Splines.....how to?
Forum topic by John Cleary posted 06-27-2011 02:32 PM 1284 views 1 time favorited 8 replies Add to Favorites Watch
View John Cleary's profile
John Cleary
74 posts in 2782 days
06-27-2011 02:32 PM
Topic tags/keywords: jig question router miter saw
I am wondering how would you go about making cuts in a box to receive splines, having no tablesaw or bandsaw?
Maybe a router set up or on a mitresaw ( as these are the only options regarding power tools).
Cheers!
-- crumbs make bread--
8 replies so far
View blackcherry's profile
blackcherry
3338 posts in 3822 days
#1 posted 06-27-2011 03:07 PM
One of the best ways is a jig for the table saw, either riding on the fence or in the miter slot. By adjusting the blade high you will be sizes the length of the spline. The piece of wood with the pencil lines is a story stick to set the stop block on the jig. Next place your box to fit snug against the stop block and cut the spline. Here a pic’s of my jig hope this help understanding spline made on the table saw…BC
View Toolz's profile
Toolz
1004 posts in 3741 days
#2 posted 06-27-2011 03:19 PM
You can use the same type of jig on a router table if you have one.
-- Larry "Work like a Captain but Play like a Pirate!"
View Woodwrecker's profile
Woodwrecker
4149 posts in 3574 days
#3 posted 06-27-2011 03:20 PM
He said he doesn’t have a table saw or a band saw BC.
You can do them on a router table Johnnie with a sled set up similar to that used on the table saw.
I bet you’ll be able to find a ton of examples if you do a search on this site.
Good Luck.
-- Eric, central Florida / Utor praemia operibus duris
View PurpLev's profile
PurpLev
8535 posts in 3647 days
#4 posted 06-27-2011 03:47 PM
Aren’t the above suggestions for KEYS (perpendicular to the box sides joints)? If that is what the OP is asking about then a jig for the router table, or an inverted version for use with handsaws wold be a good method. If the question thought is about SPLINES that bind together things like miter joints and go parallel to the joint then routing then I would either create a router sled that holds the parts at 45, or use a router plane with an edge guide.
blackcherry
#5 posted 06-27-2011 03:52 PM
OPS my bad…
John Cleary
#6 posted 06-27-2011 04:17 PM
Thanks for the advice so far.
@ BC + Toolz That sled looks like a good option for me as i have a router table.
View ImolaS3's profile
ImolaS3
3 posts in 2533 days
#7 posted 06-27-2011 04:45 PM
Hand saw for thin ones using a guide made for a couple of pieces of scrap. if not, then a sled on the router table – I have done both often and both work well
View cassady's profile
cassady
16 posts in 2407 days
#8 posted 11-30-2011 08:19 PM
Dumb question alert!!! I am trying to get info on using splines as part of building boxes. Is the use of splines more of just a decorative feature or do the serve a structural component? Also, I have seen several videos on building a spline jig so I am ok with that part but have not been able to find anything on creating the keys. Are these something that you can buy at a store like biscuits?
-- Cassady in Denver, CO
