My new saw update
Forum topic by SCOTSMAN posted 06-27-2011 10:23 PM 1159 views 0 times favorited 10 replies Add to Favorites Watch
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3671 days
06-27-2011 10:23 PM
Well we finally got the 590 kilo saw into the shop.It had to be taken to pieces as the layout of my woodshop is behind my house up a steep driveway and round the back of a large two story house then up a small flight of steps then doors removed wrangled into the shop front door through another set of doors you get the pictureLOL. Anyway it was fitted but I couldn’t get it to work the blade wouldn’t turn despite trying hard to under power . It worked fine at the sellers place so I knew it would be ok once checked out my a qualified electrical expert My best friend is just such a man and he did it all for me.To explain I don’t have 440 volt 3 phase but have a rotary convertor ,now this beauty is all of seven and a half horse power and takes a sixteen inch blade.Anyway there was a problem with the convertor and he tweaked it for an hour or so, and it now runs fine. to go back over what I just said needless to say once brought into the shop it had to be reassembled again as it was taken apart every nut and bolt including a 200 +pound cast iron top.I am curently working on an overhead guard which I am fabricating myself as they cost some of them over two thousand dollars on ebay ask me to show you them if you find this hard to believe.Anyway as soon as I get the guard finished I will take some pics and let you see my proud new aquirement and of course achievement. MY three sons and my nephew were marvelous and did all the work as I am not capable health wise of doing much . Will be soon in touch I hope your as pleased with the results as I am. Alistair
10 replies so far
SCOTSMAN
#1 posted 06-27-2011 10:36 PM
see what I mean. The design I am making is more traditonal and larger read wider. Alistair
http://cgi.ebay.co.uk/CX550-Circular-Saw-Guard-/290305922826?pt=UK_BOI_Building_Materials_Supplies_Carpentry_Woodwork_ET&hash=item439794d70a
View PurpLev's profile
PurpLev
8539 posts in 3734 days
#2 posted 06-27-2011 10:41 PM
glad to hear you’re up and running in the shop. that guard looks very interesting. looking forward to seeing you saw all put together.
View Jim Bertelson's profile
Jim Bertelson
4192 posts in 3250 days
#3 posted 06-27-2011 10:45 PM
Yikes, my saw isn’t even worth a 4th of that guard.
Enjoy your new saw, friend. Hope you have some fine new things to show us soon.
And I will be interested in your guard, but somehow, I suspect it will involve some custom metal work. Mine will be built in the next month out of plastic, aluminum extrusions from the hardware store, and possibly a little wood.
Here in my vacation home in La Conner WA, 10 days off from work. I will be blogging a silly misadventure or two, but no real woodwork here. Next trip down, I hope to buy a modest table saw, and build a few small sleds. Even less room here than in the shop at home, but adequate for some fun small stuff.
Alaska Jim
-- Jim, Anchorage Alaska
SCOTSMAN
#4 posted 06-27-2011 11:16 PM
Thanks Jim your a real gentleman ,and a dear friend. Take care paL kindest regards Alistair
View sedcokid's profile
sedcokid
2733 posts in 3684 days
#5 posted 06-28-2011 12:45 AM
Glad you have your saw working… It is always good to see a project come together. Take Care
Thanks for sharing
-- Chuck Emery, Michigan,
View mafe's profile
mafe
11740 posts in 3175 days
#6 posted 06-28-2011 01:52 AM
Wonderful the saw is up and running.
That price for a sawguard is …..
Best thoughts,
Mads
View John Ormsby's profile
John Ormsby
1288 posts in 3823 days
#7 posted 06-28-2011 02:07 AM
I think it is a very good idea to make the saw guard wider. They have a tendency to get pulled closer together with the blade and dust collector running. There might be a chance of the guard hitting the blade. My overhead guard is about 2” wide and I am glad it is that wide.
The wider guard will also allow one to use dado cutter heads if the machine is able to accept them on the arbor.
-- Oldworld, Fair Oaks, Ca
View Manitario's profile
Manitario
2630 posts in 2969 days
#8 posted 06-28-2011 02:31 AM
I am highly impressed that you were able to get a 590kg saw as you put it ”...behind my house up a steep driveway and round the back of a large two story house then up a small flight of steps then doors removed wrangled into the shop front door through another set of doors..”
I look forward to seeing the complete guard, and the projects you’ll make with it.
View Per Isacsson's profile
Per Isacsson
66 posts in 2656 days
#9 posted 06-28-2011 06:59 AM
To move a 590kg saw is impressive and that far… Good job.
I as many looking forward to you solution for the overhead guard.
-- Per I
TopamaxSurvivor
18342 posts in 3762 days
#10 posted 06-28-2011 10:13 AM
Sounds like it might have been easier to move the shop than the saw ;-)) Can you get big enough wood back there to warrant such a big saw? Glad you got it moved and up and runnig. Have fun and keep your fingers out of it !!
