How to fix tearout?
Forum topic by Marcel T posted 145 days ago 241 views 0 times favorited 11 replies Add to Favorites
View Marcel T's profile
Marcel T
127 posts in 161 days
145 days ago
Hey LJ’s,
I bought a beautiful board of Purpleheart, but unfortunately it has some really nasty tearout from a jointer (I think). It’s nice and smooth, then there is a big knot and it’s tearout-ville. How can I remove it? I do not have a planer or a jointer.
Also, is it normal for parts of Purpleheart to shine? When I wet it down, parts of it just SHINE, it’s absolutely beautiful!
I will try to post pictures ASAP.
Thanks! :)
View Dadoo's profile
Dadoo
1479 posts in 425 days
145 days ago
The knot is formed where a branch was and the grain of course takes a drastic turn at this point. The planer blades will always catch this grain, but if you turn the board around, the blades will smoothly plane the knot. Another way is to sand it smooth. Scrapers also do a good job of this. Most guys will either cut it away or glue it in place with epoxy.
And some really cool fixes are to remove the knot and fill it in with turquoise chips and epoxy! Or you could substitute stone, glass, silver or gold leaf…what have you?
View Earle Wright's profile
Earle Wright
122 posts in 155 days
145 days ago
Another way to handle the tearout is with a handplane. My preference for the job is a bevel-up smoother or jack plane from Veritas. I use either a 38 degree blade or a 50 degree blade. Added to the 12 degrees of the plane bed, you end up with an effective cutting angle of either 50 degrees or 62 degrees.
I’ve been able to plane without tearout most of the time using just the 38 degree blade. The 50 degree blade will most certainly handle the toughest grain situations.
The other advantage of using bevel-up planes is that there is not frog to adjust, as in ‘Bailey-style’ planes.
-- Earle Wright, Lenoir City, Tennessee
Marcel T
145 days ago
Thanks guys! :)
As said in my first post, is it normal for parts of Purpleheart to shine?
View GaryK's profile
GaryK
8392 posts in 423 days
145 days ago
Parts shine and others don’t.
Marcel T
145 days ago
Thanks Gary. I just thought it looked kinda like the stripes on figured maple or something of the sort.
Marcel T
139 days ago
Those pictures I promised, a view of the board and closeup of the tearout.
View Sawdust2's profile
Sawdust2
823 posts in 522 days
139 days ago
Sand, sand, sand.
The shininess probably comes from compression when the wood was cut.
View 8iowa's profile
8iowa
114 posts in 196 days
139 days ago
I agree with earle. A handplane is the answer.
View Tom Adamski's profile
Tom Adamski
210 posts in 205 days
139 days ago
Marcel,
You are right, it is a beautiful board. You have a dilema my friend. I’d recomend finding someone (friend or nearby business) with a planer (with sharp blades) and clean it up. If that is not do able, get yourseld a good scraper and go to work. Pay attention to the grain, It will be easier and give better results in one direction over another. Don’t spend too much time sanding purpleheart. It is very heavy and dense, and will just use up a lot of your sandpaper while leaving the surface of the wood dull and uneven. Check out the “Joliet” box in my gallery and you’ll see that purpleheart shimmer.
Good luck,
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
GaryK
139 days ago
You could also try putting it through the jointer/planer at an angle, not straight through.
Marcel T
139 days ago
Thanks guys! I think I’ll try taking it to the local lumber seller and ask if they can resurface.
Bookmark And Share This Page
