sponge sanding block
« back to Woodturning forum
Forum topic by Karda posted 06-20-2018 04:04 AM 762 views 0 times favorited 17 replies Add to Favorites Watch
View Karda's profile
Karda
1222 posts in 669 days
06-20-2018 04:04 AM
do any of you use sponge sanding blocks and are they as good as sandpaper. I saw them at lowes and they are priced the same as a pack of sandpaper. On the back they say they last longer but do they thanks Mike
17 replies so far
woodbutcherbynight
5545 posts in 2524 days
#1 posted 06-20-2018 04:26 AM
I use them for various applications. They last a decent amount of time and can be washed and such. Get mine from HF usually. Not the very best but they get the job done. Still use sandpaper though, somethings just require it.
LOL
View Rich's profile
Rich
3523 posts in 705 days
#2 posted 06-20-2018 04:35 AM
I have a few and never use them. I like plain old sandpaper with either the Preppin' Weapon blocks or, for finer work, these blocks from Veritas. If I need to get into moulding or other curves, I use rubber profile blocks.
View AlaskaGuy's profile
AlaskaGuy
4353 posts in 2424 days
#3 posted 06-20-2018 04:58 AM
I’ve used quite a few of them. They don’t cut as well as real sandpaper but for sanding between coats of primer, paint and clear costs I think they are great and easily conform to profiles.
Karda
#4 posted 06-20-2018 05:13 AM
ok thanks
View John Smith's profile
John Smith
1308 posts in 278 days
#5 posted 06-20-2018 11:29 AM
- Rich
x2
-- some people are like a Slinky - - - pretty much good for nothing. But still make you smile when you push them down a flight of stairs.
View bondogaposis's profile
bondogaposis
4925 posts in 2467 days
#6 posted 06-20-2018 12:48 PM
I rarely use them except to clean up rust on cast iron, they are really good for that.
-- Bondo Gaposis
View Gene Howe's profile (online now)
Gene Howe
10821 posts in 3544 days
#7 posted 06-20-2018 12:56 PM
They’re great for profiles.
View DBDesigns's profile
DBDesigns
126 posts in 113 days
#8 posted 06-20-2018 01:18 PM
They’re awesome for sanding on the lathe or drill press for round parts. Buy them from Harbor Freight as suggested above. They come in 8 packs and they are way cheaper than Lowes or HD.
I find that they really don’t last any longer than sand paper so i rarely use them on flat surfaces but they conform well to weird shapes so they are very useful for that.
As always, have fun,
Tim
-- I remember when Grateful wasn't Dead
View Nubsnstubs's profile
Nubsnstubs
1359 posts in 1845 days
#9 posted 06-20-2018 02:51 PM
Mike, if you do get some and start using them, do not apply too much pressure as the will start disintegrating. Otherwise, I’m like several other posters, have some, rarely use them…............. Jerry (in Tucson)
View splintergroup's profile
splintergroup
2250 posts in 1338 days
#10 posted 06-20-2018 07:40 PM
I use them extensively, but only for certain applications. The quality is all over the place. For quick flattening of a finish, I’ll use the more rigid blocks. They clog up as fast as sandpaper, but can be cleaned with compressed air. For final finish sanding the cheaper “soft” blocks (actually pads) work quite well. The grit seems finer than their rating (i.e.. 180 grit acts like 220).
Overall they are invaluable for curves and hard to access areas.
Karda
#11 posted 06-20-2018 08:17 PM
thanks for your replies, I’ll give it a shot, its good to know about not using to much pressure thanks Mike
View LeeMills's profile
LeeMills
583 posts in 1417 days
#12 posted 06-21-2018 12:36 PM
I have used them occasionally but not real often, mostly in flat work for rounded corners when I didn’t want to grab a pad sander. Like some, the quality seems to vary a lot. On the lathe I do use the rubber pads (about the thickness of a mouse pad) with psa backed paper for straights and gentle shallows or long beads. For details on the lathe it may be difficult to sand evenly. The ones I have are thick enough that to apply enough pressure to sand around a bead you would be sanding the top much more than the sides, same for a cove. For beads or coves I use the standing strips without a pad so that it can be used down in the beads or coves.
I have used a rigid backer on the lathe for long straight sections such as areas on a wand.
Karda
#13 posted 06-22-2018 12:44 AM
ok thanks
View JCamp's profile
JCamp
795 posts in 666 days
#14 posted 06-22-2018 02:12 AM
I wet sand with them and use them for other than flat surfaces. To me they wear out fast for as much as they cost.
-- Whatsoever thy hand findeth to do, do it with all thy might
Karda
#15 posted 06-22-2018 06:17 AM
ok thanks
