Table Saw Decision Help
Forum topic by dpwalker posted 06-24-2011 09:08 PM 4325 views 0 times favorited 14 replies Add to Favorites Watch
View dpwalker's profile
dpwalker
273 posts in 2798 days
06-24-2011 09:08 PM
Hi folks, I am thinking of replacing my $200 Craftsman saw with a better more accurate saw. I am looking at the Ridgid R4510 & Ridgid R4512. Both are the same price at my local HD. They are pretty close in specs. The 4510 has a higher amp rating & also a higher blade speed, so I assume more power? Overall dimensions of the saws are pretty close by only an inch or so. My question is should I go with the lighter more powerful portable saw or the maybe sturdier, heavier saw? Is there really any reason to go with the 4512? I should mention I have a small shop. It’s an 8’X10’ storage shed that I share with the lawn equipment which I remove each time I want to use the “shop”. Any thoughts are appreciated. Thanks Dean
-- You have not really lived until you do something for someone who can never repay you.
14 replies so far
View PurpLev's profile
PurpLev
8534 posts in 3616 days
#1 posted 06-24-2011 09:27 PM
the 2 saws a significantly different. the 4510 is a portable saw while the 4512 is a stationary hybrid.
the 4510 uses a universal motor while the 4512 uses an induction motor which is actually more powerful than the universal motor. Also less noisy and will last far longer than any universal motor.
Sizewise both saws will take about the same floor space unless you store the portable saw on it’s side on a top shelf somewhere. if you plan on storing it horizontally then it’ll take just about the same floor space as the hybrid though.
Generally speaking, if you are a contractor and need to take the saw with you on jobsites – get the portable one, otherwise I would go with the heavier with more mass, more accomodating tablet top surface, more powerful, less noisy saw being the 4512.
mind you – this is merely based on the 2 options you presented assuming those are the only ones you can go with.
good luck.
View DonnyBahama's profile
DonnyBahama
215 posts in 2498 days
#2 posted 06-24-2011 10:56 PM
I’ll advocate for a heavier saw for better accuracy. (Assuming you don’t need it to be portable – if you do, keep some sandbags around to add weight/stability to the lighter saw.) If you don’t need it to be portable but can’t leave it in the middle of your shed, buy or make a mobile base for it.
In that price range, you may want to consider looking for a used cabinet saw. If you need/want to stick with 110VAC, look for a hybrid saw from Steel City, Grizzly or Jet. Any of those should offer a better table, trunions, fence and probably even motor than the Ridgid.
-- Founding member of the (un)Official LumberJock's Frugal Woodworking Society - http://lumberjocks.com/topics/29451
View crank49's profile
crank49
4030 posts in 2938 days
#3 posted 06-24-2011 11:00 PM
I have the Sears Craftsman version of the R 4512. I got it for father’s day last year, so I have about a year of use on it. It’s a nice saw. Cast iron top, good fence, riving knife, decent blade guard, plenty of power and runs very quietly (compared to any portable)
I put a good blade on mine and replaced the miter guage with an Incra V27. There were some minor issues with assembly and in particular setup, due to real crappy manual that Sears provided. Being an engineer I just put the manual away and figured it out myself. If you get one, the Ridgid manual may be better, if not, pm me and I’ll be glad to offer any guidance I can.
Over all, I think these saws are about the most saw you can get for the money; unless you can catch a deal on a used saw. For a small shop it has a very good set of retractable casters, but if your shed is not on a concrete slab that won’t help you much. These saws weigh close to 180 lbs.
View knotscott's profile
knotscott
7980 posts in 3343 days
#4 posted 06-25-2011 12:49 AM
Your assumption that the R4510 has more power is incorrect. It uses a universal motor that has less torque than the belt drive induction motor of the R4512….the universal motor is much louder. From a perspective of function, other than portability, the full size stationary saw has every advantage you might name….mass, stability, accuracy, power, reliability, upgradeability, repair feasibility, resale, user friendliness, noise, etc. From a practical standpoint, I can see why a portable might be attractive for your small shop…within it’s classification, the R4510 is a capable jobsite saw.
View NBeener's profile
NBeener
4816 posts in 3141 days
#5 posted 06-25-2011 12:51 AM
The 8’x10’ shop probably DOES rule out a used cabinet saw … unfortunately.
While you’re looking around in that price range, I’d also evaluate the Bosch 4100 and the DeWalt DW744—both very good saws, and with excellent mobile stands.
Good luck !
-- -- Neil
View Paul M Cohen's profile
Paul M Cohen
86 posts in 3745 days
#6 posted 06-25-2011 02:39 AM
Look into a Shopsmith depending on your budget a used one can be found cheap (on Craig’s List or eBay) and upgraded over time or a new PowerPro which would give you a 2 HP highly accurate tool. You would also get a drill press, shaper, tabletop router, disk sander and several other professional tools in less space than a bicycle.
-- Paul, Beaverton OR, www.TravelbyPaul.com
View William's profile
William
9949 posts in 2809 days
#7 posted 06-25-2011 02:51 AM
My personal recommendation is to see if you can find a used Ridgid TS3650. I have one. I see them popping up a lot on Craiglist lately because some people are going with the newer just becasue they think the newer has to be better. I got my 3650 used. It took me some time to get everything adjusted becasue the previous owner had no idea what she (yes, a woman owned it) didn’t know what she was doing. After getting everything right on it though, I couldn’t be happier.
I have looked at the two saws you’re interested in and if someone tried to trade me my 3650 for either of those, they’d have a fight on their hands.
View ChefHDAN's profile
ChefHDAN
1057 posts in 2817 days
#8 posted 06-25-2011 03:02 AM
Concurr with William, I’ve got a floor model TS3612 which was just before the 3650, and the only thing I’d like to have that the new saws have is the riving knife
View David's profile
David
172 posts in 2810 days
#9 posted 06-25-2011 04:28 AM
Na they’re all wrong, find a R4511, or similar granite top 110v/220v hybrid saw. You will not be disappointed!
-- “Don’t tell me what can’t be done, tell me what you want done then shut up and get out of my way and let me do it!”
View Steven H's profile
Steven H
1117 posts in 3027 days
#10 posted 06-25-2011 04:45 AM
Try to avoid universal motors at all times. If you REALLY NEED it portable, then go for it.
Paul M Cohen
#11 posted 06-25-2011 06:48 AM
He has 80 square ft, I think the tables on some of these saws are almost that big. Plus rotating them 90 degrees in that space is a bear. Then where does he put the rest of his power tools.
If I had a 1,000 square ft shop I would have made very different decisions, my current shop is 220 square ft and can’t dream of fitting a usable dedicated saw, plus lathe, jointer, bandsaw… and still fitting in the shop.
View richgreer's profile
richgreer
4541 posts in 3042 days
#12 posted 06-25-2011 06:41 PM
My first shop was 10×12. I had a ShopSmith plus a miter saw and a benchtop thickness planer. It was very crowded, but I built a lot of stuff in that small shop.
I tell you this to say if you have such a small shop, seriously consider a ShopSmith. IMO, it’s the right option for a small shop, despite some of its shortcomings.
Paul M Cohen
#13 posted 06-25-2011 08:30 PM
Rich,
Everything has shortcomings in an 8×10 space, what shortcomings are you talking about that still apply to a Shopsmith Mark 7 or 520?
A lot of opinions of a Shopsmith were formed when it has tiny tables, a crappy fence and 3/4 HP motor. With 2 HP variable speed DVR 110/220 motor (found on no other saw today), very large removable tables (so it still fits and works in an 8×10 space), a great fence and Riving knife those don’t apply.
Plus it can do things none of the saws talked about here could dream of, like cut metal or plastic due to it high torque and/or low speed, drill horizontally and vertically removing the need to try and fit a drill press into the space.
dpwalker
#14 posted 06-25-2011 08:36 PM
Thank you all for replying. I think based on these recommendations I am leaning towards the 4512. Mobility shouldn’t be much of an issue. It will only be used at home.
PurpLev & knotscott thanks for the lesson in universal vs induction motors. Very enlightening.
My local Craiglist is pretty lean on quality tools. Most of what is for sale is by home owners who are selling the lower end table saws used for home improvement projects.
I am going to weigh the options a little longer then pull the trigger on one. Dean
