
6887 posts in 2316 days
#1 posted 07-04-2018 06:21 PM
It will work just fine as long as you don’t try running large bits, and the price is certainly right.
View John Smith's profile
John Smith
1309 posts in 280 days
#2 posted 07-04-2018 07:46 PM
Like Brad says – just fine for soft woods and taking small bites at a time.
I have had several 3/4 hp Craftsmans in my younger years and when they pooped out,
I slowly moved up to 2-1/4 hp which is more than adequate for the work I do.
when it is time, start moving up in HP with 1/2” collets.
and don’t let anyone kid you, there is nothing wrong with having 6 or more routers !!!!!!!
I started out with practically nothing ~ and still have most of it left.
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View Bill White's profile
Bill White
5048 posts in 4078 days
#3 posted 07-04-2018 08:23 PM
You didn’t say what brand or age.
-- bill@magraphics.us
View JCamp's profile
JCamp
796 posts in 668 days
#4 posted 07-04-2018 08:41 PM
It’s free so just get it and give it a try. Also welcome to LJs
-- Whatsoever thy hand findeth to do, do it with all thy might
View bondogaposis's profile
bondogaposis
4926 posts in 2469 days
#5 posted 07-04-2018 08:43 PM
It will work just fine for most things.
-- Bondo Gaposis
View LesB's profile
LesB
1801 posts in 3561 days
#6 posted 07-04-2018 09:37 PM
Free is a good place to start.
Use sharp bits and don’t go too fast. But don’t go to slow either or the bit will burn the wood….especially Cherry.
If you need to use larger bits you can get a bigger router later. A 2hp + is adequate for almost all routing.
I have had good luck with the Porter Cable 890 series of routers which uses the same motor on a variety of bases.
There are routers that are less then 3/4 hp but they are trim routers…..not much bigger than a large Dremel tool.
-- Les B, Oregon
woodbutcherbynight
5545 posts in 2526 days
#7 posted 07-04-2018 09:49 PM
Free is good, as others said go slow and use smaller bits.
