Question on French Cleat Storage Systems
Forum topic by groland posted 06-23-2018 02:24 PM 1085 views 0 times favorited 7 replies Add to Favorites Watch
View groland's profile
groland
195 posts in 3530 days
06-23-2018 02:24 PM
Topic tags/keywords: french cleat system on irregular walls
I wonder what solutions guys have come up with for putting French Cleat Storage racks on walls that are irregular? None of the videos I have looked at address this.
In starting to lay out the locations of my Fr. Cleat system, I noticed that the sheetrock walls are far from flat in any plane. I plan on using 1/2” plywood screwed into the studs to which the cleats (also 1/2 inch plywood) would be attached.
If you have done this satisfactorily, and like the results, I would like to know how you handled the bumps and shallows in the walls behind?
Thanks,
George
7 replies so far
View HTown's profile
HTown
114 posts in 1304 days
#1 posted 06-23-2018 03:00 PM
I use FC in the shop with sheetrock walls that aren’t noticeably bumpy.
The depth of the cleat will take up some wall variance. (ie. they may not seat all the way). Also short mating cleats would only need that length of the wall to be in reasonable shape.
Hope this helps.
View Rich's profile
Rich
3533 posts in 707 days
#2 posted 06-23-2018 03:08 PM
I personally wouldn’t use plywood for cleats. Its layered construction makes it weak in one of the directions that it will be under load. Some 4/4 poplar, or something similar will not only be stronger, but give you more leeway for undulations. Also if the wall is too irregular for even that, use some shims.
View BlasterStumps's profile
BlasterStumps
855 posts in 557 days
#3 posted 06-23-2018 03:45 PM
There are metal hanger brackets that work similar that might work with irregular surfaces.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View pontic's profile
pontic
626 posts in 726 days
#4 posted 06-23-2018 03:53 PM
I had to put shims on a few of mine. They worked well.
-- Illigitimii non carburundum sum
View jerryminer's profile
jerryminer
942 posts in 1559 days
#5 posted 06-25-2018 02:55 AM
+1 on shims. Small pieces cut from a cereal box (or equivalent) work well for this. Stack them up as needed. A drop of glue will keep them in place.
Plywood should work fine for cleats. It’s plenty strong in the directions you need.
View bobasaurus's profile
bobasaurus
3530 posts in 3302 days
#6 posted 06-25-2018 03:47 AM
I have a 4×8’ backer sheet of plywood on mine to make it uniform.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
View jonah's profile
jonah
1837 posts in 3416 days
#7 posted 06-25-2018 02:52 PM
Treat it just like a window or door frame. If it’s irregular, you shim it to be straight and flat. Shim behind the cleat wherever there is a gap, then screw through the shims. Be sure to pre drill the hole in the shims or they’ll split.
