| Forum topic by Bob Babcock | posted 611 days ago | 1240 views | 6 times favorited | 10 replies | ![]() |
611 days ago |
Topic tags/keywords: sketchup tutorials I’ve added a few tutorials that I originally did for FWW to my Sketchup tutorial blog http://lumberjocks.com/jocks/Treefarmer/blog/4011 Any questions let me know. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
611 days ago |
Thanks! -- Gary, East TX -- The longest journey begins with a single step. |
610 days ago |
I am going to take about three days and immerse myself in this program. There are a few hurdles I just can’t seem to get over. |
610 days ago |
What are the problems you’re having rikkor? -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
610 days ago |
Say it’s a table. |
610 days ago |
Lets say you want to move the apron so that it lines up with the top of the leg and is centered on the leg. To move the apron onto the leg you should 1st have both as seperate components. Once you have that you can click on the apron to select it, then choose the move tool. Move the cursor to the midpoint of the line defining the connecting edge of the apron and hover over it until you see a small box next to the cursor that reads “Midpoint in Component” then click to select that point. You will now be dragging around the apron by that midpoint you selected. Drag it up to the line defining the edge of the leg where you want it to connect and hover over it until you see the same “Midpoint in Component” box and select it. You will now have the apron precisely located at the midpoint of the leg. This also works for endpoints and centers of circles. Now lets say you actually want the apron 2” down from the top of the leg. Select the apron and then click the move tool. You can now click any point in the model (it doesn’t even have to be on a surface or line) and start to drag down in the blue axis. Type in 2” and the apron will move exactly 2” down. If you had wanted to move it to the edge so that the faces were flush just move it from the endpoint of the apron to the endpoint of the leg. Do you have the learning center tips dialogue active when you 1st enter sketchup? If not you can turn it on by going to the HELP menu and selecting LEARNING CENTER.The 8th window shown is about moving things accurately. It has a small animation that illustrates what I just explained. The other tips that are shown are just as valuable too. There is also a tab for additional resources which will give you a list of links for sketchup help. Once in sketchup the help menu also has links to all the official online resources. 1st thing you should do is open up the “Quick Reference Card” and print it out to have available. The sketchup users guide (windows pdf) can be downloaded here: http://dl.google.com/sketchup/gsu6/docs/ug_sketchup_win.pdf A few questions for you rikkor. Have you viewed the online videos available at sketchup.google.com? The 1st thing I did when starting to use sketchup was to take a day and go through all the videos. Absolutely the best way to get started. 26 version 5 videos here, all still relevant…http://sketchup.google.com/gsu5vtvideos.html Do you have the INSTRUCTOR turned on? If not you can turn it on by going to the WINDOW menu and selecting INSTRUCTOR. The instructor gives context sensitive help for whatever tool you have selected. Most of the questions I get on sketchup already have good explanations available for them either directly in the help menu or online at sketchup. You just need to know where to look. Don’t be too frustrated. I’ve equated learning sketchup to running a strange marathon. The 1st mile is all uphill, then you get over the top and someone hands you a bicycle and a mai-tai and its all downhill and time to party…:) -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
610 days ago |
Thanks. This will take a little time to assimilate. I appreciate your help. |
609 days ago |
Again, nice tutorials Bob. How did you get them published in FWW? -- David, South Windsor, CT "I love the smell of sawdust in the morning" |
609 days ago |
Nice work Bob. Thanks for sharing. |
609 days ago |
Thank you David. I have just copied both yours and Bob’s suggestions into a document to print, and I am going to go forth and slay this dragon! |
609 days ago |
Don’t worry about stepping on any toes Brad. No ego here (LOL..or at least very little). It’s all good. I hardly ever use construction lines in my work but I know a lot of folks do. I’m a lot quicker without them…less steps…but I know they can help. I started doing tutorials on FWW’s knots forum about a year and a half ago as a way to contribute since I was learning so much from others there. The editors saw the tutorials and asked me to help start the Design, Click, Build sketchup blog with Dave Richards and Tim Killen. It wasn’t long after the blog started that I found LJ. As much as I enjoyed FWW I found the vibe here so positive that I wanted to help LJ grow. I walked away from a paying gig at FWW so that I could focus my efforts here. Now my life has gotten so busy that I even have a tough time posting here. I’m making an effort to be more active though so I hope that folks will ask for help with specific problems that I can do tutorials for…or at least describe the process that I would use to solve it. BTW…for those of you that do not have an online subscription to FWW you are missing out. The blog is still active and Tim Killen is not only great with sketchup but his processes for design are great. He also builds some amazing stuff. -- Bob, Carver Massachusetts, Sawdust Maker http://www.capecodbaychallenge.org |
| Forum | Topics |
Woodworking Skill Share
2937 |
3967 |
260 |
956 |
226 |
Woodworking Trade & Swap
624 |
Coffee Lounge
2403 |
LumberJocks.com Site Feedback
525 |
