Help finding router bit moulding profile.
Forum topic by juicegoose posted 06-28-2011 04:26 PM 3804 views 0 times favorited 10 replies Add to Favorites Watch
View juicegoose's profile
juicegoose
117 posts in 3062 days
06-28-2011 04:26 PM
I’m in the process of making a reproduction piece for the wife and was trying to find a moulding style similiar to the crown they used on the original. I’ve found some small 2 1/4” crown moulding i could use but I’d rather find a case moulding with a similiar profile as this.
Can any of your router guru’s point me to a good place for router moulding bits in larger sizes like 2 1/4” length. Also if I would need to make a compuond moulding out of multiple profile what would you guys recommend i do. here is a picture of the profile.
10 replies so far
View fussy's profile
fussy
980 posts in 3051 days
#1 posted 06-30-2011 04:04 AM
That’s an awfully big router bit you’re asking for. I do not believe it exsists. Go instead to www.mlcswoodworking.com and find profiles you can combine. Choose the right ones and do a little experimenting with setups, and you can do that in about 2 setups on your router table. Fine Woodworking had an article a while back by Gary Rogowski, I believe, on this subject.
By the way, MLCS bits are as good as any, prices are ok, and the shipping is FFREE!!!
Steve
View ,'s profile
2387 posts in 3547 days
#2 posted 06-30-2011 04:27 AM
I agree with steve on this. There are some large router bits but i feel the qualitt would suffer in a router application.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3286 days
#3 posted 06-30-2011 03:38 PM
I also agree. That is too big for a router. Those mouldings are typically done with a moulder in a production shop, usually having 4 to 6 heads on them. I have found it is even difficult on a big shaper to run some large mouldings, (especially if they have to run standing up on the edge) and would probably make 2 or 3 passes that way. Try 2 o 3 router bits—it is safer and better.
All that said. I usually buy my mouldings, or sometimes use a combination of store bought and pieces I make.
-- http://shepherdtoolandsupply.com/
View Bertha's profile
Bertha
13528 posts in 2693 days
#4 posted 06-30-2011 04:09 PM
Are you talking “molder” meaning shaper or router. That’s a demanding job for even the biggest router. If you’re talking shaper, I’ve used these guys:
http://www.carbide.com/catalog/custom-knives.cfm
They ain’t cheap, but the quality is there. You could always make your own molding plane. You’d be ready for the Ironman after a few dozen feet:)
View Oreps's profile
Oreps
3 posts in 2796 days
#5 posted 06-30-2011 04:30 PM
“fussy” Steve’s idea seems good. I checked FWW and found a good article by Phillip Lowe at http://www.finewoodworking.com/FWNPDF/011166074.pdf.
Hope that gets you started.
10401 posts in 3648 days
#6 posted 06-30-2011 05:06 PM
If you’re patient and skillful you can rough in the coves with a table
saw and refine the moulding with old moulding planes. I’ve done that
a few times and it’s kind of fun. You’ll need one or two cove planes
and a veining plane helps make the crease. The shape is finished up
metal scrapers you grind yourself and then sanding (those little rubber
“tadpole” sanding blocks work great).
View Mickey Cassiba's profile
Mickey Cassiba
312 posts in 3031 days
#7 posted 07-01-2011 03:22 AM
The moulder Kent refers to is(if I read his comment correctly) is sorta like a jointer with profiled knives. About six heads over 18-20’ of iron beds. Noisy beasts!
-- One of these hammers oughta fix that...
Kent Shepherd
#8 posted 07-01-2011 06:36 PM
Al, didn’t mean to ignore your question—just now checked back.
Mickey Cassiba
#9 posted 07-01-2011 06:57 PM
Yup, that’s what I was talking about. Used to maintain six like that…total daily production of around twelve thousand L.F
View buckles's profile
buckles
24 posts in 2542 days
#10 posted 07-03-2011 05:12 AM
juicegoose
I make wooden parts for clocks and sometimes some wants a molding . So I cut it on my CNC machine. I can cut the molding for you cheaper than you can have knifes made.
PM me if you are interested.
Regards
Joe
-- Politicians are like diapers. They need to be changed for the same reasons.
