Wood vs. Trex?
Forum topic by jasoncarpentry posted 06-27-2011 07:55 PM 2491 views 0 times favorited 10 replies Add to Favorites Watch
View jasoncarpentry's profile
142 posts in 2589 days
06-27-2011 07:55 PM
I’m starting to build an overhead lumber-storage rack in my shop. I have some Trex (2×4 and 1×6) left over from another project, and I’d like to use it for some or all of this rack. However, I’m concerned about the structural properties of the Trex vs. those of regular 2×4’s, etc. Since Trex is a composite of wood & plastic, does it have as much resistance to bending as wood? Also, its higher density will make the rack itself heavier and possibly more likely to collapse. If that happens while I’m standing under it, well …
I realize that the main advantage of Trex is its resistance to rain & UV light, hence its superiority over wood for outdoor structures like decks. But for this indoor project, is there any good reason to use it instead of wood?
-- Jim in Tennessee
10 replies so far
View Lee Barker's profile
Lee Barker
2170 posts in 2785 days
#1 posted 06-27-2011 08:05 PM
Wood is the right choice here, Jim. Good for you for a thought outside the box…there must be other homes for your Trex if you keep thinking you’ll land on it.
-- " his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It"
View crank49's profile
4030 posts in 2905 days
#2 posted 06-27-2011 10:13 PM
If you have any applications for wood in contact with concrete, like in a basement, this is a good material for that. I use it for the sill at the base of a framed wall sitting on concrete, and for base plates on the bottom of table and workbench legs that will be in contact with the concrete floor.
View Dennis Fletcher's profile
Dennis Fletcher
467 posts in 2989 days
#3 posted 06-27-2011 10:28 PM
The trex is definitely not meant as a structural material for the application you are talking about. I actually disagree that it could be used for structural anything, as it is prone to bending at much less spans that wood and most would use it like it was a 2×4, unfortunately.
--, Making design and application one. †
View Cosmicsniper's profile
2202 posts in 3093 days
#4 posted 06-27-2011 11:09 PM
I build small observatories with Trex decking. If there aren’t closely enough spaced floor joists, you could probably use the deck as a trampoline…it’s THAT flexible.
Definitely use wood…regular 2×4s are cheap and will give you all the support you need for that.
-- jay,
View Spotcheck's profile
8 posts in 2461 days
#5 posted 06-30-2011 12:31 AM
As noted – way too flexible. Also – if the weight of the shelves themselves might be the cause of failure on a lumber storage rack, you may want to rethink a couple of the design fundamentals :)
View MrWoodworker's profile
65 posts in 2529 days
#6 posted 07-01-2011 11:59 PM
Heavy, bouncy, and not a great choice.
View eaglewrangler's profile
64 posts in 2471 days
#7 posted 07-02-2011 06:10 AM
take an old trex board and bend it until it breaks, you will never think of it as structural again. The only hard part of breaking it is knowing to cost of it. It is also unstable, expannding in heat, sagging if spanned more than 16 inches, decking is all it can do.
View devann's profile
2246 posts in 2627 days
#8 posted 07-02-2011 08:38 AM
Better go with the wood. Trex has always had to much of a sag factor for me even when used at manufactures recommended spacing specifications. I built myself an overhead lumber storage rack from some 12’ post oak pallet material I came across, it worked fine. After finishing the rack take some measurements from floor to shelving and periodically check them to be sure that everything is staying were you put it. Due to space limitations I had to make mine a cantilever design. Some Simpson connectors can also be used the beef up some of critical joints.
View TheDane's profile
5384 posts in 3597 days
#9 posted 07-02-2011 02:58 PM
Trex is a good material for jigs & fixtures in the shop.
View ChrisMc45's profile
100 posts in 2794 days
#10 posted 02-11-2012 11:17 AM
Agree with TheDane & EagleWrangler, all good points. Great decking, also grand for jigs and tool handles as it machines super-smooth. Heavy, flexy; strongest in compression not in tension or torsion.
