Fixing up knob and tote on old Stanley hand plane
Forum topic by Brett posted 06-28-2011 04:11 AM 2930 views 0 times favorited 2 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2646 days
06-28-2011 04:11 AM
Can anyone share some tips on fixing up the knob and tote from an old hand plane? Should I sand or strip off the old finish (anybody know what it is)? What is a good stain/sealer/finish to use?
-- More tools, fewer machines.
2 replies so far
View WayneC's profile
WayneC
13753 posts in 4061 days
#1 posted 06-28-2011 04:17 AM
The best resource I know of is on the Rexmill site…
http://home.comcast.net/~rexmill/planes101/handle_repair/handle.htm
I sand and use schellac…
View Dan's profile
Dan
3630 posts in 2844 days
#2 posted 06-28-2011 07:14 AM
I used to sand mine with sandpaper but I then changed over to using the scotch or 3m abrasive pads. The pads are much finer, last longer and IMO work much better on the Rosewood. I have Green, Red, Silver and white pads I and I use them in that order. The white is super fine and will really give you a nice super smooth surface.
I also found the sandpaper a lot harder to get around the curves of the tote where the abrasive pads work much better. The knobs I put on a bolt tighten it with a nut and chuck it in the drill press and sand with the pads.
I have used shellac, clear lacquer, poly and tung oil for finishes and I personally think Lacquer and tung oil give the best finished look. I usually use lacquer though because I can spray finish and it drys fast.
-- Dan - "Collector of Hand Planes"
