Anyone own a wecheer power carver?
Forum topic by Chris posted 06-24-2011 07:53 AM 3228 views 0 times favorited 5 replies Add to Favorites Watch
View Chris's profile
358 posts in 4021 days
06-24-2011 07:53 AM
I am in the market for a power carver and was considering the weecher brand. I was wondering if any of you own this particular brand or are familiar with their design in the chucking of the bits. If i understand correctly, the company that makes them designs the chucks in one of two ways, there is a collet chucking system and jacobs chucking system.
Can these systems be changed out on any of their designs?
What in your opinion would be the better means of chucking when it comes to power woodcarvers?
I plan on using mine for tedious, close quarter carving and am concerned about hand fatigue, etc;? I am thinking about the various weights about the two units. Really wanting something that doesn’t cramp my hands too bad.
Any further suggestions in regards to other brands, other carvers, and the like are highly welcome. I am very familiar in regards to tooling in the arena of woodturning but not so in the realm of woodcarving.
so go easy guys
-- Chris Harrell - custom callmaker "Quacky Calls" Eastern NC.
5 replies so far
View Jim Finn's profile
Jim Finn
2641 posts in 2857 days
#1 posted 06-25-2011 03:38 AM
I have a mastercarver brand set up. About the same as wecheer. I have three different hand pieces. One is a mini jack hammer that takes small gouges and works like a charm for carving. Another is a collet type hand piece and the third is a chuck and key type. The chuck and key type is a LOT easier to change out tips with. It is also larger than the other two handpieces and for me is more comfortable to hold. It will take up to 1/4’ tips whereas the collet type handpiece is limited to smaller tips. Wecheer…mastercarver…and foredom hand pieces are all interchangeable I believe. I have a table top power unit with speed controler in it. I opted to not get the foot speed control because to me it is tireing to hold my foot in one place all the time.
View Jim Jakosh's profile
Jim Jakosh
20180 posts in 3041 days
#2 posted 12-25-2012 11:05 PM
Hi Chris. I am also looking to buy a power carver. I have a Dremel tool but it only handles 1/8” bits. They have a cheap carver at Harbor Freight with a foot pedal, which is nice , but it only goes to 5/32” .
I just got the Woodcraft sale flyer and they have a 1/4 HP Weecheer that will take 1/4” bits for $159.
In searching today, I found a 1/3hp Wecheer carver for $169 and I’m thinking that is what I should buy. If you are interested, drop me a PM and I’ll find the site for you….......Jim
View Howie's profile
2656 posts in 2858 days
#3 posted 12-26-2012 01:08 AM
I have the wecheer and have been very satisfied with it.
Like Jim Finn stated get the table top speed unit. The foot control is not that comfortable.
-- Life is good.
View lwllms's profile
555 posts in 3217 days
#4 posted 12-26-2012 01:25 AM
The collets in the hand piece are weak part of Weecheer’s design. They’re aluminum and deform a little under pressure. This makes changing points or other tools a lot harder than it should be. Foredom’s hand piece will fit a Weecher flex shaft but they’ll add to the cost of the tool. If you’re careful and only lightly torque the collet nut you should be able to get by for some time. I’ve been thinking of just making some hardened tool steel collets for the Weecher we have but I’m not sure I want to put that much time into the Weecher hand piece. It might be smarter to just buy a Foredom hand piece. Other than the collet situation the Weecher flex shaft seems to be a well made tool.
Grizzly sells a similar flex shaft for about $60 last time I checked. It also accepts Foredom hand pieces but the Grizzly unit isn’t reversible so there are trade-offs there too.
Foredom, of course, is the best made and doesn’t have weaknesses of other units but they’re expensive. It’s all a matter of how much you plan to use the tool and what your budget is. I don’t use those we have for carving so I’m not sure what to say about the carving hand pieces.
#5 posted 12-26-2012 05:09 PM
Thanks, i appreciate the reply. It has been quite sometime since I made this original thread. Since, that time I have settled for the Dremel flex shaft for my Dremel tool, simply because I just needed a tool that would allow me to add little embellishments to my workings and needing something to fit that bill. As far as a bona fide carver goes, i do not necessarily need one at this time.
I do however have plans to purchase one eventually, just not right now…monies going in about a thousand directions right now…(blow out) I do appreciate so much all of the useful feedback and advice regarding the different brands and their pros and cons. Highly useful information for me to use later on. So thanks for that.
Thanks for all offers guys, Chris
