Interesting Woodnet/Toolcrib post - Lumberjock thoughts
Forum topic by USCJeff posted 463 days ago 541 views 0 times favorited 24 replies Add to Favorites Watch
View USCJeff's profile
USCJeff
864 posts in 819 days
463 days ago
Just got an interesting thread in an email from Toolcrib. I thought I’d carry it over to Lumberjocks as I don’t follow the other sites closely.
Anyways, it was about the best “recycled” items for the workshop. This is one of the things I like about woodworking. . . Having a problem and creating a solution. Many household items have found new life in my shop. I’ll list a few but am interested in everyone’s ideas.
~PB & J Plastic Jars – I store mostly paint in these so that I don’t have to deal with larger gallon buckets. Makes touchups faster as well. Good for blending as well. Wax paper or “Press and Seal” works well to keep paint of the threads.
~Baby food Jars – Much like above, but keep little amounts of mixed stains and diluted finishes.
~Baby Wipe Rectangular Boxes – Great for lidded part storage.
~Grocery and Newspaper Plastic Bags – “Free” Gloves for finishing.
~Mouse Pads – Dampens Vibrations under tools (glued to my scroll saw and grinder). Also is a decent sanding and routing pad.
YOUR TURN
-- Jeff, South Carolina
View GaryK's profile
GaryK
9429 posts in 739 days
463 days ago
Baby food jars are great for small things.
Dick, & Barb Cain
6381 posts in 1051 days
463 days ago
I use small yogurt container lids, for mixing epoxy, the container for small amounts of paint.
View Earle Wright's profile
Earle Wright
123 posts in 472 days
463 days ago
one gallon size ziploc bag—- insert filthy 10” sawblade, hold plastic bag open while spraying liberal amout of cleaner of choice, place on flat surface, press all air out of bag and zip.
Blade then basically sits in a small bath of cleaner. Flip after five or ten minutes, push cleaner to blade edges and soak. Then, remove blade, rince under hot water using old toothbrush on pitch. Zip bag and discard.
Reinstall clean blade, once again dropping arbor nut into saw cabinet. Retrieve arbor nut and turn clockwise on arbor for three minutes until you remember it’s a left-hand thread. Reverse direction and drop the arbor nut again. Take long break, breathe deeply, find happy place.
-- Earle Wright, Lenoir City, Tennessee
View Mario's profile
Mario
824 posts in 803 days
463 days ago
Earle, Good idea and have you been watching me change blaeds on my saw? That sounds too familiar.
Thnanks
-- Hope Never fails
View Dadoo's profile
Dadoo
1674 posts in 742 days
463 days ago
Plastic Dixie cups for mixing glues, stains and paints.
I used to keep empty coffee cans, Planters plastic nut jars, Kool-Aid drink mix jars, but have given them all away for 4”x18” storage bins. I have like 15 of them on the shelf, all full of goodies, seperated with the dividers. (Used to have metal card file cabinets.) And if the need arises to take those 3” screws to a jobsite, then I use a plastic jar or bucket.
Also, save your thin cutoffs as they make great stir sticks.
View Bob Burrington's profile
Bob Burrington
9 posts in 474 days
463 days ago
~Baby food jars for small nuts and bolts
~Coffee can are good for just about anything
~ cut up sponges and clothes pins work well for appling stain and touch up painting or finish…
-- SAWDUST...Source of Fiber......Bob
View rikkor's profile
rikkor
11345 posts in 626 days
463 days ago
Any small containers with lids are useful. I am a little ahead right now, so they are going into the recycling for a while.
16268 posts in 573 days
463 days ago
I use mason jars for storing poly. This helps keep it from skimming over in the gallon cans.
USCJeff
462 days ago
Still Laughing Earle. I’ve glued a rare earth magnet to a dowel for that very scenario. Yeah, it’s happened enough to warrant it! Not to mention the LH thread. I go “righty-tighty” every time. That is the primary reason I end up fishing for the arbor nut.
I’ll add a couple more things I’ve used:
~After trimming wired shelving for closets, I like to cut off the individual plastic covered metal rods from the scrap. They make great mixers. Use it to blend epoxy mostly, but most are long enough to mix other materials.
~Baby Wipes – They make spreading caulk and putty into a corner very easy and neat.
~ALMOST FORGOT one of my favorites – Empty nail polish containers. I use a lot of the same finishing materials over and over. I keep a little of each in the tiny containers. The finish keeps the brush moist so that it doesn’t dry out and is always ready for a touch up. Easy to store with built in applicator, nuff said. I’m up to 4 bottles and have requested the females in my life to save them!
View Suz's profile
Suz
51 posts in 508 days
462 days ago
Don’t forget those fake plastic credit cards make good glue spreaders.
Use grocery bags to “sand” the final buffing on your poly or shellac finished projects. It works like a VERY fine sandpaper to knock off any “nibs” in your final coat.
-- Jim
teenagewoodworker
2374 posts in 519 days
462 days ago
-dixie cups for mixing and holding finishes on small projects
-baby food containers for holding random fasteners (my dad uses them mostly)
-paper towels for random cleanup or other things
-plastic knives for mixing and putting gel poly on a cloth
-fake credit cards and used gift cards for spreading glue
View Kevin Violette's profile
Kevin Violette
214 posts in 615 days
462 days ago
-Plastic shot glasses-for small glue applications and mixing sawdust and glue for filler
-peanut butter jars-store fasteners, dowel pins, biscuits, buttons, plugs
-hockey pucks-deaden vibration under table saw
-coat hangers-cut and bend to make custom pegboard hooks
-old t-shirts-excellent for applying stains
-newspapers-to keep the benches clean when applying paint, stain, finish
-shower curtain-covers the table saw when spraying or during glue ups when I use the saw as a bench
-margarine or ice cream containers-for mixing stains in and for storing scres and pieces of furniture while you are refinishing/restoring(make sur you label it!)
-- Kevin -- (http://www.furniturebykevin.com)
View John Ormsby's profile (online now)
John Ormsby
392 posts in 488 days
461 days ago
-the large rolls of heavy duty freezer paper to put on the bench when gluing of finishing. Keeps things clean.
-those very small plastic dixie cups, sold by the thousand, for measuring and mixing epoxy and resin glues and small amounts of stains.
-- Oldworld, Fair Oaks, Ca
View Al Killian's profile
Al Killian
267 posts in 504 days
461 days ago
old sheets and tees for stripping finsh
mud flaps off of trucks under the machines to absorbe to the harmonics.
coffee cans for storeing odd and ends
View Sawdust2's profile
Sawdust2
1071 posts in 839 days
461 days ago
Plastic Jello and pudding cups for small doses of anything.
Been many, many, many years since baby jars have been in this house. The youngest grandkid is 13. The oldest is 18. (Let’s hope we’re not to be great-grandparents too soon.)
Had a neighbor who turned lots of pens. He took 2 liter soda bottles, cut the top off and fastened the bottom to wooden squares. He then numbered the container and kept track of his pen blanks that way.
USCJeff
461 days ago
I hear you Lee. My youngest is now 1 and the baby food jar supply is exhausted. One the upside, he’s getting closer and closer to playing with Lego’s and other toys Dad wants to play with but is too embarrassed to get for himself. hehe. My 3 year old daughter just isn’t into the good stuff. I can only take so much My Little Pony and Care Bears. Thankfully, there isn’t a Wiggle or Teletubby within a mile of the house. Phew.
ANYWAYS, got another idea last night. I recently bought a 6 pack of Harbor Freight 8 oz. plastic storage bottles (HF is great for these types of things – $1.49). They have the little white flip tops with about a 1/4” spout. I’ve put a lot of finishing materials in them. I buy things like Mineral Spirits in large containers so it is very nice to have an 8 oz. container for those. It’s also easy to eyeball measurements for diluting things. I can mix my Shellac and D.A. 3:1 quickly. IDEA – I was eating a salad (happens occasionally) and realized the salad dessing bottle was just about the same thing in a different shape. Slightly larger spout. Will try it when it’s empty.
View Lakey's profile
Lakey
100 posts in 524 days
461 days ago
This isn’t a plug for Vitamin Water, but in addition to the fact that I love it, the caps are really great for glue.
Playing cards or cards from abandoned board games are good for all kind of stuff – mixing small amounts of epoxy, spreading glue, used as shims and spacers.
Canning wax – I always keep a slab handy for slapping on saw blades and plane soles.
Plastic packing tape – great to put on glue blocks and cauls.
—Lakey
-- "No Board Left Behind"
View TomK 's profile
TomK
495 posts in 626 days
459 days ago
Small plastic folgers coffee cans are great for blending and storing finishes. French’s plastic mustard bottle w/ screw top for easy glue distribution whe you purchase in larger containers.
-- If you think healthcare is expensive now, wait until it's free! PJ O'Rourke
GaryK
459 days ago
I keep any type of jar, plastic or glass. Great for mixing and storing dyes and finishes.
View jude's profile
jude
148 posts in 700 days
458 days ago
My grandfather used old jars to store the stains and finishes that he would mix up. Also, baby food sized jars are great for storing miscellaneous screws and such cause you can see them in the jar.
Screw the lid to the underside of an eye level shelf and you can see what you need, unscrew the jar from the shelf, take what you want and screw it back up on the shelf. It’s a great use of unused space.
-- life can always be weaved into a song.
View Harold's profile
Harold
315 posts in 599 days
458 days ago
if you ever have access to some thin bamboo strips, you can make up simple glue brushes amazingly quick, Just cut them in 1/4” strips (or what ever width you would like) and then sand of the softer interior of the bamboo and crush the surface with a hammer. If you have the strips cut and setting in a corner or cup somewhere it takes literally seconds to make a new brush….and you can just cut off the used portion and keep reusing the bamboo until the stick is too short …. this is a great post, I think most people take for granted the small items that are used each day and we don’t realize how these cost’s add up.
-- If knowledge is not shared, it is forgotten.
View Blake's profile
Blake
2560 posts in 626 days
458 days ago
My favorite one for home and shop:
Popsicle sticks! ...and especially the larger “craft” sticks also used as tong depressors in doctor’s offices.
I get them 1000 at a time in a box from the craft and fabric store. At home I use them as stir sticks, butter knives and spreaders because they are cheap, easy, bio-friendly, and disposable. We don’t have a dishwasher so it is nice to grab one for a quick PB&J sandwich, etc.
In the shop they are glue spreaders, paint mixers, shims, epoxy mixers, box splines, mini biscuits, etc. You can put them under a project while you finish it. If you twist them they will break with a pointed edge which is perfect for touch up, detail cleaning, tooth-picking, etc.
I go through a lot of these, they are the perfect quick-to-grab shop accessory.
View Brad_Nailor's profile
Brad_Nailor
1081 posts in 709 days
458 days ago
I save all the plastic PB jars. they are great for fasteners, nails, screws and to mix and store water based paint. I also always save any small to medium size pieces of cardboard. I cut them up and use them to mix bondo on. I also save the tall thin plastic containers the cat treats we buy come in. They are great for storing acid brushes. Unfortunately I am a bit of a pack rat and I tend to keep allot of scrap wood I should really just throw away!
View sIKE's profile
sIKE
968 posts in 505 days
458 days ago
For a good while I was buying the round silicon ball type cat litter. These containers work great for storing many things. I have a half dozen that store the white clips for Christmas lights. I also use them for immersion of items that need to be cleaned mainly like lawn and garden type tools. The orange box sells these little flip top boxes from Sterlite every spring time for a $1.99 and then they clearance out at $.99 I buy a bunch of these also. They work great for storing project based supplies. I typically look at a project and start buying the hardware for it and this is how I keep up wit them.
Bookmark And Share This Page
