| Forum topic by Craig | posted 721 days ago | 850 views | 0 times favorited | 7 replies | ![]() |
721 days ago |
Have a planer showing up this afternoon and want to make sure I have the correct fittings. Does anyone know if its a 4” or 2 1/2”? Running a 4” line off the separator, so I will need a reducer if its smaller. Can’t find any information online. Thanks. |
7 replies so far
#1 posted 721 days ago |
My Ridgid 13” planer came with a 4” to 2 1/2 reducer yours may also.I am amusing you have a cyclone separator with 2 1/2 fittings. |
#2 posted 721 days ago |
Geez, I know the 735 is a 4”. With all the debate about 734 v. 735, if there was a differnce in port size, it seems like it would come up as the first complaint. My guess is 4”; we’ll see if I’m right. I bought a 4 to 2.5 reducer on Amazon that was of surprisingly good quality. If you can’t find it, I’ll scour my buy history. Good luck. You’ll like this machine. You gonna put the $400+ Byrd in her? ;) -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#3 posted 721 days ago |
Between this and the jointer, I better get started on the better half’s wish list before I get anything else! I might run out and get the reducer just to be safe. I am running a 4” line off the separator, which is connected to a HF collector. I made a new set up for it this weekend, I’ll see if I can post some pictures. Mainly wanted to eliminate all the kinks in the hose from the fan to the separator and then out. Its mounted above the can now with the intake straight down, similar to whats been posted here. Thanks again. |
#4 posted 721 days ago |
Well spent $8 for a guy with any level of impatience. I’d put my list up against yours any day, Craig. Try to explain why electrolyzing a bit brace is required before making wooden vents that contain no round holes. I had to face that one last night:) I also had to face the $800 Incra jig in my Amazon cart. “now what does it do again?” ;) Good luck and enjoy your tool. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#5 posted 721 days ago |
I have the 734, it has a 4” port with a reducer for running 2 1/2”. -- -Steve, Seattle |
#6 posted 721 days ago |
Tadow! 4” ! Steve, is yours like the 735 with two sets of rings, the innermost for 2.5? -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#7 posted 719 days ago |
Bertha, it’s not like that. The chip collector has a 4” port molded into it, and the reducer simply slips over the port and knocks it down to 2 1/2”. -- -Steve, Seattle |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
