| Forum topic by Walt M. | posted 694 days ago | 1136 views | 1 time favorited | 13 replies | ![]() |
694 days ago |
Topic tags/keywords: outdoor projects oak finishing Iv’e used poly on most everything I do but this project will be outside all year round so not sure if that’s a good idea or Thompsons waterseal? I’ll be using oak not stained. Thanks Walt |
13 replies so far
#1 posted 694 days ago |
Fine Woodworking did an article on outdoor finishes a few years ago. You can find it here. As I recall, the liked 2 Epithanes products best. One was a marine varnish and the other was a marine epoxy. I hope this is helpful. -- Rule # 1 - Don't mix yer blood and sawdust! |
#2 posted 694 days ago |
Forget Thompson watrer sealer, it is crap. Any big box stores exterior finishes will no last even in 3 months. As what Sumdume said, use Epithanes Marine Varnish or boat industry standard. -- shdesign3.com |
#3 posted 693 days ago |
The wooden boat folks I know turned me on to Penofin. You have to re-apply regularly for a while (ie: a month or two, and then few months or years), but allegedly eventually it gets to the point where it’s permanent. And re-applying it is easy. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#4 posted 693 days ago |
Than I try some of that. |
#5 posted 693 days ago |
Benjamin Moore Paint. -- When the moderator chooses sides, his site sucks. |
#6 posted 693 days ago |
Every coating has to be refreshed outside….the difference is the amount of time you can wait before it has to be done. I really like Valspar Spar Varnish….or any maritime varnish….these are made to peal off slowly from the UV and can last up to 3-5 years in a heavy maritime environment (may or may not be longer in your outside environment)....Epoxies are all heat vulnerable…alot of them let go when exposed to directly with the sun – the same will happen to a finish with a poly resin in it….they will last a bit…but not as long as a marine varnish. -- Woodworking.....My small slice of heaven! |
#7 posted 692 days ago |
What exactly are you making? -- shdesign3.com |
#8 posted 692 days ago |
At this point, you’ve posed a fairly open-ended question. As Steven H asked, it depends on what you’re building, and whether or not you’d consider paint/stain, or are looking for something more clear or natural looking. Several good products mentioned above, at least from what I’ve read in the past about them. You might also consider teak oil. You’ll have to reapply about once a year, but it’s a very simple application. -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
#9 posted 692 days ago |
So just to elaborate on my “Penofin” answer earlier: Per Jonathan, it’s an oil. And as ReggieK says, everything has to be refinished regularly when it’s outside. The reason to use an oil finish outside is that refinishing is a matter of “wipe it clean, apply the oil, wait a little while, wipe it off”. My experiences with varnish is that when they degrade you have to do a lot more surface prep, taking off cracked finish, sanding, etc., than you do with oils. I don’t know where the trade-off for how long the finish lasts vs how much time you spend wiping on new oil is, but I hate sanding, and adding another coat of oil is easy. -- Dan Lyke, Petaluma California, http://www.flutterby.net/User:DanLyke |
#10 posted 692 days ago |
Common mistake I see people do it they wait until varnish fail. Dont wait until it cracks. Refinish before it does. -- shdesign3.com |
#11 posted 690 days ago |
Well I should have said what the project was to begin with sorry, didn’t think about that but it’s only three pieces of oak for a barbecue grill to place plates of food and whatnot. The reason I was using oak was because the other wood they used seen to get broken and left jagged edges that was dangerous around kids. though it seems sacrilege to paint oak for a woodworker it may be the best option since I won’t have access to the wood very often. I thank everyone for the comments as I may be building some picnic tables and benches soon and would need this kind of information to tell the client what I would use for a finish. Not sure what type of wood to use since redwood doesn’t seem to be very widely used these days and teak well you can figure that one out. So you can tell I don’t have much experience with outside projects. @Steven H I bookmarked your blog good information there thanks |
#12 posted 690 days ago |
Ipe (pronounced: “E-Pay”) is another excellent wood to use for outdoor projects, although it isn’t the cheapest thing either. It’s one of the nice alternatives to using teak, at a lower price point. A few links with ipe facts and ipe lumber: -- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker." |
#13 posted 690 days ago |
Used on out door stuff I`ve found Australian Timber oil is by far better than Penofin on softwoods. Did my own little test with both, 2 coats of each on Sitka spruce, a year later, the one with ATO still beaded the all day rainfall. -- FUN IS GOOD Smithers BC |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15797 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
