Jet table saw dust collection
Forum topic by piesafejim posted 698 days ago 1239 views 0 times favorited 5 replies Add to Favorites Watch
View piesafejim's profile
piesafejim
33 posts in 703 days
698 days ago
Topic tags/keywords: dust collecti woes
Hello fellow lumberjocks.
I am having dust collection problems and could use some of your input. I have a jet cabnetmakers table saw with the dust collection port in the back, my collectin unit is the Harbor Freight 2hp unit and i only have a 10’ trunk with 2 outlets on it. I just dont get the suction out of my saw would like and i always hae a pretty good pile in my saw and still get peppered with sawdust over the top of the blade, any advice would be greatlly appreciated.
5 replies so far
View gfadvm's profile (online now)
gfadvm
6650 posts in 861 days
#1 posted 697 days ago
I have the same problem when using a zero clearance insert but not with the factory insert. It appears that over the top of the blade dust collection is the only answer. Ill be interested to see what others have to offer. I also see the same thing when using my super sled which stands to reason as it is a zero clearance as well.
View pintodeluxe's profile
pintodeluxe
1754 posts in 984 days
#2 posted 697 days ago
Blade height makes a huge difference. I only raise the blade enough for the carbide to clear the wood by 1/8” or so. This works well for most hardwoods, but I raise it higher for plywood and melamine to avoid any chips.
View Chipy's profile
Chipy
378 posts in 764 days
#3 posted 697 days ago
I worked in few wood shops with industrial dust collection top of the line duct work and you know what there is allays sawdust to clean up.I just got use to the idea of minimizing or mitigating dust.You will all ways have to clean up.I just set up a box fan behind my saw to blow the fine dust away from the saw.As long as you system is not getting clogged and it is getting most of the dust then your doing good.I think gfadvm is got a point with the zero clearance insert
it probably reduces air flow.A dedicated dust collector for your table saw is about the only answer and that will not get everything.At one shop I worked at we had a 5hp Delta uni saw with a 5hp two bag dust collector and their was still dust that would well up from the saw cabinet we just used a fan behind the saw.I hope this is some help to you.
piesafejim
#4 posted 697 days ago
Thans for the insight. I agree about the zero clerance, but my problem i think is with where the motor is locted in relation to where the port for the collection is on my saw. I am considering cutting a new port on the right hand side of my saw. I am not really having a dust iin the air problem I guess i want mine to work like the ones on tv you knw what i mean no chips at all lol.
Chipy
#5 posted 696 days ago
piesafejim Yes dust is one thing and chips are another.Hope your mod works out well. Sometimes these engineers that design tools miss things we grunts figure out and that’s a cool thing!
